3rd Gen 1" lift??
Discussion in '4Runners' started by musicmaan, May 20, 2012.
  1. May 20, 2012 at 8:20 PM
    musicmaan
    musicmaan [OP] Member
    Where the sun don't shine...... Literally
    not enough
    Is there such a thing as a 1" lift for a 3rd Gen?? My wifes Runner could use a little lift, but she won't let me.... I figured I could get away with an inch without her really noticing ;)
    MM
  2. May 20, 2012 at 8:22 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    I think there is some flaw in your logic sir.
  3. May 20, 2012 at 9:39 PM
    musicmaan
    not enough
    hahaha... well, let me re phrase that... she doesn't want me to lift it as much as my Tacoma, (which is only up 2").. so I figured 1" would be good
  4. May 20, 2012 at 9:45 PM
    BakerTaco
    BakerTaco Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    just level it out with bilsteins and maybe tsb
  5. May 22, 2012 at 4:41 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    No TSB for 4runners, we have coils not leafs.
    Your best bet is either 99 tall springs or the cheapest is a 1" body lift.
  6. May 22, 2012 at 8:10 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    did not notice i was in the 4runner section...... awkward.. well see you guys later
  7. May 23, 2012 at 5:58 PM
    musicmaan
    not enough
    nah... body lifts are lame... but what are the "99 tall springs"?? please explain
  8. May 23, 2012 at 8:16 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    They are the coils from certain 4wd 99 4runners. In 99 they had a model called the "Highlander". Basically the sport edition, but before the designation. They are 1" taller than the other years.
    Part Numbers:
    Front right 48131-35400 L=368mm
    Front left 48131-35350 L=374mm
    Rears ( same for both ) 48231-35210
    Color Codes:
    Fronts: Blue/Pink & Blue/Yellow
    Rears: Green/Red
    These are a good alternative and will replace your worn out coils.
  9. May 24, 2012 at 9:17 PM
    musicmaan
    not enough
    awesome... thanx
  10. May 24, 2012 at 10:14 PM
    SCRunner12
    Robert
    Santa Cruz, CA
    No problem. Glad I could help and let me know if you have anymore questions.
  11. Jul 13, 2012 at 2:58 AM
    06ryan27
    06ryan27 Well-Known Member
    Aiken, SC
    12 DBL 4x4 SPORT
    3" RBP lift, anytime fogs
    I kinda enjoy my runner leveled out now, (guessing because of wore rear springs) is this gonna lift my rear higher then front now? I just bought an 02' for a grocery getter. trying to do a couple things to make myself like it. (The extra loud system I just installed didnt work)
  12. Jul 13, 2012 at 10:03 AM
    SCRunner12
    Robert
    Santa Cruz, CA
    If you put just the rear coils in you will have some rake. The 02's have the lowest stock height of all 3rd gens so depending on how your coils have sagged it may be more than 1" of rake. I would replace all 4 for a level aggressive stance. Congrats on the purchase. Since you have an automatic look into a transmission cooler or replacing the radiator otherwise you may be a victim of the "pink milkshake."
    Also check out this thread as it is a wealth of information. http://www.toyota-4runner.org/3rd-gen-t4rs/82033-3rd-gen-4runner-buyers-guide.html
  13. Jul 28, 2012 at 4:40 PM
    06ryan27
    Aiken, SC
    12 DBL 4x4 SPORT
    Cool deal man, that guide is the ticket for sure, got all kinds of ideas now
  14. Sep 5, 2012 at 2:24 PM
    Sixpack577
    Sixpack577 Member
    The 99' tall rear springs leveled my stock 01, and it has no rake at all.
    I then removed them and added spacers front and rear.
    The 1" front spacers gave me 1.5" of lift.
    The 2.5" rear spacers gave me 2.5" of lift(with stock springs).
    No rake at all with spacers, and a small subtle lift that actually makes getting in and out easier for me.
    I guess the factory spring wear/sag does come in to play on if your 4runner will end up level or not though.
