3rd Gen ('19 TRD 4x4 Off Road MT) Brake Bleeding Override Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GrandiOdyssey, May 16, 2019.
  1. May 19, 2019 at 6:13 PM
    GrandiOdyssey
    GrandiOdyssey [OP] Well-Known Member
    2019 Tacoma TRD 4x4 MT
    Lots coming soon...
    Noted well I will try this again the next time I have to bleed brakes and have someone else to help me.
  2. May 20, 2019 at 4:46 AM
    sakibomb
    sakibomb Well-Known Member
    Kevin
    DFW Texas
    2016 TRDOR DCSB 6MT
    Dual Batteries Blue Sea Fuse Panel
    Ok, I figured you still tried to use the bleeder pump.
    For a one person job, cut a 2x4 and place between the brake pedal and seat bracket. Slide the seat forward to depress and hold the brake pedal then key on and open the bleeder. I didn't try this but in theory it should work :fingerscrossed:
    You CAN bleed the brake lines without an OBDII scanner.
  3. May 20, 2019 at 8:22 AM
    GrandiOdyssey
    Lots coming soon...
    Now I'm m really confused.... accordingly to the shop manual (Step 4) the master cylinder needs to be bled if a brake line gets disconnected and this requires a Techstream or OBDII scanner. Am I mistaken? Either way I plan on getting a bluetooth OBDII scanner since I will be going through remote areas, far away from a Toyota dealer.
  4. May 20, 2019 at 10:06 AM
    sakibomb
    Kevin
    DFW Texas
    2016 TRDOR DCSB 6MT
    Good question. It says "If the brake line is disconnected from the brake master cylinder"
  5. Jun 27, 2024 at 6:33 PM
    Jocab36
    Jocab36 Member
    Mr. Pickles
    2019 Tacoma TRD Off-Road
    Just did my brake lines all the way around on my 2019 OffRoad. You can bleed without a scan tool. Just have to use a specific sequence with the start button to have the brakes basically bleed themselves through the electronic controlled brake cylinder. It’s in a thread on here somewhere. I did it with the intention of if it doesn’t work I’ll use my AAA but it worked great!
  6. Jul 24, 2024 at 7:19 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I'm getting ready to do mine. I read through what @splitbolt posted in the earlier thread. What order did you do for the wheels? Just based on length of lines (longest to shortest), I think it's:
    • Passenger Rear
    • Driver Rear
    • Passenger Front
    • Driver Front
    Wanted to check what you did though and how much fluid you went through. I have Techstream just in case but doesn't sound like I'll need to use it. I have done plenty of brake bleeds on cars with regular boosters so plan is to not screw up this one.
  7. Jul 24, 2024 at 7:22 AM
    Jocab36
    Jocab36 Member
    Mr. Pickles
    Your order is correct. I went through almost 2 full large bottles of fluid. But I did a little extra for a little more of a flush.
    Smacky2020[QUOTED] likes this.
  8. Jul 24, 2024 at 7:30 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Yep, two quarts just barely does it.
    If you waste even a little bit, you'll come up short with only two bottles.
  9. Jul 25, 2024 at 10:05 AM
    Smacky2020
    Bristol, VA
    Holy cow. 3-32oz bottles (or at least 2x32oz + 1x16oz) it is. Getting ready to do mine this weekend. Still reading a lot of conflicting posts on here regarding bleeding on OR/Pro so I'll start with just the line bleed procedure and do Techstream step if needed. Gives me a chance to adjust the rear drums too.
    jmneill[QUOTED] likes this.
  10. Aug 4, 2024 at 5:41 PM
    Jocab36
    Jocab36 Member
    Mr. Pickles
    Rear drums self adjust if you don’t feel like adjusting. Just pump that hand brake approximately 1 billion times.
    Stuck in VT likes this.
  11. Mar 17, 2025 at 1:38 PM
    remysenpai
    remysenpai Member
    Remy
    2018 Tacoma TRD Pro
    After so much research I finally have found someone who has tried this method. I am going to do my brake flush on my TRD pro and dont have a scan tool. glad to see this method has work @Jocab36 has anyone else did their brake flush without a scan tool?
