3rd gen 2.7L auto - regear needed for 235/85R16?
Discussion in 'Wheels & Tires' started by TacoDell60, Nov 25, 2024.
  1. Nov 25, 2024 at 9:25 AM
    TacoDell60
    TacoDell60 [OP] Well-Known Member
    Good day everyone,
    Long time lurker.
    Joined up to ask a rather specific question regarding the 3rd gen 2.7L auto and gearing/tire diameter:
    My truck has stock 245/75R16 tires on stock SR5 wheels and suspension.
    I'd love to go up a size in diameter while sticking with "skinny" tires. 235/85R16 seem to be the "sweet spot" in diameter/width; stock 245/75 is 30.5" tall vs 235/85 is 31.7" tall
    My question is, will the RPM's, speedometer difference and overall drivability be affected enough to need a re-gear to run the 235/85R16 tires?
    I would probably run them on a sub-20lbs 16in wheel like Koenig Countersteers etc, not the stock SR5 25lbs mags, to offset the added weight of the E rated 235s.
    My current setup weighs 60lbs per corner (245/75 Toyo OpenCountry SL load ATIII on 16in SR5 mags)
    The setup I'm looking at would weigh 63.6lbs per corner (235/85 Toyo OpenCountry ATIII E load on 16in Countersteer wheels).
    Thanks in advance and I apologize if this is a dumb question.
  2. Feb 1, 2025 at 10:40 AM
    TacoDell60
    @Nyrob any thoughts regarding gearing?
    Would a 235/85R16 rub at all on stock suspension height settings and a +10 to 0 offset wheel?
  3. Feb 1, 2025 at 6:07 PM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    No need for a regear. I have 2.7 3rd gen and I'm running a 255/75/17 which is a 32.1" tire and theres no issues with rubbing or gearing issues.
