3rd gen 285/75r16 fitment question
Discussion in 'Wheels & Tires' started by mgc3333, Apr 3, 2024.
  1. Apr 3, 2024 at 11:50 AM
    mgc3333
    mgc3333 [OP] Member
    2019 trd offroad, OME 2” lift. I am running stock wheels which I believe are 25mm offset. I have KO2 285/75r16s.
    Issue: tire tubs on UCA
    I was wondering if I put on some spidertrax 1.25” spacers to push it out from the UCA will lead to rubbing else where in the wheel well. If anyone has a similar setup please chime in. Thanks
  2. Apr 3, 2024 at 4:16 PM
    Slow_sr20
    Slow_sr20 Well-Known Member
    23’ DCSB O/R
    mgc3333[OP] likes this.
  3. Apr 3, 2024 at 4:28 PM
    VikingForge
    VikingForge Well-Known Member
    First Gen
    Safer to trim a fender or wheel well than grind down a spindle or UCA. Bump the tire out, either with the spacers or a different wheel and deal with the less critical rub points when they arise.
  4. Apr 3, 2024 at 5:59 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    This UCA rub issue for this size tire has been published.
    +15 offset will clear factory UCA. You can order a 10" spacer from BORA.
    But it just barely clears the front plastic and back cab mount, depending where alignment is set.
    Barely clears works on street driving, not offroad with full stuffs. Choice is yours to get a CMC or not.
  5. Apr 3, 2024 at 6:01 PM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
