3rd Gen/ 2nd Gen Engine bay Splash Guard/ Rock guards Template.
Discussion in 'Off-Roading & Trails' started by Shveet, Jul 28, 2019.
  1. Jul 27, 2020 at 7:30 AM
    #41
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    All.stock clips. They fit loose but hold.for now.
    Shveet[QUOTED][OP] likes this.
  2. Sep 27, 2020 at 10:27 AM
    #42
    TreeCop
    TreeCop New Member
    Tony
    2007 Silver Tacoma 2wd
    Oh. This is for 4x4 only right? A part of the rubber is cut out to accommodate a piece of the suspension that is mounted higher on 4x4 than the rwd model. Rats.
  3. Sep 27, 2020 at 10:49 AM
    #43
    Shveet
    Shveet [OP] joe-shmo
    Own-tario
    2018 shitbox
    you can modify the template in any way you'd like. to my understanding this fits the 4x4 model, but if you print out the template onto paper and see where you're missing material, it's easy enough to add tape or something to create a new template.
    The most important part is the location of the mounting holes. if those line up - you can shape the template in any way you'd like/ fits your needs
  4. Sep 27, 2020 at 2:10 PM
    #44
    TreeCop
    TreeCop New Member
    Tony
    I should have done this, instead I taught myself a lesson about "measure twice cut once" and had eagerly cut the rubber all too early, just spend the last three hours cutting and shaping cardboard and made a new template, will do photos when it's done.
  5. Oct 5, 2020 at 12:14 PM
    #45
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Finally installed my DYI splash guards.
    Material:
    Rubber mat: $15 at Home Depot (link)
    Push Pins: $20 on Amazon. (link)​
    I added a little bit more material by the front hole. You can see in one picture below that the pin is right on the edge. The template provided was a great start and much help but there might be some slight alterations needed. Thanks for the template!
    I drilled the holes out slightly to better fit the new plugs.
    I printed the template on 6 11x17 papers. I cropped the template and I used the "poster" option with "cut marks" option to line everything up perfectly. I attached the 6 page (11x17 paper) document with the cut marks. Make sure you print to "actual size". Also attached the cropped PDF of the template.
    Also repainted the frame in the front around the suspension. More rust removal!
  6. Oct 22, 2020 at 3:48 PM
    #46
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    Does anyone have any other links for a different mat? Ive looked at my home depots and Amazon and cant really find an equivalent for the same price.
    Shveet[OP] likes this.
  7. Oct 22, 2020 at 3:54 PM
    #47
    Clwrz
    San Diego, CA
    Shveet[OP] and llamasmurf like this.
  8. Oct 22, 2020 at 4:11 PM
    #48
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    So what changes would i need to make to the template for a 2wd 2nd gen?
    Shveet[OP] and dpele like this.
  9. Oct 23, 2020 at 10:30 AM
    #49
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    No idea. Print out the template and find out... :thumbsup:
  10. Nov 1, 2020 at 7:59 PM
    #50
    Clwrz
    San Diego, CA
    ca08tacoma, dpele, Shveet[OP] and 2 others like this.
  11. Nov 2, 2020 at 6:21 AM
    #51
    Shveet
    Own-tario
    2018 shitbox
    Woah, this is too good of a install video
    :bowdown:
    but at 1:40 which holes is the template missing? Just the top front on the driver side?
    I've not been able to verify the template 100% for the second gens but it seems to fit almost perfectly in there other than the missing mounting locations
    also added your description links for the materials if you don't mind :fistbump:
  12. Nov 2, 2020 at 6:25 AM
    #52
    Windigo
    Farook
    '14 Acess Cab
  13. Nov 2, 2020 at 6:53 AM
    #53
    Shveet
    Own-tario
    2018 shitbox
    seen that you figured that one out, somehow didn't see the notification for the thread...
    updated the first page to include your links and video!
    I don't believe there is a difference between the 4wd and 2wd - but i cannot say that for certain that it's the same.
    if you give it an hour, you can print out the template and take a quick look for yourself to see if things line up. Give us a heads up if you try it, i'd like to add in a disclaimer on the first post if there is a difference between the two
    Added to the first post, thanks bud!
    Also to everyone else, thanks for the help with links to materials, the clips, photos, and videos. It's pretty awesome to see the guide getting the traction it got:fistbump:
    DanaPtTaco[QUOTED] likes this.
  14. Nov 2, 2020 at 7:00 AM
    #54
    Shveet
    Own-tario
    2018 shitbox
    I've gone and updated the guide #1 and template printing #2 posts on the first page to try and re-organize it to appear a bit more coherent.
    revised it all to have the links talked about in the thread to allow people to easily find the materials used and it shows what to do with a body lift on your truck as this does change the templates design.
    IF THERE IS ANYTHING MISSING, PLEASE LET ME KNOW.
    this includes and is not limited to;
    Is the 2x4 version of the Tacoma (2nd and 3rd gen) the same as the 4X4 versions?
    dpele likes this.
  15. Nov 2, 2020 at 10:46 AM
    #55
    Clwrz
    San Diego, CA
    thank you! Yeah there was just a few holes on the top nothing too difficult to figure out after the template was put together. I also added a few more inches of material to the front where it changes from 2nd to 3rd gens. this link however is the first one i ordered and realized that it was 3in by 8ft not 3ft by 8ft like i thought Rubber Sheet Warehouse .125" (1/8") Thick x 3" Wide x 10' Feet -Neoprene Solid Rubber Strip NOT for Cosmetic Purposes Perfect for Weather Stripping, Gasket, Costume & DIY Projects so I got the other one i linked in the video instead
  16. Nov 2, 2020 at 11:50 AM
    #56
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    So I am having issues printing the template. I do not have adobe to print the "Poster" way. And when I did print it it seemed to scale down about 25% so I am missing a lot of the lines and holes. Anyone else have this issue? Also I am not that tech savvy.
  17. Nov 2, 2020 at 11:54 AM
    #57
    Clwrz
    San Diego, CA
    https://get2.adobe.com/reader/ download this guy and you can do the poster option
  18. Nov 2, 2020 at 12:25 PM
    #58
    Northbound_Taco
    09 Off road build
    Nice thank you that worked. I have a couple sheets that have the smallest of lines on it but Ill make it work.
    Shveet[OP] and Clwrz[QUOTED] like this.
  19. Nov 2, 2020 at 7:09 PM
    #59
    Woodylz
    Woodylz Well-Known Member
    Portland, OR
    2020 Silver Sky OR AC
    ask my wallet about my modifications...
  20. Nov 2, 2020 at 7:47 PM
    #60
    Shveet
    Own-tario
    2018 shitbox
