3rd Gen/ 2nd Gen Engine bay Splash Guard/ Rock guards Template.
Discussion in 'Off-Roading & Trails' started by Shveet, Jul 28, 2019.
  1. Feb 27, 2023 at 9:59 AM
    #101
    Bocotacointhewild
    Bocotacointhewild Often wrong, never in doubt
    Connor
    West coast best coast
    2010 ECLB SR5 5MT 223K
    265/75 KO2s, ome 2” rear, rear seat delete, ECGS bushing, sleeping platform, weatherproofing, blacked out tailights, head gasket only has 5k on it, dual battery, water tank, interior LED's and a pop n lock
    Did these last friday. Definitely had to make some adjustments for my second gen from the template but overall it was a big help. Printed poster mode, taped and cut the pieces together and then cut cardboard halves. Definitely took some guesswork, evidenced by multiple holes for some of the clips. Used the versatex mat, industrial 40x60. For clips I got a set from Amazon of multiple sizes, ended up using ones smaller than 9mm. 7.1 and 6.8 I believe. Not sure how that works.
    gabbo2112, srspicer, dpele and 2 others like this.
  2. Jun 18, 2023 at 8:52 AM
    #102
    Shveet
    Shveet [OP] joe-shmo
    Own-tario
    2018 shitbox
    took off the splash guards working on the truck, few days later figure to go out with a few buddies on some trails.
    never place them back in as i ran out of clips since the old ones of 3 (actually 4 years, wtf i've had these for this long?) years all broke
    this was my engine bay after a few hours on the trail and through some muddy water crossings
    :annoyed:
    need new clips now
    gabbo2112 and dpele like this.
  3. Dec 12, 2023 at 10:15 AM
    #103
    NCCarlsbad
    NCCarlsbad Member
    2008 Regular Cab 4x2
    Thanks so much for this!!!! It worked out perfectly. Will post some pics in the next few weeks!
  4. Dec 17, 2023 at 3:11 PM
    #104
    NCCarlsbad
    NCCarlsbad Member
    Finished up the splash guards today. Thanks again for the templates!! All worked out well. I had to make some minor adjustments as it seems the templates were for 4wd trucks, and my son's truck is just a 2008 2wd base model standard cab. Here are a few tips I learned:
    1. Put the template on the the truck and use all the old broken fasteners to hold up the template. They are most likely broken anyway, but they hold up the paper and allow you to place the holes properly.
    2. I did the passenger side first and used the cut out to make the driver's side. However two holes didn't match the passenger side and I ended up with an extra hole. No big deal.
    3. When I put the paper template up, I then added tape to areas that need more coverage and cut areas that needed to be adjusted.
    4. After I cut the rubber mat, I put it on the truck and used the old fasteners. This allowed me to make final adjustment such as making room for brake lines.
    All in all, it was a fun project that saved me a bunch of money and was satisfying to do it myself- of course with the great assistance of the template makers!!IMG_7076.HEIC.jpgIMG_7078.HEIC.jpgIMG_7079.HEIC.jpgIMG_7080.HEIC.jpgIMG_7082.HEIC.jpgIMG_7083.HEIC.jpgIMG_7085.HEIC.jpgIMG_7086.HEIC.jpgIMG_7076.HEIC.jpg IMG_7078.HEIC.jpg IMG_7079.HEIC.jpg IMG_7079.HEIC.jpg IMG_7080.HEIC.jpg
    TacoManOne, gabbo2112 and SR-71A like this.
  5. Dec 22, 2023 at 1:00 PM
    #105
    EGBTER
    EGBTER Well-Known Member
    Wayne
    Denver CO
    2016 TRD SPORT
    Thanks for the info. Used the template to make some and uploaded a video showing the process!
  6. Jan 1, 2024 at 4:15 PM
    #106
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Nice work!
  7. Mar 22, 2024 at 11:12 AM
    #107
    BizzyBone
    BizzyBone Well-Known Member
    gabbo2112[QUOTED] likes this.
  8. Mar 22, 2024 at 12:08 PM
    #108
    BizzyBone
    Thanks for the PDF's. Do I need to trim the edges of the paper (so the line from the drawing on each page touches each other when taped together) or just print and align the paper end to end and tape together?
  9. Mar 23, 2024 at 5:11 PM
    #109
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    It’s still holding up pretty well, I’ll probably make a new set at some point just to get a slighter better fit. I’m not sure stuff rips easily but if you have a roll it wouldn’t cost you anything to try it out.
  10. Jul 21, 2024 at 1:23 PM
    #110
    Livefree1
    Livefree1 Member
    Greg
    2012 Tacoma
    Thanks for the template guys! It was a huge help. I modified it a bit but it saved me a ton of time by giving me a starting point.
    I wanted mine to be easily removable for maintenance purposes and I hate those stupid body clips, so I used m6 rivet nuts for all the holes and bolted them in. Just had to drill the holes a little bigger.
    I also split it in half and did 2 pieces per side. Main reason for this is I used plastic mud flaps for my material, and I could only get half out of one mud flap. Real heavy duty material, should never have to replace them.
    Just thought I’d throw out my mods, in case someone wants to do something similar. Rivet nuts aren’t used very often, but can be super useful in the right conditions.
    TacoManOne and gilligoon like this.
  11. Jul 24, 2024 at 3:10 PM
    #111
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Nice! I need to get RivNuts for some Moto repairs, so this is a great option/upgrade. Plus... I plan to keep my Gen3 until death... at which point it will be passed to a Scion (if you get my meaning...)
  12. Nov 15, 2024 at 7:38 PM
    #112
    ORcement
    ORcement Active Member
    Vince
    20 trd off road cement
    Used the template and here is my contribution. I am super happy with the results!!!
  13. Apr 7, 2025 at 8:00 AM
    #113
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Thanks again for everyone's contributions! I used the template pretty much blindly and it worked great. I used one 30x48 mat from Amazon to just barely fit both (don't mess up and make sure you have the side you want facing "out". Material is nice and strong and a bit more rigid than OEM but still very flexible and able to be cut with scissors or utility knife, and 9mm shell casings made perfect hole punches.
    https://www.amazon.com/dp/B07D38CPWW?ref=ppx_yo2ov_dt_b_fed_asin_title
    gabbo2112, Pigpen and stickyTaco like this.
  14. Apr 13, 2025 at 6:17 PM
    #114
    WILLX
    WILLX New Member
    First off solid work from the OP
    I worked with some cardboard templets for a min and your design was a solid starting point.
    I added the desert fab upper A arm supports because I needed a project and modded the original design to fit this.
    Wanted to add a metal splash guard because I have a problem and want to make things alittle different, other than that its just a personal preference.
    Used an aluminum flashing roll, and used the original design as a template.
    Then took another idea from another member (not being an ass just didnt scroll back up to see the name but we know who you are)
    And did the nutserts
    Made a support bracket (from a curtain rod hanger, dont judge me. For the rear part)
    IMG_9532.jpg IMG_9533.jpg IMG_9534.jpg IMG_9536.jpg IMG_9537.jpg IMG_9538.jpg
    essjay, sawbladeduller and llamasmurf like this.
  15. May 1, 2025 at 2:24 PM
    #115
    th3clara
    th3clara Well-Known Member
    Trevor
    Portland, OR
    2020 TRD Pro - Army Green
    RIDE Shocks 285/75r17
    Thanks for the template OP. I have access to a plotter table and was able to cut the 3mm versatex rubber in 4 passes. Took about 5 minutes. Excited to put these on the truck.
    Partial cut through after 2 passes
    Final result
    essjay, llamasmurf, gabbo2112 and 2 others like this.
  16. May 12, 2025 at 1:33 PM
    #116
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Very nice, way easier than scissors
  17. Jun 2, 2025 at 12:27 PM
    #117
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    How are these working out for you?
  18. Jun 2, 2025 at 12:29 PM
    #118
    GRNT4R
    NC - Triad
    TBD
    anyone interested in making a set for a 2nd Gen and shipping, id paypal for materials and time
  19. Jun 4, 2025 at 10:20 AM
    #119
    th3clara
    Trevor
    Portland, OR
    I've only done the passenger side so far but I really like the look and I'm confident it will keep a lot of mud out of the engine bay compared to the stock splash guards. Here is a comparison of the stock guards, lots more coverage, especially at the top of the wheel well.
    I had the holes from the CAD file plotted out on paper, but almost every hole was slightly off from where I ended up placing them. My method was to place the paper stencil where I wanted it, used a small screw driver to locate the hole, punched through the paper, then secured with the plastic clips. Once all holes were established in the paper, I laid that on top of the cut rubber and drilled each hole to match the stencil.
  20. Jun 4, 2025 at 12:21 PM
    #120
    GRNT4R
    NC - Triad
    TBD
    They def look good. I ended up
    Ordering a set from Rad Rubber Design so I hope to see them soon. I’ll post pics back here incase anyone else is interested
    https://radrubberdesign.com/product/tacoma-2nd-3rd-gen-2005-2017/
