3rd gen 3.4 coolant leak
Discussion in '4Runners' started by Paul123, May 16, 2017.
  1. May 16, 2017 at 10:17 AM
    Paul123
    Paul123 [OP] Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I need help figuring out a coolant leak. It's a 3.4 jdm engine I swapped a few months ago. I changed the water pump and timing belt in the process, the old water pump looked good and dry but I put a new one in anyways. The leak is Above the water pump and wraps around the side of the engine, to above the oil filter. Sometimes it leaks pretty bad and sometimes it doesn't leak at all. Coolant drips down onto the front crossmember and then onto the ground, usually when parked downhill. Thanks for any help
  2. May 16, 2017 at 5:39 PM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Any relation to this thread?
  3. May 16, 2017 at 5:40 PM
    Paul123
    Paul
    Reno
    Yeah that's my girlfriends account on t4r. (It's her 4Runner) I just fix it.
  4. May 18, 2017 at 10:08 PM
    mark52cents
    mark52cents Well-Known Member
    How high above the pump?
  5. May 18, 2017 at 10:35 PM
    Paul123
    Paul
    Reno
    I actually found it today. It was the coolant line that connects to the throttle body. It would leak onto the intake manifold and down the front of the engine, making it difficult to find.
