3rd gen 3.5L 6 speed manual owners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Astonebrook91, May 16, 2020.
  1. May 17, 2020 at 7:42 AM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Yep. Its a mid-sized, Japanese V6 with wide variable valve timing and direct injection making peak torque at 4600, peak hp at 6000. Let it rev, they're made for it!
    Fun fact: the silverado mentioned above made 335 lb-ft at 4000rpm, 295 hp at 5200rpm... the proverbial low rpm power v8 had to be wound tight to actually put that power out too. It felt unnatural.
  2. May 17, 2020 at 8:51 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yep, my work van (gmc express) with the 4.8 vortec, operates at about 200 rpm lower with normal driving on the same roads. Dont understand peoples complain with this 3.5 engine. Unless you have a big diesel, most engines need to be wound up to get into the powerband. I think its a fantastic engine, good power when needed, but good on gas when driving conservatively.
  3. May 17, 2020 at 8:56 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’ve driven more powerful vehicles and stuff faster off the line, but I’ve never once felt like I needed more power than I could get out of this engine
  4. May 17, 2020 at 9:01 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Having put right at a million miles on 2 first gen tacomas, now i own a 2020, i will say that it is not better nor worse than the first gens. But i will say it is different, to me you have to rev it a little higher to get the same smooth shifts. I notice it more between 2-3 than 1-2....
    ActionHank and su.b.rat like this.
  5. May 17, 2020 at 9:11 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I never drove 1st gen MT but i shift 2-3 at pretty low rpms sometimes, and its always buttery smooth. Goes for all the other gears, no need to rev it high to get smooth shifts like a lot of others are complaining about. Maybe i just got lucky with my tranny? Haha
    shakerhood likes this.
  6. May 17, 2020 at 9:16 AM
    smithlaketaco
    Houston, Al
    high to me is 2500-2700. low-high is relative depending on the person i assume
    Junkhead likes this.
  7. May 17, 2020 at 9:27 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    1-2 i usually shift at 3000
    2-3 around 2500
    3-4 around 2200
    4-6 around 2000
    I barely use the 5th gear. Ill go for a drive later on today and will double check the rpms.
    shakerhood and Astonebrook91[OP] like this.
  8. May 17, 2020 at 9:29 AM
    Astonebrook91
    Astonebrook91 [OP] Member
    Andrew
    Buffalo, NY
    2019 Black TRD Sport Access 6MT 4X4
    None yet
    Thats exactly how I shift, but 1-2 I slip the clutch a bit more so I don't hear that noticable clunk if I just let off the clutch like normal
    Junkhead[QUOTED] likes this.
  9. May 17, 2020 at 9:31 AM
    smithlaketaco
    Houston, Al
    If you been driving manuals as long as i have, you really dont know the rpm's you shift at its all about sound. That maybe another reason the 2020 shifts different, because i am not use to the sound. After 450,000 miles in my 02 on the original clutch I think it just shifts itself
  10. May 17, 2020 at 9:33 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    If im in traffic and need to get moving fast, since people are in a rush here, i will bring up the first gear to 3500. Otherwise some people in the back freak out when doing that 1-2 shift at lower rpms.
  11. May 17, 2020 at 9:35 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I barely look at the tach when i drive, thats why i said i will go for a ride and double check.
    My first vehicle was 1990 mazda b2200 5 spd, had no tach. Was very fun to drive. Miss that truck man...:pout:
  12. May 17, 2020 at 9:39 AM
    smithlaketaco
    Houston, Al
    My first vehicle was a 53 Chevy pickup and do i dont miss 3 on the tree. The GF mentioned my new 20 shift from 2-3 when she drove it, and yes her DD is a manual so she knows how to drive one.
  13. May 17, 2020 at 9:41 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I think it just needs to be broken in. My tranny loosened up a bit after few thousand KM. A lot of other members reported similar thing.
  14. May 17, 2020 at 9:48 AM
    ruskiMishka
    ruskiMishka Member
    After driving sport cars with short shifters and lightweight clutches, this is the softest and easiest MT ive ever shifted
    shakerhood, su.b.rat and Junkhead like this.
  15. May 17, 2020 at 9:52 AM
    #35
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Russian bear?
  16. May 17, 2020 at 10:00 AM
    #36
    ruskiMishka
    ruskiMishka Member
    lol indeed
  17. May 17, 2020 at 10:01 AM
    #37
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha! Zdarova bratan.
  18. May 17, 2020 at 10:02 AM
    #38
    ruskiMishka
    ruskiMishka Member
    Ayyy the ruski taco club
  19. May 17, 2020 at 10:03 AM
    #39
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep :rofl:
  20. May 17, 2020 at 10:04 AM
    #40
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    You can't be slow on the 1-2 shift. If you get it from 1 to 2 quickly, the rpms will not drop below where you need to be when letting the clutch back out.
