3rd Gen. 4 cyl pulling camper question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newtacoma19, Oct 6, 2023.
  1. Oct 7, 2023 at 10:36 AM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    I’ve always responsibly towed, so therefore I’ve never experienced being pushed through intersections.
  2. Oct 10, 2023 at 8:07 AM
    Newtacoma19
    Newtacoma19 [OP] Well-Known Member
    SSM utility 19
    If I were to get a trailer as such and add brakes to said trailer.. what could I expect to reasonable pay to have them installed? Is that something a RV/trailer dealership might include with a haggled trailer purchase or a local garage? Would I need a brake controller added to the tacoma cable as well? I live in central Florida. Wouldn’t wanna be be price gouged.
  3. Oct 10, 2023 at 8:13 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    i would think that the travel trailer would come through with brakes already installed. especially at 2800 pounds. brake controller for the truck is a simple plug and play. it will trigger the trailer brakes through the factory 7 pin connector if you have one.
    Chew likes this.
  4. Oct 10, 2023 at 9:39 AM
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    Weird. My camper is around 3500 loaded and my truck never “struggles” with it at all. It tows it great.
  5. Oct 10, 2023 at 9:46 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    remember we are comparing results, but everyone has different environments and expectations.
  6. Oct 10, 2023 at 9:46 AM
    Da Voke
    Canada
    Totally agree. There’s a ton of bs here about towing. So much comes down to driving skill.
  7. Oct 10, 2023 at 11:09 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    It’s the internet- OP asks for opinions, he/she got them, some of them firsthand experience. Having a different opinion is not fear mongering. Most, if not all, didn’t say it couldn’t be done, they gave differing levels of not ideal.
    Again, everyone has different environments, expectations, and an infinite amount of other variables.
    RustyGreen likes this.
  8. Oct 10, 2023 at 11:11 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    In the end, one could simply test drive and form their own conclusion.
  9. Oct 10, 2023 at 11:27 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    When we head north, out of phoenix, up the 17, we run into pretty long steep grades. Engine strains on these stretches.
    On flat straight away stretches it's a piece of cake.
  10. Oct 10, 2023 at 11:28 AM
    abodyjoe
    joe
    i don't know of any(maybe there is one out there,who knows) dealerships they will set up a WDH, allow you to hook up to one of their new/used trailers and take it for a test drive.
  11. Oct 10, 2023 at 11:51 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    A regear can help both with acceleration and maintaining a higher gear but it’s not a cure for less power, it just gives the power you have a bit more leverage to get going and traverse the gear range. The penalty is increased revs at any speed.
    Every Tacoma model is set up differently for wheel/tire size and power output/mileage. If you need to make an adjustment a regear is one place to do it. Almost automatic when people go up in tire sizes which is also a leverage issue.
    You’ll also need to deal with tongue weight either by using a wd hitch, helper springs, sumo springs, air bags or you’ll be bouncing off your bump stops. Trailer load balancing can help with this but when the weight comes down on the rear end stock leaves are inadequate. If it’s a working truck you’re probably already aware of this. Personally I’d combine wd hitch with sumos as the best/safest/inexpensive bang/buck combo for a work truck that also tows. I use air bags and appreciate the flexibility but my install was more complicated than most(ie works for me but not everyone’s cup ‘o tea).
  12. Oct 10, 2023 at 12:04 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Can't imagine any dealer letting you test tow with a new vehicle.
  13. Oct 10, 2023 at 12:25 PM
    abodyjoe
    joe
    if you need those bandaids you really need the proper truck to begin with.
  14. Oct 10, 2023 at 12:46 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Sometimes that’s true and sometimes that “proper” truck still isn’t set up the way you want and mods are still called for. It’s up to the individual to make that call based on their circumstances. These are basic common sense mods to dial in a truck to specific applications not turning a Yugo into a Ferrari.
  15. Oct 10, 2023 at 1:35 PM
    #35
    Chew
    Chewy
    Midwest
    19 TRD OR
    You can always rent or ask a used seller, if you like it, buy it.
    I’m not saying it’s as easy as test driving a new vehicle, but damn, just to accept it’s a couple more steps, and buying the unknown. Seems worth it to me anyway.
  16. Oct 10, 2023 at 1:56 PM
    #36
    Da Voke
    Canada
    What does “strains” mean? When I encounter a long steep grade it gears down to 3rd occasionally and the rpm’s climb but the motor isn’t under any kind of stress at all. When the rpm’s are up its cooling is running at maximum, oiling is at its maximum and the torque converter is locked. The key indicator of any motor under stress is the temperature. If it’s operating temperature isn’t climbing it’s not straining. It’s louder because it’s working harder but it’s not hurting it.
  17. Oct 10, 2023 at 2:27 PM
    #37
    abodyjoe
    joe
    sure you can ask, i sure wouldn't let someone hook up to my used trailer and test drive it.. not sure how many would. doubt there are many if any dealers that would allow it either.
  18. Oct 10, 2023 at 2:30 PM
    #38
    abodyjoe
    joe
    ummm, thats is basically tryining to make a tacoma a good tow vehicle.. tacoma is what it is.. good little truck thats good for running to the hardware store for a few things, towing a atv or something similar, its kinda light dudy jeep wrangler like. its just not a great tow vehicle.. notthng wrong wth that.
    ScrippsRanch67 likes this.
  19. Oct 10, 2023 at 3:09 PM
    #39
    2021SR5V64WD
    I mean I have to kick it up a notch or two... push the RPM's into the 4k range, I thought the V6 ( compared to the wife's 4cyl subaru )
    would have more power to maintain speed.
  20. Oct 10, 2023 at 3:13 PM
    #40
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    A lightweight popup might be your best bet. Tow capacities as shown are a joke sorry to say.
