3rd Gen 4R E-Locker in a 2018 Sr5 4x4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreyBaldTaco, Jun 27, 2019.
  1. Jun 27, 2019 at 7:16 AM
    GreyBaldTaco
    GreyBaldTaco [OP] Well-Known Member
    2019 F150 5.0
    I found a fairly reasonable e-locker out of a 3rd Gen 4 Runner. Is this a plug and play solution to add an elocker to my truck? Is there anything I would need to do to make this work?
  2. Jun 27, 2019 at 7:21 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    The short answer is no
    Snaeper likes this.
  3. Jun 27, 2019 at 7:24 AM
    GreyBaldTaco
    2019 F150 5.0
    Damnit, can you expand on that at all?
  4. Jun 27, 2019 at 7:27 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    http://sonoransteel.com/phong/retrofit_electric_locker.html
    There is quite a bit that has to be done to the housing to swap in an elocker. It can be done on the SR5 axle as it is a traditional 8” housing. Swapping in a Detroit or a Yukon Grizzly locker would be my choice if I had an 8”.
    GreyBaldTaco[OP] likes this.
  5. Jun 27, 2019 at 7:31 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You could get an ARB rear air locker with compressor and have onboard air, as well. (Limit arb lockers to 105 psi)
    Drunken Chewbacca likes this.
  6. Jun 27, 2019 at 7:33 AM
    GreyBaldTaco
    2019 F150 5.0
    I've thought about that, but this would be less than half the price of the arb unit alone, if it worked.
  7. Jun 27, 2019 at 7:36 AM
    Grossomotto
    2017 4WDV6LB6MT
    If it works great, but keep in mind there’s more to it like the ECU involved.
    The great thing about air lockers is you have the tank always pressurized so it’s instantly locked with the push of the button. Plus you can run air tools and fill tires.
    There’s another thread of a member trying to put an elocker in his SR, he couldn’t get it to work.
  8. Jun 27, 2019 at 7:36 AM
    GreyBaldTaco
    2019 F150 5.0
    Damn thanks man.
    Mods feel free to lock or delete this as it seems I started a useless thread.
  9. Jun 27, 2019 at 7:37 AM
    Grossomotto
    2017 4WDV6LB6MT
    I’d say this is better than 95% of the threads here.
  10. Jun 27, 2019 at 7:38 AM
    GreyBaldTaco
    2019 F150 5.0
    Thankfully I haven't needed a locker yet, but it'd be nice to have. This is my first taco and I've been very impressed so far with just tossing some tires on it.
  11. Jun 27, 2019 at 7:39 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Agreed!!!
  12. Jun 27, 2019 at 7:39 AM
    Grossomotto
    2017 4WDV6LB6MT
    The cheaper way is better tires and some recovery gear.
  13. Jun 27, 2019 at 8:57 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    @traumahawk got the e-locker functional as far as I know, I don't know if anybody else tried and failed.
    https://www.tacomaworld.com/threads/2017-e-locker.585669/page-5#post-20380348
    The final take-away for the 3rd gen Tacoma e-locker is that it doesnt appear too bad to manually activate it (separately from the 4wd ECU). However you won't do any good dealing with the 4wd ECU, you have to manually control it and provide feedback lights if desired. During development, Traumahawk was running with a resistor and flyback diode to make the install as close to the Toyota 3rd gen electrical properties as possible, easily. As far as I know that worked fine, no issues reported.
    NOTE, I don't know anything about the electrical properties of the 3rd Gen 4 Runner, which may or may not be electrically similar to the 3rd Gen Tacoma.
    NOTE, I don't know anything about the physical installation of the e-locker into your existing housing.
  14. Jun 27, 2019 at 9:49 AM
    GreyBaldTaco
    2019 F150 5.0
    Thanks for the info.
  15. Jun 27, 2019 at 9:54 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Seriously. It's about trucks and not about fitting 33s.
  16. Jun 27, 2019 at 9:57 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    If it fits you would be far better served if you could activate it manually. Then you’d be able to use it in 2wd and most likely not even need to engage 4wd.
    The best mod I ever did on my old pathfinder was putting in a lock-right drop in locker.
    It made a huge difference in what the truck could do.
    Also manual hubs which save wear and tear and allow you to use 2wd low.
    If you haven’t bought the e locker yet I’d look into a mechanical one. I had no driving issues after figuring out what to avoid doing.
  17. Jun 27, 2019 at 9:58 AM
    Pilsner
    18 TRDOR
    I thought it was more complicated than providing voltage. If so, it gives me a few ideas about locker anytime mod that I may research and post in that thread.
  18. Jun 27, 2019 at 9:59 AM
    GreyBaldTaco
    2019 F150 5.0
    I would like to go that route but I question my skills on making that work and not screwing up my DD. Maybe ARB while more expensive would be the better option in this scenario, for me.
  19. Jun 27, 2019 at 10:05 AM
    eon_blue
    Azusa, CA
    I wouldn't put an auto locker in a nearly brand new vehicle lol. Auto lockers work great when you need them to do what they are designed to do, but they can be very unpredictable on the street especially in bad weather.
    I had the same one (Lockrite) in my 99 Prerunner, made it much more capable on the trails but it's street manners got real squirrelly, particularly in the rain. Any tire slippage at all and that sucker locks up and can make your otherwise uneventful day an eventful one.
  20. Jun 27, 2019 at 10:05 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Are you questioning the install or the wiring? You can always have a shop install it and the wiring shouldn’t be too complicated (if you opted to run it to a switch) instead of the computer.
    The lock right was super easy to install. The ARB is more involved and you’ll need a compressor, ox lockers make cable operated ones.
    I’m not sure what’s available for the 3g tacos.
