3rd gen 4Runner front diff in a 1st gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lshaw97, Jun 1, 2024.
  1. Jun 1, 2024 at 1:00 PM
    Lshaw97
    Lshaw97 [OP] Member
    My rear end has a 8” 4:30 diff and the 4runner diff I have has a 7.5” 4:30 diff. Does the difference in ring gear matter here?
    Will my 4x4 work and not nuke the transfer case with the two different ring gear sizes?
    thanks!
  2. Jun 1, 2024 at 1:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Front diffs are the same between the 4R and Taco.
    tcBob likes this.
  3. Jun 1, 2024 at 1:57 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    As Kwikvette said, the front diffs are the same--all 1st gen Tacoma and 3rd gen 4runner front diffs have a 7.5" ring gear. Only the ratio (4.30:1 in your case) matters when pairing front and rear diffs.
    Apart from ratio, you also need to pay attention to the passenger-side extension tube. There are three variants: straight (for manual hubs), vacuum-actuated automatic differential disconnect (ADD), and electronic-actuated ADD. A 4runner diff will have one of the ADD types. Which one you need depends on the truck you're putting it in to. The tubes can be swapped between diffs fairly easily if needed.
    tcBob likes this.
