3rd Gen 4Runner - Linked FJ80
Discussion in 'Solid Axle Suspension' started by smacaulay, Mar 16, 2022.
  1. Jun 29, 2022 at 1:37 PM
    #61
    smacaulay
    smacaulay [OP] Well-Known Member
  2. Jun 29, 2022 at 1:59 PM
    #62
    02hilux
    Planet: EARTH
    You're using the 3.0 case, forgot about the 80 axle
  3. Jun 29, 2022 at 2:04 PM
    #63
    smacaulay
    All good, i'll figure something out using a factory mount.
  4. Jul 1, 2022 at 9:03 AM
    #64
    98rock runner
    98rock runner Member
    Nick
    1998 4runner
    4wu solid axle swap
    I cut up a Tacoma Trailgear dual case mount and welded it to 4WU link brackets.
  5. Jul 1, 2022 at 12:56 PM
    #65
    smacaulay
    Cool idea, i like it.
  6. Jul 2, 2022 at 3:28 AM
    #66
    02hilux
    Planet: EARTH
    I thought about integrating the free TG crossmember I got from a buddy to accommodate the 4wu brackets like yours but my front shaft sits too far back and will bind. End up turning it into a skid plate instead. I still need to somehow built a frame brace to support the skid and turn it into a full case skid somehow.
    smacaulay[OP] likes this.
  7. Jul 2, 2022 at 7:31 AM
    #67
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Interested to see how that works out. I have that same mount and it flops all over under the truck.
  8. Jul 4, 2022 at 1:03 PM
    #68
    98rock runner
    Nick
    1998 4runner
    4wu solid axle swap
    Slander, are you talking about the trans or the mount it self flopping?
    Wulf likes this.
  9. Aug 28, 2022 at 7:12 PM
    #69
    smacaulay
    This is gonna be full bump. 1” higher the axle hits the pan and upper link mount is in the motor mount. Ride height will be 4” higher. Tcase is out and crawl box kit should ship soon.
    ToyRyd04 and Duckfatt like this.
  10. Aug 28, 2022 at 7:21 PM
    #70
    smacaulay
  11. Aug 31, 2022 at 3:58 PM
    #71
    smacaulay
    Good looking parts
    98rock runner, Duckfatt and bhigbee like this.
  12. Sep 3, 2022 at 8:25 PM
    #72
    smacaulay
    Cracked into my junkyard case, pretty damn clean.
    Ran into an issue with the NFW shaft, 20 mils bigger than the VF1 shaft and planetary won't fit. Anyone else experience this issue? Sent a note to NWFab so we'll see.
  13. Sep 3, 2022 at 8:32 PM
    #73
    smacaulay
    Added some reinforcement to the front horns, will run a 1.5" .120 wall tube in between to stiffen the frame a bit before cutting out the trans cross-member (anything bigger gets in the way of the compressor line). Plan is to add a 2x3" piece in front eventually for start of the winch mount/bumper.
    Duckfatt likes this.
  14. Sep 6, 2022 at 10:46 AM
    #74
    smacaulay
    NWF got back to me very quickly, and are taking care of it...solid customer service. The bearing face of the shaft wasn't finish machined.
    ToyRyd04 likes this.
  15. Oct 21, 2022 at 12:41 PM
    #75
    smacaulay
    Almost done.
    02hilux and ToyRyd04 like this.
  16. Oct 21, 2022 at 9:51 PM
    #76
    smacaulay
    The kids went down early tonight
    04Pre_Runner, ToyRyd04 and 02hilux like this.
  17. Oct 24, 2022 at 9:56 PM
    #77
    v5ensx
    v5ensx CARB legal is not CALI legal
    How's the runner coming along
  18. Oct 25, 2022 at 7:48 PM
    #78
    smacaulay
    The cases took longer than anticipated. I experienced several minor issues, which Nwfab was super quick to respond to. Customer service alone I’ll go back to them every time, and great products. Got a piece of schedule 40 welded in up front to brace the frame. Deleted the evap stuff to make room for the driver coilover tower, need to take out the stock intake and ABS module to make room for the passenger tower (want to keep cruise control still). My next real challenge is figuring out a trans mount so I can get the lower link mounts in. Once that happens I can start getting the 3 link mocked up.
  19. Oct 25, 2022 at 8:04 PM
    #79
    smacaulay
    Also, looking for a full float fj80 rear if anyone has a line on one in the PNW. Will be spring over with 57” f150 packs.
  20. Dec 5, 2022 at 6:36 PM
    #80
    smacaulay
    Frame brackets tacked in and lower arms mocked up. JD2 bender on the way.
