3rd Gen 4Runner - Linked FJ80
Discussion in 'Solid Axle Suspension' started by smacaulay, Mar 16, 2022.
  1. Dec 5, 2022 at 7:40 PM
    #81
    02hilux
    Planet: EARTH
    Nice. Baby steps
    smacaulay[QUOTED][OP] likes this.
  2. Dec 5, 2022 at 8:35 PM
    #82
    02hilux
    Planet: EARTH
    How long is your lower link?
  3. Dec 5, 2022 at 9:08 PM
    #83
    smacaulay
    smacaulay [OP] Well-Known Member
    38” bolt to bolt
  4. Dec 11, 2022 at 7:57 AM
    #84
    smacaulay
    More baby steps. Need to fully cycle it, but looks like the panhard mount needs to move back an inch, and upper link needs to move drivers an inch or so. I picked up 4wu shock mounts but will probably end up bending some tube to clear steering/engine bay stuff more easily.
    02hilux likes this.
  5. Dec 11, 2022 at 7:59 AM
    #85
    smacaulay
  6. Dec 11, 2022 at 8:00 AM
    #86
    smacaulay
    What pitman arm did you use?
  7. Dec 11, 2022 at 8:09 AM
    #87
    02hilux
    Planet: EARTH
    Sky's chromoly 3/4" less drop than stock
  8. Dec 11, 2022 at 8:26 AM
    #88
    02hilux
    Planet: EARTH
    Tube will definitely be easier overall, no steering shaft to mess with. I'm re-doing my front towers maybe next week. Putting in taller towers to bring the truck down a few inches and will be cutting it different so I can run a 1 piece steering shaft vs the current 2 piece.
    Just finished re-doing my rear suspension by adding RJ antirock swaybar and changing the lower mount with one that sits an inch lower.
  9. Dec 11, 2022 at 8:32 AM
    #89
    smacaulay
    Thanks for the pics, that helps a ton! I’ll be copying you (maybe not double sheer as I have so much other shit to do). Are you running the heim below the steering arm?
  10. Dec 11, 2022 at 8:40 AM
    #90
    smacaulay
    That rear setup is so bad ass. I’ve been looking for a full float cruiser rear but they’re hard to find. $1k+ at the junkyard. I’ll probably end up running the stock rear with spacers and leafs.
  11. Dec 11, 2022 at 8:44 AM
    #91
    02hilux
    Planet: EARTH
    I had it right under the arm originally but it bind when drooping before maxing out my CO. I end up add a (maybe) half inch spacer between the arm and heim and cycle the suspension with no issue after that.
    But after driving it around like that and having discussions with other local 3 link owners regarding the drag not being in the same plane as the track bar, I just move (last week) the drag heim above the steering arm. I don't have any picture of how it currently sit but the drag and track is nearly identical now. I'll snap some pictures later when I go to my mancave.
  12. Dec 11, 2022 at 8:51 AM
    #92
    02hilux
    Planet: EARTH
    It's about the same price here. Open ff80 runs about ~800 and locked ff80 are going for ~1200. Picked up one for a buddy last year from a 97 LC9.5 with elock for 1100.
  13. Dec 11, 2022 at 8:56 AM
    #93
    02hilux
    Planet: EARTH
    Those damn grade 8 3/4" bolt is no joke. Bought the 3/4-10x11 and cost $30 buck.
  14. Dec 11, 2022 at 8:57 AM
    #94
    02hilux
    Planet: EARTH
    If you're running 12" CO, you should be fine without a space.
  15. Dec 11, 2022 at 8:57 AM
    #95
    smacaulay
    Sweet, I’ll use the same pitman arm and run the heim on top of the arm. It does look like it lines up well with the panhard that way to keep them in the same plane.
  16. Dec 11, 2022 at 8:57 AM
    #96
    smacaulay
    I’m running a 14”
  17. Dec 11, 2022 at 8:59 AM
    #97
    02hilux
    Planet: EARTH
    Yea, I was honestly trying to avoid that. I wanted both heim to be bolted within the double shear. Guess 1 heim above the top shear will be fine, lol.
  18. Dec 11, 2022 at 9:06 AM
    #98
    02hilux
    Planet: EARTH
    The flat pitman might be the better option honestly if there's clearance. I end up running an offset heim at the frame for the track bar. If i knew the flat would not contact the frame when I ordered the 3/4" less drop, I would have bought the flat instead.
    I end up mounting my steer box flat vs being tilted and low to the bottom of the frame. By doing this, it provide more clearance for the pitman. My buddy's 3 link taco steer box was tilted and he ran the 3/4" less drop. I figure I needed the same one.
    Just too expensive to buy the flat for $150+ now for this reason.
    But looking at your picture, the flat will bind and you will need to notched the frame.... Buy mine with double shear and I'll buy a flat.... just kidding lol
  19. Dec 11, 2022 at 9:22 AM
    #99
    smacaulay
    I haven’t drilled any holes in the frame yet. Are you thinking the best solution is mount the box lower with the flat arm to align it perfectly with the panhard heim? I guess I just need to decide which one the order and then figure out how to make it work.
    Edit: I’m on kid duty all day, all I really need to do is get a damn measuring tape on it.
  20. Dec 11, 2022 at 9:39 AM
    #100
    02hilux
    Planet: EARTH
    Yes. But looking at your picture, you really don't have much of a choice.
    Yours
    Mine
    I think the 4r frame is slightly smaller in profile as well?
