3rd Gen 4Runner - Linked FJ80
Discussion in 'Solid Axle Suspension' started by smacaulay, Mar 16, 2022.
  1. Dec 11, 2022 at 11:04 AM
    #101
    02hilux
    Planet: EARTH
    Here you go, heim above arm.
    smacaulay[OP] likes this.
  2. Dec 11, 2022 at 11:47 AM
    #102
    smacaulay
    smacaulay [OP] Well-Known Member
    Super helpful to have your pics for reference. I’ll get out there later tonight and get some measurements.
  3. Dec 18, 2022 at 12:25 PM
    #103
    smacaulay
    Old engine stand, almost ready to use this thing
    ToyRyd04 likes this.
  4. Dec 19, 2022 at 10:28 AM
    #104
    smacaulay
    Found a 07 4runner complete rear axle for $350 (FJ80 rear disc are impossible to find). ~65" WMS (63" front, may just run spacers) with disc and internal drum parking brake which i want to retain. Anyone gone down this path with advice?
  5. Dec 20, 2022 at 6:53 AM
    #105
    02hilux
    Planet: EARTH
    4th Gen 4R rear are decent because of the disc/drum combo but they're still a semi floating axle. You want a FF because the load is not on the axle like a semi. Semi bearing is position at the tube end vs a FF with spindle.
    And if you by chance grenade on the trail, changing a shaft or third member will be so much easier and less of a mess. You'll thank yourself later.
    As you know, the 9.5 can handle abuse.
  6. Dec 20, 2022 at 8:22 AM
    #106
    smacaulay
    If it was easier to find (closest is 1k miles away, and $1k) I 100% agree and I'd definitely go full float. I've broken older ifs rear shafts on the trail with 40's and it does suck. I'm hoping with only 37's i can keep a semi float reliable.
    With 1" spacers up front, 4th gen rear, and 3.5" bs wheels this thing is gonna be wide for yota axles.
  7. Dec 23, 2022 at 7:05 AM
    #107
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    4th gen 4runner axle will be an 8” diff, people grenade them pretty regularly in mildly built 4Runners and GXs but that’s partially high mileage units with loose crush sleeves. The only upgrade with that axle is the width and the brakes. A slightly stronger option is from a 5th gen 4runner/ GX460/ 11(?) + FJ with the 8.2 rear diff.
    The FF 80 axles still have a weak link where the axle flange bolts to the wheel hub, it can be remedied by installing larger studs or bolts and eliminating the cone washer, but it will never be as strong as a 1 ton FF due to the smaller wheel bore and those bolts being on a narrower diameter.
  8. Dec 23, 2022 at 9:00 AM
    #108
    smacaulay
    Great info, thank you! Any axle I end up with will get a arb with solid spacer. The width, rear disc, and internal drum brake are a good upgrade from the stock rear. I’ll look for a 5th gen or fj80 rear in the meantime, but seems like the 4th gen is a good compromise in my situation.
  9. Dec 23, 2022 at 10:13 AM
    #109
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Have you checked car-part ? I’m picking up a set of fj80 FF axles next week for $1k for the pair
  10. Dec 23, 2022 at 1:20 PM
    #110
    smacaulay
    That’s a great price! The only full floats near me are 800 miles away and $800 for the rear only.
  11. Dec 23, 2022 at 1:30 PM
    #111
    Kerleyfries
    Zack
    Lebanon
    Where are you at? I’m in Nashville and having to drive to Bristol for them, bout 4 hours each way.
  12. Dec 23, 2022 at 1:58 PM
    #112
    smacaulay
    near Seattle
  13. Dec 23, 2022 at 2:02 PM
    #113
    Kerleyfries
    Zack
    Lebanon
    Damn. Yea, you’re out there. May be worth checking car-part and seeing if anyone would ship. I found a set in MI that would ship. $1k for the set plus 250 to ship, but they were rusted as fuck.
  14. Dec 23, 2022 at 2:03 PM
    #114
    smacaulay
    I’ve asked a couple so far and it’s more than it’s worth. I’ll keep looking in the mean time and pick up that 4th gen rear just in case. They used to be super easy to find.
  15. Dec 23, 2022 at 2:08 PM
    #115
    smacaulay
    For $800 plus I might as well be pricing out a diamond
  16. Jan 7, 2023 at 5:14 PM
    #116
    smacaulay
    07 4runner axle is going in the rear. I want rear disc, width, and maybe a parking brake.
  17. Jan 10, 2023 at 6:28 PM
    #117
    smacaulay
    F150s it is
    02hilux likes this.
  18. Jan 10, 2023 at 6:54 PM
    #118
    02hilux
    Planet: EARTH
    They're good. Had them on my 83. Carry good weight and decent flex. They're cheap too.
  19. Jan 10, 2023 at 7:10 PM
    #119
    smacaulay
    $100, can’t beat the price. I’ll have almost 10x the price of the rear in the front. Good to hear they should work out well!
  20. Jan 15, 2023 at 5:27 PM
    #120
    smacaulay
    Got all the steering parts. If the stock pitman arm isn’t magically off the box tomorrow I’ll be cutting it off.
    Duckfatt, ToyRyd04 and 02hilux like this.
