3rd Gen 4Runner low on power (5VZ)
Discussion in '4Runners' started by tigerstripe40, Aug 30, 2022.
  1. Aug 30, 2022 at 10:15 AM
    tigerstripe40
    tigerstripe40 [OP] Member
    I am helping a friend with her 3rd gen 4Runner with a 5VZ and automatic.
    It's low on power, and reporting a lean condition.
    They get a check engine light that comes and goes, and when we pull codes we are seeing a Lean condition in one bank.
    I haven't worked on it yet, but I am preempting the work I am going to do this evening.
    So far as I know it has had:
    1. Downstream 02 Sensor replaced.
    2. MAF Sensor replaced.
    3. Ran a can of Chevron fuel injector cleaner through the tank.
    My Plan of Action is to:
    • Pull the code to get the exact Error(s).
    • Test the upstream O2 sensor (AFR sensor, IIRC).
    • Pull the spark plugs and check the condition.
    • Compression check the motor.
    Any other things I should check or am I just spinning in circles without pulling the codes?
  2. Aug 31, 2022 at 6:53 AM
    DuckDiggler
    DuckDiggler Active Member
    2020 Toyota 4Runner
    Stock…so far…
    I would def start with pulling the codes. Has she been the only owner?
