3rd gen 4Runner seats in Access Cab Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by sshirley, Dec 7, 2014.
  1. Jan 21, 2015 at 8:59 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Keaker, thanks for the reply. That's about what I was figuring anyway. Ive been keeping a eye open for a set of brown seats and center consol.
    I like the idea of modding the mounts to push the seat further forward. As it is Im 6,1'' and don't push the seats all the way back.
  2. Jan 21, 2015 at 10:40 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well if you are planning to move the mounts forward then you have to drill all new holes to mount them anyways so look for seats that have 4 flat style mounts so they bolt straight to the floor. this means you have endless seat choices so go walk a salvage yard and shop for this type of mounting system then once you know the brand and model that has them search those for the nicest set of seats.
    as to the center console,
    I find them all to be cheap crap and most you find at salvage yards are cracked or have broken lids so its better make your own console from wood and screw it to the floor. it will have a lot more storage inside then the factory ones and this will be more solid and strong plus you can cover it with vinyl, paint it, or stain it to look nice.
  3. Jun 20, 2024 at 12:56 PM
    Dcharloff
    Dcharloff Member
    David
    NC
    2000 Tacoma 5VZFE 4x4 5spd
    Gen2 TRD SC 33x12x15 Mastercraft Coursers 2 inch level Custom exhaust
    Great post thanks for the insight and idea for the console
  4. Jul 2, 2024 at 3:15 PM
    Tuluk
    Tuluk Well-Known Member
    1999 trd manual 4x4 ext cab
    Does anyone know if any of the 3rd gen front passenger seats came with the Isofix style car seat buckle anchors? I’m not sure when those were first available, but it would be nice to have a seat with them.
  5. Oct 10, 2024 at 10:02 PM
    hp415
    hp415 Well-Known Member
    Paul
    1999 excab taco v6 TRD 5spd
    Has anyone performed this swap by changing over the seat rails? There's a set of minty 3g-t4r seats on Marketplace right now, the only caveat is they are using the rails for their next seats. I currently have tacoma stock buckets in my truck. Could I pull off this swap?
  6. Oct 11, 2024 at 10:10 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I believe it is possible to swap the rails, but it's not a simple swap. You have to remove a stop on the end of the rail to be able to slide the whole bottom part off. The bearings will fall apart when you do this. Its usually easier to remove the feet and weld them on the new rail.
