3rd Gen 4WD Lever
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skimendo, May 11, 2025.
  1. May 11, 2025 at 3:17 PM
    skimendo
    skimendo [OP] Member
    Howdy
    Just had a bit of a problem in the hills far from home. Truck wouldn’t come out of 4 low after trying everything. Finally crept to town 3.5 hours later and found a video about what to do. Removed acuator and pushed rod into 2wd. Pretty simple took 15 minutes. Thank god for this forum and YouTube. Anyway got thinking if any of you have ever installed an actual 4WD lever like old school and got rid of actuator. 2016 Taco here. Thank you Tacoma world folks for all your help over the years!!
  2. May 11, 2025 at 3:45 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    https://www.tacomaworld.com/threads/lets-see-your-fj-case-swap.455278/
    Chew likes this.
  3. May 11, 2025 at 8:15 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Never heard of it yet. The actuator has contacts and thus communicates with the 4X4 ECU so if you removed all that the lights on the dash would be in conflict and perhaps the ADD would not move either. Something to study.
  4. May 11, 2025 at 8:17 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I have not seen anyone simply add a lever. There have been a number of people swapping in FJ cruiser manual shift cases though. I’d love to do that but too much work for my use case and now I’m not planning on keeping the truck anyways.
    Not a fan of electronic shift. I really think it is a solution looking for a problem, and it introduced more problems than it solved. Nobody wanting a 4x4 truck was begging to get rid of the manual shift lever.
