3rd gen 5100 lift
Discussion in '4 Cylinder' started by Nyrob, Jul 28, 2022.
  1. Jul 28, 2022 at 8:13 AM
    Nyrob
    Nyrob [OP] Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    I have a 2.7 3rd gen accesscab with a mid rise topper and some 265/75/16s. I was looking to do a very minor lift 1” front 1.5 in the back or 3/4 front and 1.25 rear. I was thinking about 5100s all around first or second setting on the front and a blocks in the rear. I haven’t been able to find any info on 3rd gen 2.7s using 5100s I see coil spring swaps was looking to see if anyone has kept stock springs with 5100s. I could do spacer front and rear but while i am in there would rather put some better shocks
  2. Jul 28, 2022 at 10:37 AM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Another option might be 5100s all around fronts on the bottom for no lift and a 1/2 front and 1.25 rear block. Will 5100s front on the lowest setting and swapping the rear add any height ?
  3. Jul 28, 2022 at 2:03 PM
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    I have 5100’s all around. Used my stock coils on first setting and kept the rear stock other than the 5100’s. My truck sits level and it improved the ride quite a bit.
  4. Jul 28, 2022 at 7:30 PM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Any pictures sounds like it raised the front 1-1.25'' since that's about the stock rake. Exactly what i am looking to do and probably a rear block since i have a shell causing a little drop
