3rd Gen 6112's In Stock and Ready to Ship
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, Feb 15, 2017.
  1. Mar 19, 2019 at 11:24 PM
    #41
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
  2. Mar 20, 2019 at 12:07 PM
    #42
    HeadStrong Off-Road
    HeadStrong Off-Road [OP] Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    PM sent :)
  3. Mar 20, 2019 at 9:08 PM
    #43
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Also curious about this. Am I correct that if you need the heavy coils you have to buy two pairs of coils? Thanks!
  4. Mar 21, 2019 at 9:03 AM
    #44
    HeadStrong Off-Road
    PM Sent. :)
    ffemt2987[QUOTED] likes this.
  5. Mar 21, 2019 at 4:21 PM
    #45
    Dk4975
    Dk4975 New Member
    Dave
    2018 White TRD Sport
    Also interested in the 6112/5160 combo with the stiffer coils. Curious about stock?
  6. Mar 21, 2019 at 8:06 PM
    #46
    wsharp23
    wsharp23 Member
    2017 Tacoma TRD off-road 4x4 LB
    Are the 6112s in stock? I’m interested as well
  7. Mar 22, 2019 at 11:23 AM
    #47
    HeadStrong Off-Road
    PMs sent :)
  8. Mar 22, 2019 at 11:55 AM
    #48
    ken360
    ken360 Well-Known Member
    Nebraska
    2018 Tacoma TRDOR DCSB Cement
    Wheelers has different spring options
  9. Apr 2, 2019 at 5:32 PM
    #49
    jimbro
    jimbro Well-Known Member
    Jim
    Manoa, Hawaii
    2024 Bronze Oxide Tacoma Trailhunter
    Leitner rack
    2nd gen 6112 on the highest setting, how much lift for a 3rd gen? I’ve searched but can’t seem to get a definitive answer
  10. Apr 9, 2019 at 3:21 PM
    #50
    Papito
    Papito Member
    USVI
    2017 Silver Tacoma Limited
    Looking to purchase 6112 kit with strut assembly.
    I have a limited 2017 crew cab tacoma
    Would like to add a deaver leaf to the rear and shocks - open to suggestions!
    Thanks
    -Papito
  11. Apr 9, 2019 at 5:03 PM
    #51
    TacoDelaroca
    TacoDelaroca Well-Known Member
    Andrew
    2014 taco double cab short bed TRD Sport with 4x4
    Nothig yet
    Looking for a 5160/6112 set up as well
    I have a 14’ TRD sport DBSB. Curious about pricing per set up.
    Thank you!
  12. Apr 12, 2019 at 8:23 AM
    #52
    MinerTaco
    MinerTaco Active Member
    SoCal
    2018 TRD Off Road DBL
    I was wondering the same thing. Because the stock 3rd gen is 1 inch taller than 2nd gen, subtract one inch from the 2nd gen 6112 lift height and that will be the lift on the 3rd gen. Discovered this firsthand. I put on 2nd gen 6112 at 3rd notch (1.5") on my 3rd gen and got only 0.5" lift from stock
    jimbro[QUOTED] likes this.
  13. Apr 12, 2019 at 10:42 AM
    #53
    jimbro
    Jim
    Manoa, Hawaii
    Leitner rack
    Thank you sir thats exactly what i needed! Since i found a used set for reasonable price, i will be using them on my 3rd gen. If it doesn't work out, i'll just wait for the 3rd gen to restock somewhere.
  14. Apr 19, 2019 at 9:35 AM
    #54
    HeadStrong Off-Road
  15. Apr 19, 2019 at 7:44 PM
    #55
    joltyK
    joltyK Active Member
    '16 MGM DC TRD Sport 4x4
    Just ordered my set from Marie today! Great customer service, can’t wait to install!
  16. Mar 20, 2020 at 8:35 AM
    #56
    ZeroT4R
    ZeroT4R Well-Known Member
    Vantucky
    TRDCEMENT_TACO19
    6112/5160 SPC UCA RCI SLIDERS NITTO 285 75 17 SCS 17x9 RAY10s
    How about HS spacers with 6/5 notch to get that extra .5” of lift, true 2.5”
  17. Mar 20, 2020 at 8:46 AM
    #57
    GladiatorNOT
    2017 TRD OR
    if you get the optional 650 springs then you will get 2.5” of lift without adding a spacer.
  18. Mar 20, 2020 at 2:34 PM
    #58
    ZeroT4R
    Vantucky
    TRDCEMENT_TACO19
    I would do that option. But looking to do something is a short run and easy install
  19. Sep 8, 2020 at 5:55 PM
    #59
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    I’m interested in a the 6112 option with 650lb springs but also I want full leafs in rear for HD load as I occasionally tow a trailer. What do you recommend? I don’t want to deal with UCA’s so if I could stay at 2” or less.
  20. Nov 11, 2020 at 10:48 AM
    #60
    El Tigre
    El Tigre Well-Known Member
    Long Beach
    2018 DCSB TRD Sport 4x4 6speed
    Armrest MOLLE Panel (https://www.tacomaworld.com/threads/3rd-gen-center-armrest-molle-panel.712437/) Hood Scoop Hidden Baja Designs S8 10" Diode Dynamics SSC2 Pro Ditch Lights Bilstein 6112 front Bilstein 5160 rear Bakflip MX4 DIY Bed Lights RGB Rock Lights Modified Amazon 8 gang switch controller (thread coming)
    I installed the 2nd Gen 6112s up front on the 4th setting (+2.15") and subtracted the 1" like you said to get an idea. However after installing, I still seem to have about a 2" lift unless somehow my math is off... Center of my hub to the bottom of the fender directly above measures 22.5" and from what I can remember the stock measurement there is 20.5" or am I wrong with that last number?
