3rd gen AC at idle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaC, Aug 12, 2023.
  1. Aug 12, 2023 at 1:10 PM
    YotaC
    YotaC [OP] Member
    My tacoma is a 2020 model. The AC cools very quickly when moving but if sitting still it blows just slightly cool air.
    Now as I type this last it is 103F in central MS.
    Is this normal tacoma AC behavior?
  2. Aug 12, 2023 at 1:12 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Yes
    Apparently there’s a service bulletin, adding an electric fan if customer complains about low speed cooling.
  3. Aug 12, 2023 at 1:15 PM
    YotaC
    YotaC [OP] Member
    Nice. I'm going to ask Toyota about that. Thanks for the quick response!
    Chew likes this.
  4. Aug 12, 2023 at 1:18 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Most vehicles struggle with AC when it’s over 100 with high humidity. Nice to hear about an additional fan option. I have not noticed an AC problem, but where I live, mainly dealing with 80s or low 90s for most part.
    Phlogiston likes this.
  5. Aug 12, 2023 at 1:28 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I’d find the TSB, read it before you go. I think it spells out customer complaints.
    NTSALL4 and YotaC[QUOTED][OP] like this.
  6. Aug 12, 2023 at 1:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Most (all?) automobiles struggle with heat, a/c, and electrical output at idle. Everything is spinning slowly.
    Junkhead, hiPSI and Chew like this.
  7. Aug 12, 2023 at 5:14 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    The TSB for this can be found on this forum. Read it first before pursuing. The 'fix' is a real mess of a hack job on the wiring. Ask yourself if you want a tech that can't do an oil change properly doing this work.
  8. Aug 12, 2023 at 5:18 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Yup completely normal
  9. Aug 12, 2023 at 5:18 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Good point!
    Mine does have slightly decreased performance when REALLY hot and idling, it still keeps me plenty cool, even when not on MAX. That said, I’d rather deal with that, then let Ricky-Ratchet gut my truck.
    Taco22trdor likes this.
  10. Aug 12, 2023 at 5:21 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, this TSB.
    musicisevil and Squirt like this.
  11. Aug 12, 2023 at 5:37 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    is this your first vehicle?
    The AC system requires circulating air to move the heat away from it, air circulates better when your vehicle is in motion rather than sitting still at idle.
    Home AC works the same way, if the coils are clogged with dirt and debris that can prevent air circulation and the compressor can overheat and stop working efficiently.
    When you're at idle, try putting it in neutral (foot on brake of course) and bring your RPMS up to 2000-2500 to see if that helps pull some air into the engine bay and see how that affects it.
  12. Aug 12, 2023 at 5:38 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes and no. A lot of vehicles have electronic fans which are powered independently which reduces many of these issues.
    usmc2msu likes this.
  13. Aug 13, 2023 at 9:00 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This is exactly why I'm not doing the AC evaporator TSB even though I have the infamous high RPM AC whistle. Mine really isn't that bad, and I shudder to think about my dealership tearing the dashboard apart, taking out the AC unit and evaporator, and putting it all back together again. My truck doesn't have a single rattle in the dash, and that seems like a perfect way to end up with a bunch of them. I'd rather put up with the occasional intermittent whistle.
  14. Aug 13, 2023 at 9:05 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    Get your A/C system checked for leaks. I had a similar issue on my 17’ and previously on a 16’. Schrader valves leaking and low refrigerant were the culprit both times. My 17’ AC also had the infamous whistle but after the valve repair and refill this issue has gone away.
    YotaC[OP] likes this.
  15. Aug 13, 2023 at 11:12 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While I have not heard the infamous whistle in my 2020 yet, imo the A/C is only average at best, especially when over 95 degrees. Its no better than my early gen1 tundra was.
  16. Aug 13, 2023 at 4:20 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Something not helping the poor performance of the A/C systems on these trucks is the very long uninsulated refrigerant line that snakes it's way from the evaporator housing on the passengerside firewall, down and then underneath the front of the engine, and then over to the A/C compressor on the left side of the engine (the entirety of it all soaking in the hot air blast from the engine fan).
    I insulated it using split-foam pipe insulation (wrapping it every few inches with 3M electrical tape to help keep it secured). This made a noticeable difference in how cold the air gets while in bumper-to-bumper traffic. Have not experienced it shutting off when it's 105°F outside either, which I've read can happen when it gets over 100°F.
    https://www.homedepot.com/p/Everbilt-3-4-in-x-6-ft-Foam-Self-Seal-Pipe-Insulation-ORS07812/204760815
    YotaC[OP] and Phlogiston like this.
  17. Oct 27, 2023 at 11:43 AM
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    I heard the AC whistle for the first time in my '23 Pro today....was very short but it was there. Apparently normal? Air was still ice cold though...
  18. Oct 27, 2023 at 11:51 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Welcome to the club :) Let's not call it normal because an AC evaporator isn't supposed to do that. Let's just say a common quirk for these trucks. :) Mine blows ice cold also, even in the Florida heat.
  19. Oct 27, 2023 at 11:52 AM
    Nordicbeast
    '23 TRD Pro 6MT
    Agreed....how about "normal for a Tacoma!"...
  20. Oct 27, 2023 at 11:54 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
