3rd GEN Added Lamps to Cargo SW
Discussion in 'Lighting' started by caribe makaira, Jan 15, 2019.
  1. Aug 25, 2019 at 4:07 PM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    Completed harness with taps to all pins on Cargo Lamp switch except RED (CGSW_CGLP)
    wahoobie likes this.
  2. Sep 18, 2019 at 1:13 PM
    planohog
    planohog Well-Known Member
    Seabrook, Texas
    2019 taco 4X4 v6 TRD OR
    3&1 lift, tire,wheels, bakflip G2. Front Cam,A/C,rock leds,internal leds.
    help:
    The documentation you have is great, I somehow get confused on application.
    I will have VCC and Ground to the leds.
    I need them to illuminate ( on ) with the following conditons.
    a. ( key fob lock-unlock )
    b. ( door open )
    c. ( manually turn on the cargo light from OEM switch in dash board. )
    I have a relay
    12V DC 40/30 Amp 5-Pin SPDT Automotive Relay
    I have mini fuse tap ( sun roof fuse is my proposed pick point )
    I will have pin 86 and pin 30 on relay = 12VDC
    I will have pin 87 on relay to rock-leds then GND
    I need pin 85 on something that will work with a. b. c above.
    Do you know where I can find these wires ? and what color and where are they.
    Assumtion is drivers side kick panel.
    Thanks for you help
  3. Sep 18, 2019 at 3:51 PM
    caribe makaira
    If all are required, you'll need a few more parts, but if you leave the Cargo Lamp Switch on DOOR, and you tie your added relay wire from pin 85 to the BLUE wire on the Cargo Lamp connector you're set.
    The wire (BLUE) you need to use are behind the driver's dash panel (behind the Cargo Lamp Switch).
  4. Sep 19, 2019 at 1:00 PM
    caribe makaira
    Here be another tap. Using a Tundra Cab Illumination switch.
    You can have the added lamps OFF, DOOR or ON.
  5. Sep 19, 2019 at 8:57 PM
    caribe makaira
    For a "cheaper" switch instead of the Tundra switch and connector.
  6. Sep 20, 2019 at 5:31 AM
    planohog
    Seabrook, Texas
    thanks for the help, really enjoy the mod, the off/door/on switch does everything I need, on door, it will turn itself off with the dome lights ect. 12VDC fused, sourced from sunroof tap to relay pin 30 & 86. Relay pin 87 to leds RED. Relay pin 85 to blue wire on cargo connector with tap. Gnd I used the 10MM bolt that is closest to the door into sheet metal. This ground was for Led black. I dropped the panel under steering wheel with three easy to find 10MM bolts, It un-cliped nicely, easy to find, I also had drivers side kick panel and door sil panel off, all very easy to remove and replace. I used a very small hole under drives seat carpet to get out of the cab. I need to revisit that spot and wrap wires to keep from rubbing and putty it up. I think this basic mod should come from factory, Im super happy with this one. Thanks all for the work you did to help the rest of us.
  7. Sep 20, 2019 at 6:45 AM
    caribe makaira
    Excellent! So no added switch for OFF or ON? What tap type didya use?
  8. Sep 20, 2019 at 7:21 AM
    planohog
    Seabrook, Texas
    The cargo switch, I can control the leds , with it , turn them on or off or use the "door" feature. This switch controls the back cargo lamp as well.
    The leds I used.
    https://www.amazon.com/gp/product/B01LZU3DWG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    6 Pods LED Rock Lights, Ampper Waterproof LED Neon Underglow Light for Car Truck ATV UTV SUV Jeep Offroad Boat Underbody Glow Trail Rig Lamp (White)
    Tap
    ( note the very small fuse did not fit in this tap, but the tap fit in the breakerbox under dash.
    it had a 15amp included with tap, make sure you install it in the correct slot. Use meter or test lamp to verify. )
    The fuse box cover (tacoma) was not reinstalled. I have it for reference only now. I
    https://www.amazon.com/gp/product/B01BU59QA8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    ABN Fuse Tap Fuse Holder & Fuse 5-Pack – 12V Add a Circuit Kit – ATM Low Profile Mini Fuse Blade & 15A AMP Adapter
    by ABN
    relay
    https://www.amazon.com/gp/product/B01KVZ2MU4/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
    • User Manual available for download under Product Information Details
    • Bosch style 12VDC (14V Max) 5-Pin SPDT (Single Pole Double Throw) Relay with 40A/30A High Switching Capability.
    • Interlocking design relay socket harness base for easy cable management & organization.
    • Heavy duty 14AWG wires for the main contact and pre-wired with 6" pigtail leads.
    • Wire Specifications: Black - Ground (85), Red - VDC (30), White - Trigger (86), Yellow - Output N/C (87a), and Blue - Output N/O (87)
    zDirtyDeedz likes this.
  9. Sep 20, 2019 at 8:17 AM
    caribe makaira
    And the tap to the blue wire?
  10. Sep 20, 2019 at 12:19 PM
    planohog
    Seabrook, Texas
  11. Oct 1, 2019 at 8:26 AM
    Osteology
    Osteology Well-Known Member
    Mark
    Dallas, TX
    2019 Quicksand TRD-OR DCLB
    Is this harness available or was it a one-time group buy?
    Thanks!
  12. Oct 1, 2019 at 8:35 AM
    caribe makaira
    PM @KTJO 4x4 for more details...
  13. Feb 28, 2020 at 5:50 PM
    caribe makaira
    Bed lights tied to Cargo Lamp switch and an added tailgate switch.
    Cargo Lamp on Door or ON, Bed Lamps ON.
    Vehicle OFF, tailgate open, Bed Lamps ON.
    Adding a Tailgate switch "lock" would be a solution for daytime or driving with tailgate open...
    Diode type required:
    http://www.cycleterminal.com/mt-built-in-diode.html
    Sumitomo 3 Pin M Double Diode
    Sumitomo part number 6098-0129
    Part name 3P-CA 090D 3M1.5 C
  14. Apr 20, 2020 at 10:50 AM
    jookdoree
    jookdoree Active Member
    2019 Tacoma TRD Off-Road
    King Extended travel, OME 2.75" Lift - Deaver Expedition Series Springs stage 3, Camburg Toyota Tacoma Pre/4wd 05-19 Performance Balljoint Upper Arm Kit, Archive Garage Tacoma Hammer Hangers, U-BOLT FLIP KIT,
    +1 for group buy please
  15. Apr 20, 2020 at 11:39 AM
    #35
    caribe makaira
    Think it ain't happening. Contact @lapoltba or @KTJO 4x4 for purchase.
    jookdoree[QUOTED] likes this.
  16. Apr 20, 2020 at 12:15 PM
    #36
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I can make one or a few for people of there is a list going. Let me know and I can take deposits and order parts.
  17. Apr 20, 2020 at 4:05 PM
    #37
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    PM Sent
  18. Jun 1, 2020 at 1:41 PM
    #38
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    PM sent
  19. Jun 23, 2020 at 10:08 AM
    #39
    reymataco
    Denver, CO
    @caribe makaira @planohog @lapoltba ... I have a couple clarifying question for you guys...
    I have a topper, so the Cargo lamp is useless to me. I want to repurpose the dash's cargo lamp switch to run some interior LEDs instead. I want the switch's settings to be honored (On, Door, Off).
    I have a cargo switch harness (en route) from @lapoltba with taps for all pins. The LED kit I'm using is an Opt7 Aura Pro LED kit. From their website:
    This kit has a little black box with power and ground for running the LED's themselves, and it has a remote power-on wire. I have dedicated power and ground through a fused power block in the engine that connects directly to the battery.
    The remote power-on wire is supposed to be hooked to a + wire that turns on when the door is open. Which pin from the back of the harness should I use to feed the remote + wire for the Aura kit? The blue wire is labeled as a ground, presumably for a ground activated relay, as described in the posts above. I need a positive wire.
    Presuming then I need to use the green or brown wire? Which is positive and which is negative?
    From the post by @caribe makaira on the top of page 2 in this thread, the labels in the picture posted do not match the labels for the diagram:
    Brown is labeled as Illumination positive in the picture and Illumination negative in the diagram. Same for the green wire. Also, I am not sure if those wires are only hot based on the switch setting (On, Door, Off)?
    Thanks in advance for the help!
    Regards,
  20. Jun 23, 2020 at 10:13 AM
    #40
    lapoltba
    CT - 06076
    The Illumination circuit is for backlighting of all the buttons and switches on the dash. It is fairly low power and should not be used for anything other than small backlight LEDs in switches. It goes on and off with your headlights and dims with the instrument cluster just like all the other interior buttons. If no-one gets back to you before I get home I will look at the wiring diagram again. It's been a while since I looked at this part.
