3rd GEN-Adding Back-up LED's to rear bumper
Discussion in 'Lighting' started by caribe makaira, Apr 27, 2019.
  1. Apr 27, 2019 at 12:03 AM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    Your choice LED's to rear of vehicle, add-a-circuit to 10 amp BKUP lamp fuse No.2, one wire to rear of truck (loomed) and secured. ON with OEM BU lamps and Trailer (if connected). The added BU leds should not exceed 15 amps with the trailer connected. I venture to say the circuit could be "up'd the 20 from 15 then configure to share before buying LED's.
    P.S. for 2GR-FKS only
  2. Apr 27, 2019 at 9:09 AM
    caribe makaira
    Variation: added relay and cab switch for ON when ya like. Hot fuse negates auto off when vehicle off when you leave switch ON.
  3. Jul 2, 2019 at 7:28 AM
    caribe makaira
    A few other variations...
    Tap the power to the BU lamp for added relay pin 87a and Battery Charger circuit in the T12 towing socket, place weatherproof fuse holder inline the tapped Battery Charger line, run relay pin 85 wire and LED grounds wires (loomed) to cab switch.(DPDT)
  4. Jul 2, 2019 at 7:33 AM
    caribe makaira
    Uno más:
    This one you leave relays and towing taps in engine room, nicely tuck away.
  5. Nov 17, 2019 at 8:14 PM
    Catstravaganza
    Catstravaganza Make poor decisions, expect to have a hard time.
    Sacramento
    2019 TRD Tacoma
    Barricade bumpers, mbrp exhaust, method wheels, k&n cold air intake.
    Awesome. Thanks everyone!
  6. Nov 24, 2019 at 9:38 AM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Fairly sure my setup is closer to @caribe makaira, however I tapped a 12v lead under my dash that is hot with reverse engaged for my 'on with reverse' switch power for the in-cab DPDT switch. Everything under the hood runs through my aux relay/fuse box so I didn't have to tap into anything in the factory boxes. I like having the option of turning off the bright reverse LED's when needed, AND having the option of lighting them up just off the switch for things like setting up camp... or other reasons.
  7. Nov 25, 2019 at 11:59 PM
    Hunter399
    Hunter399 Well-Known Member
    2018 White Tacoma TRD Off-Road
    TRD Pro Grill, TRD Pro skid plate, tuff skins stickers, rekgen mudflaps, 33'' tires, 17'' wheels. Nitro 5.29 Gears. Bilstein 8112 front/8100 rears. Icon delta joint UCA’s and RXT leaf pack. Baja designs Fog, squadron ditch lights, and 30” S8 light bar.
  8. Nov 26, 2019 at 7:03 AM
    caribe makaira
    For reference:
  9. Nov 26, 2019 at 7:07 AM
    caribe makaira
    For a better and shorter run on that reverse wire, since you're using the switch they included, find out if your Tacoma has the fuse on the first post.
  10. Nov 26, 2019 at 10:49 AM
    Hunter399
    Thanks for the help! I appreciate it!
