3rd gen aftermarket bumper rear bumper on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Olblue228, Mar 24, 2023.
  1. Mar 24, 2023 at 10:19 PM
    Olblue228
    Olblue228 [OP] New Member
    2012 Blue Tacoma
    Hello all! New to TW looking for answers. I found a rear bumper I really like unfortunately I’ve only found this type in the third gen. Was curious as to if it can just mount up or if there’s any modifications needed to make it fit. TIA
  2. Mar 24, 2023 at 10:48 PM
    vhinojosa4735
    vhinojosa4735 TXTaquito
    Vince
    Corpus Christi, TX
    2010 TRD OR Double Cab Taco 4x4
    2010 TRD Off-road Double Cab 4x4 McNeil Racing Fiberglass 3rd gen conversion all the way around. 4.56 nitro gears, Doug thorley long tubes, TRD exhaust, 37” Toyo M/T’s on 17x9 Method 312’s (5),Dirt King +3.5 Long Travel up front with 2.5 kings all the way around, durobumps up front, Alpharex headlights, Baja Design Fog lights, SR20” rigid bar, Demello Offroad Baja bumper, Dakar HD rear springs, prinsu rack, taco bed mat, AL off-road Trailgate,rci skid plate, full sound system, katzkin all leather seats, 10 pro comp rock lights, switch pro 8 switch setup, on board VIAIR compressor, smittybuilt 9k winch, total chaos cam tab gussets and spindle gussets.
    It will “fit” but won’t match your body lines correctly and will most likely stick out kinda far.
  3. Mar 25, 2023 at 7:52 AM
    Olblue228
    2012 Blue Tacoma
    Thank you for your input. Sounds like custom built is the way to go
