3rd gen aftermarket carrier bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jormuzza1000, May 7, 2024.
  1. May 7, 2024 at 2:34 PM
    Jormuzza1000
    Jormuzza1000 [OP] New Member
    3rd gen tacoma
    None
    Any suggestions on where to get an aftermarket carrier bearing for a 3rd gen taco? Locally I can only get it from toyota. No one has them and cant get any ? Smh.
  2. May 7, 2024 at 3:23 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. May 7, 2024 at 3:44 PM
    Jormuzza1000
    3rd gen tacoma
    None
    I bought that one. It doesn't fit its 30 % smaller than the original and bolt pattern comes up 1 1/2 inch short. I'm in contact with parts geek for a return. Any other sugestions
  4. May 7, 2024 at 3:50 PM
    gudujarlson
    Minnesota
    If you are also skilled at internet searches, I’m going to be off little help to you. The closest I’ve been to by carrier bearing is adding a OME drop spacer.
    This came up too.
    https://www.driveshaftparts.com/CBTT01
  5. May 7, 2024 at 3:55 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    The carrier bearing on the 3rd gens is slightly wider than 2nd gens. The one you received from partsgeek was likely for a 2nd gen. 3rd gen carrier bearings mounting width is roughly an inch wider.
    Best bet is probably online somewhere like from toyotapartsdeal.com or a Toyota dealers online parts site, there's plenty out there.
    Edit: This is the PN you're looking for, 37230-09080, specifically for 2016+.
  6. May 7, 2024 at 3:59 PM
    gudujarlson
    Minnesota
    Jormuzza1000[OP] likes this.
  7. May 7, 2024 at 3:59 PM
    4x4spiegel
    4x4spiegel Well-Known Member
  8. May 7, 2024 at 5:00 PM
    Jormuzza1000
    3rd gen tacoma
    None
    Thank you every one. I found one @ mako drive shafts for 29.97 that's way better than toyota's price. I should get it in 3 days. so now in with an old u joint in center of shaft until new carrier arrives.
    tcBob likes this.
  9. May 7, 2024 at 5:16 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I've been going through this for a week now. The 3rd gen is very different than the 2nd gen. The mounting holes are over an inch wider (5.75" vs 6.89") and the ID of the bearing is 32mm vs 30.
    RockAuto lists the bearing, but it's not available. I knew the first suggested listing wouldn't fit because it said fits '15.
    I found one from another vendor, a driveshaft specialist, for around $40. I've been leery of ordering, partly because of the price, suspecting it's actually a 2nd gen. A couple of other places that listed the bearing, but out of stock were $115-$175.
    Toyota's price of $272 is stupid. I bought a low mileage driveshaft out of a wreck for $275. I'll rebuild the original and keep it around for a spare.
  10. May 7, 2024 at 5:21 PM
    OldSchlPunk
    Rich
    East Central Wisco
    I don't see one on their site that will work. Good luck.
  11. May 7, 2024 at 5:25 PM
    OldSchlPunk
    Rich
    East Central Wisco
    That's the one, out of stock.
  12. May 7, 2024 at 8:28 PM
    Jormuzza1000
    3rd gen tacoma
    None
    OldSchlPunk likes this.
  13. May 7, 2024 at 9:15 PM
    OldSchlPunk
    Rich
    East Central Wisco
  14. Apr 29, 2025 at 12:55 PM
    LittleLarry
    LittleLarry New Member
    2017 Sport DCLB Dobinson IMS 2-3" Lift & UCA Durobumps Flip Greenlane Skids/Sliders
  15. Apr 29, 2025 at 1:33 PM
    OldSchlPunk
    Rich
    East Central Wisco
    You can't replace the center bearing without pulling the u-joint. If you're doing one u-joint, you may as well do all 3.
    That center bearing is the one. I haven't used it yet, I bought a driveshaft from a wreck and the one I pulled out is going to be a spare.
  16. Apr 30, 2025 at 8:28 AM
    LittleLarry
