3rd Gen ARB SAGGY FRONT
Discussion in 'Suspension' started by Dirtridercrf250, Jul 25, 2019.
  1. Jul 25, 2019 at 6:43 PM
    Dirtridercrf250
    Dirtridercrf250 [OP] Well-Known Member
    Hello all I have a new issue with how my truck is looking and performing. I have installed the OME lift and the Summit bumper from arb and now the front end is sitting low. I have read many post but what is the best solution for this?
    Will the OME 886 be a stiff ride?
    Current specs
    Ome 2" 888
    EL096r leafs
    Jba UCA
    285s
    THANKS
  2. Jul 25, 2019 at 6:44 PM
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    When did u install the springs? Bumper?
  3. Jul 25, 2019 at 10:07 PM
    Dirtridercrf250
    I installed the lift in may and the bumper in july. The front sat fine prior to installing the bumper.
  4. Jul 25, 2019 at 10:09 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    That’s because it didn’t have a 100+lb bumper to support.
    YMMPRO and whitepony04 like this.
  5. Jul 26, 2019 at 1:30 PM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    I had a bad experience with 886s sagging with no added weight so I wouldn’t recommend them with that bumper unless you want under 2-1.5” of lift.
  6. Jul 26, 2019 at 2:23 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I dont know the part numbers but you need to get the stiffer springs for those shocks to support the weight of the bumper.
  7. Jul 28, 2019 at 4:10 PM
    Dirtridercrf250
    886 sagged with stock weight? How what do you have added to the truck??
  8. Jul 28, 2019 at 10:36 PM
    mhshark
    Bend, Or
    Sliders was it. Lots of reports of OME springs sagging on the third gens. IMO they should have re-engineered them for the 3rd gen as the weight placement is so different plus the front end is heavier. The stock TRD coil is 700lb rating
  9. Jul 28, 2019 at 10:38 PM
    mhshark
    Bend, Or
    I’d message Dobinsons on here, mike is their rep on here. My local shop has done a lot of installs and loves the stuff and Mike was great giving me recommendations on specific combos for my desired lift. Much more reasonable than going full C/Os which I was thinking of doing
  10. Jul 28, 2019 at 10:47 PM
    GI_Taco
    GI_Taco Well-Known Member
    Halann
    Maryland
    2019 Quicksand DCSB TRD OR MT
    886 with 90000 shocks. Got about 2” up front. Sits level with Dakars out back loaded with about 400lbs. 71585EFC-3A65-4F2C-8633-7B21880E870E.jpg86A1A2C1-5C7B-4360-8F38-6FF90C1A7BFC.jpg
    Mack411 likes this.
  11. Jul 31, 2019 at 9:23 AM
    Dirtridercrf250
    Word you the man!! How does she ride the truck looks great btw
  12. Jul 31, 2019 at 9:26 AM
    GI_Taco
    Halann
    Maryland
    Thanks man! Rides a little stiffer than stock but not much. Noticeably tighter around turns and no more nose dive when braking.
