3rd Gen ARB Turn Signal Help!
Discussion in 'Lighting' started by kwhite1109, Oct 17, 2016.
  1. Oct 17, 2016 at 5:04 PM
    kwhite1109
    kwhite1109 [OP] Member
    Kyle
    Charlotte, NC
    2016 TRD OR
    OME BP51's w/Dakar Leaf Pack Caumburg UCA's Spidertrax 285/75r16 Ko2's ARB Summit Bar Smittybilt 10k
    Hey everyone. First time posting here so I hope I can make my question clear enough not to get roasted. Ha.
    Ok so I have installed the ARB Summit bar on my 2016 and I pretty much have it wrapped up. Last thing is wiring the turn signals to the original truck's wiring. I am fairly confident in actually making the splices when the time comes I am just not sure where to find the wires to splice.
    ARB's directions are pretty much useless as the marker kit says to see the bumper install instructions for wiring and those instructions say to look on the marker kit's instructions. The only detail it gives is listed below. The look that comes with the kit has three wires.
    Green = Indicator
    Black = Ground
    Red = Clearance
    Pretty sure I can figure out the ground. I assume the green would go into the hot wire on the back of the oem turn signal. My question is for the red. Where would that one go? Clearance meaning what? I have searched the sh*t out of Tacomaworld and the internets and have seen references to older models that have different color wires from what I could gather.
    Any help would be greatly appreciated.
  2. Oct 18, 2016 at 5:31 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    I was able to find install instructions for the 100 series Land Cruiser Summit Bar and they actually do have wiring instructions included (unlike the 2016 Tacoma). Would it be safe to assume the wiring logic is the same?
  3. Oct 28, 2016 at 8:46 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    I'm sure you've worked it out by now, but yes, it should be about the same. Identify which wires in the stock harness you need to tap into, then splice into those with the little red jumper clips that come with the ARB kit.
    20% of people probably never even wire up the turn signals in their bumpers because it can be a bit tricky to identify the right wires to tap into. In the old days when a lot of factory bumpers had turn signals built into them, it was simple to disconnect those when taking off the OE bumper, then splice in the new ones. ARB just kept that style going all these years.
  4. Oct 28, 2016 at 1:23 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Green = Turn signal 12+ volt positive wire
    Black = Chassis Ground
    Red = Park lights 12+ volt positive wire
    DRL - ECU controls the ground side of the DRL relay (pin 2)
    DRL Circuit - 10A (factory)
  5. Oct 29, 2016 at 6:29 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    Awesome to log on and see this! I have not figured it out but I finally will have some time this weekend. The above diagram should be exactly what I need. Thanks @fergyz and @Dobinsons Mike for the information.
    Crikeymike likes this.
  6. Nov 5, 2016 at 4:33 PM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    I finally got to it today. It was super easy and I have no idea why I was stressing over it. Thank you for the help!
  7. Nov 8, 2016 at 10:46 AM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Would you mind taking pictures and showing which exact wires you tapped into for the clearance/DRL wire, turn signal wire, and ground wire?
    I'm installing my Summit bar this weekend.
    Thank you!
  8. Nov 8, 2016 at 10:59 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    No problem. I will take some photos and post them up as soon as I can.
    Blindside likes this.
  9. Nov 8, 2016 at 11:06 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    Also, not sure if you got the ARB fog light kit or not but you may want to check the bulbs. Our factory wiring harness for the fog lights are setup for H11 bulbs. The bulbs that come in the fog light kit (at least the one I received) are HB4 bulbs. I went to autozone and picked up some HB4 connectors and joined them to the factory harness.
  10. Nov 8, 2016 at 11:48 AM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Awesome, thank you so much!
    And thanks for the info on the fogs...I'll be grabbing those connectors later this week. I got some part numbers for the Toyota parts, but it was over $50 for the connectors and that seemed too pricey.
  11. Nov 8, 2016 at 1:26 PM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    One more question, I'm a bit confused. Did you buy HB4 connectors? Or did you buy H11 connectors and connected those to the ARB fog light wiring so you could plug into the factory wiring?
  12. Nov 9, 2016 at 6:18 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    I bought HB4 connectors and installed them in place of the H11 connectors that are on the factory fog light wiring harness. The picture shows the original H11 connector on the bottom and the HB4 connector on top.
  13. Nov 9, 2016 at 8:24 PM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Awesome! Thank you for the picture and explanation.
    Did you ever get a chance to grab a picture of the clearance/signal lamp wiring?
    Thanks!
  14. Nov 10, 2016 at 9:28 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    No, unfortunately I did not have time to grab any photos prior to leaving town for a quick business trip. I will be back Friday afternoon and I can snap a few pics then. Apologies.
  15. Nov 11, 2016 at 6:41 AM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    No worries. I appreciate it!
  16. Nov 13, 2016 at 7:16 AM
    Blindside
    Blindside Member
    2016 Tacoma Limited
    Well after 8 hours of installation time yesterday, the suspension is done, the bumper is on, and the fog lights are wired. Only things I need to do now are wire up the KC lights and wire up the signals and DRLs in the bumper.
  17. Nov 13, 2016 at 9:01 AM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    Yes it is a pain. Ok so below are two pictures that illustrate where to attached the wires to. I don't have the time to pull the wires out but hopefully this helps.
    I spliced additional lengths of wires so that is why they are all black.
    Wires that are white with a black stripe are the grounds.
    For the turn signal. Tap into the colored wire going to the signal (that is the positive) and then tap into the white wire with the black stripe for the ground.
    For the one labeled (clearence) that is the picture with the wire way in the back. That is the side marker (not sure actual term) that is the last connection. Tap that colored wire and then you are done. Nothing is done with that ground.
    Hope that helps
    Blindside[QUOTED] likes this.
  18. Nov 14, 2016 at 7:05 AM
    baileybrandon
    baileybrandon 2016 DCSB OR - MGM -
    Bailey
    Tennessee
    2016 Tacoma TRD Off Road Double Cab
    lets see some pics of that bumper!!!
  19. Nov 14, 2016 at 4:40 PM
    kwhite1109
    Kyle
    Charlotte, NC
    2016 TRD OR
    I only have one lousy shot of it right now. I will take some tomorrow as I just got some new shoes on her!
    baileybrandon likes this.
  20. Nov 14, 2016 at 4:59 PM
    baileybrandon
    Bailey
    Tennessee
    Looks good! How was the install?
