3rd gen audio build - Joying tacoma headunit
Discussion in 'Audio & Video' started by 5nahalf, Nov 8, 2018.
  1. Oct 4, 2019 at 10:14 AM
    #361
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    Thank you all for the hard work going in to this product, its usage, and its potential as I am seriously looking at this Joying Unit. I have a 2019 DCLB SR which I believe is the base Entune system with the volume knob located in the upper left location. I have yet to pull the factory unit out to see what’s all there to be done. So to make this as painless as possible, I would need the following?
    2017-2018 Corolla Joying HU with Canbus https://www.joyingauto.com/joying-l...tion-system-for-toyota-corolla-2017-2018.html
    Scosche HU mount https://www.amazon.com/dp/B06XYBT88X?ie=UTF8&psc=1
    Regarding this mount, If one uses the factory center bezel from an Entune Premium factory unit, they would not need to trim the bezel? I have already found one and am hoping I can secure it for this use. Only the Scosche mount would need to be trimmed correct?
    GPS Antenna adapter for Toyota https://www.discountcarstereo.com/sumi-sma.html
    Just to eliminate any extra cables in the dash and promote free air space around the Joying HU for cooling.
    A front facing camera can be installed to work. The Car Solutions front camera can be installed in conjunction with the Joying HU as per arcenik on a 2nd Gen. Does the CS controller still allow the steering controls to function as programmed or does it interfere with the operation of the HU? Would one just plug the harness in before or after the Joying harness?
    Is the sound volume equivalent to the factory head unit? I mainly just want to have decent volume for now and mayber install better speakers and amps or just an OEMAudio+ in the future.
    Thanks in advance for any input or insight anyone can provide.
  2. Oct 4, 2019 at 11:55 AM
    #362
    bryanptn
    bryanptn Well-Known Member
    If you get the radio bezel from a TRD model (which you need for this radio), you'll only need the Scosche mount for the brackets. The brackets will need to be cut down a little bit to fit (about 1/4" from what I remember, but measure first). I ended up buying the Scosche mount for an SR as it was $5 less than the model for a TRD. Brackets are the same in both kit, just the bezel is different.
    ZanexGt and Tmaloy[QUOTED] like this.
  3. Oct 4, 2019 at 11:57 AM
    #363
    bryanptn
    Sound seems pretty good, almost want to say its better than the Entune but I'm not an audiophile.
    Tmaloy likes this.
  4. Oct 4, 2019 at 11:49 PM
    #364
    Tmaloy
    Troy
    2019 SR DC LB
    Thanks for the info, I wasn't able to get the used trim bezel, so I may invest in a new one that would fit this unit. Just a question but does this HU work with Torque and Carista? What ODB reader would you all recommend for use? I intend to leave it plugged in the vehicle. I have the BAFX reader and based on the reviews, it seems to be one of the most trouble free.
  5. Oct 5, 2019 at 7:17 AM
    #365
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    mine came with torq, its in a file folder, just the apk in there to install your self
    Tmaloy likes this.
  6. Oct 5, 2019 at 7:25 AM
    #366
    Tmaloy
    Troy
    2019 SR DC LB
    If I may ask, you are using the BAFX reader? Thanks 5nahalf.
  7. Oct 5, 2019 at 7:53 AM
    #367
    5nahalf
    Erik
    Minnesota
    Im not using any OBD reader on mine right now, I dont do anything that requires me monitor things and im under full warranty still. When i start towing, offroading or get out of warranty then I will get a reader.
    There is a somewhere in this thread where a certain reader didnt work for the person and they had to order a different one.
    Tmaloy[QUOTED] likes this.
  8. Oct 5, 2019 at 8:04 AM
    #368
    bryanptn
    I’ve used both Torque Pro and OBD Fusion with this HU. The OBD reader needs to be based off the ELM327, nothing nicer than that will work. I have a good Bluetooth OBD reader and it would not connect. Had to buy a cheap $10 Amazon one to be able to connect.
    I have since ditched the Bluetooth version for a USB wired OBD reader as I found that I couldn’t use my phone’s Bluetooth if I wanted to use the Bluetooth OBD reader at the same time. The USB wired OBD connects to the HU USB 2.0 connector with a USB hub so that my lower dash USB is also connected to the USB 2.0.
  9. Nov 22, 2019 at 7:33 AM
    #369
    gab1972
    gab1972 Member
    Glen
    Chapin, SC
    2017 Red Tacoma TRD Sport XP
    I am a new Toyoto owner. New Taco owner. And new to Tacomaworld.
    So far, this has been the best forum I've read. Granted, I'm a new member, but a search for a new Android head unit brought me to a YouTube video (the OP's) which subsequently brought me here...to this excellent topic.
    I've read all 19 pages. I was almost sold on getting a Alpine 9 Halo until I read about the Joying. The name almost turned me off, but after reading all of this, it goes to show you can't judge a head unit by its name alone.
    I've been using my Samsung Tablet S5 as my head unit. The tablet fits perfectly between the 2 air vents, with the edges right on the trim. So I mounted 2 very thin strips of velcro to the trim and to my tablet. I use an Android app, Head Unit Reloaded, as the OP mentioned before. I used an OTG USB-C, plug it into my phone, and Android Auto comes up automatically on my tablet. I paired the tablet with my Taco. So if I'm not using Android Auto, I can use whatever other app is on my tablet. Then I just grab my tablet and head into work or home or wherever. I use my tablet for just about everything. Graphic arts on the side. Note taking at work. Entertainment at home. So it works great. The only problem is that when it's on my dash, it covers the OEM Entune unit, which covers my back up camera.
    So I'm just going to install an Android head unit.
    Question:
    1. I saw others mentioning it, but I couldn't find where it was confirmed if a second camera can be hooked up. I would like to have a front camera. Looking at this one because of the hidden cool factor (https://www.amazon.com/dp/B07DC139L...olid=1R3ZXKZVLEKQE&psc=1&ref_=lv_ov_lig_dp_it). It embeds into the bottom portion of the Toyota logo. Anyways, has anyone successfully hooked up an additional camera with this unit?
    2. Has anyone successfully replaced the OEM backup camera?
    3. Has anyone successfully replaced the OEM backup camera AND added a second, front, camera?
    Thanks! I look forward to reading more and to seeing more mods the OP does with his audio build!
  10. Nov 22, 2019 at 7:44 AM
    #370
    5nahalf
    Erik
    Minnesota
    You can add a front camera, though Ive only heard of people using the anytime backup camera system that merges both camera signals into a toggle switch.
    No real need to replace the OEM backup camera as its plug and play for the headunit, I have seen people try to get a better resolution camera, but I dont think they had good luck and ended up with worse resolution.
    BTW, I too wanted to get the halo from alpine, but in the end I didnt want the screen sticking out, I didnt want the alpine branding sticking out to show people I have aftermarket. I wanted everything to fit as clean and flush and factory as possible.
  11. Nov 22, 2019 at 10:32 AM
    #371
    bryanptn
    I have both a front and rear camera through the anytimebackupcamera switch with the Joying HU. The HU cannot switch between the front and rear without an external switch (anytimebackupcamera).
    As for an aftermarket back up camera, I've tried that with a custom 3d printed mount. The quality was better with the stock camera, which is not very good.
  12. Nov 22, 2019 at 11:31 AM
    #372
    lilmike
    lilmike Well-Known Member
    '20 TRD OR DC SB
    vFTuned, Android, MESO Stuff
    @5nahalf Any issues with the Joying HU? How are the operating temperatures? Any problems with thermal throttling and overheating?
    I am pretty familiar with Joying. Unfortunately, I did not have all that great of an experience with them in the past. I had two of their other android HUs in my previous vehicle, neither one lasted a year. One had a screen that would cut out intermittently, the other one overheated and would start rebooting within a half hour, even faster if I was running maps. Replaced the second Joying with a Pumpkin (where do these brand names come from??) and that has been utterly flawless, so I know that these head units can be amazing. Based on a couple bad head units, I am just a little gun-shy of the Joying brand.
  13. Nov 22, 2019 at 11:40 AM
    #373
    5nahalf
    Erik
    Minnesota
    Sofar everything is running good. google play music was having a crashing fit the other day, but that seems to of resolved itself.
    Though I will say I have grown a bit tired of the interface on the unit, I feel like all of the audio sources should be skinned and reorganized for a android headunit. Many of them just are not very driving friendly, my music apps dont have a dark theme, so at night its a white screen thats blinding.
    I am on the search for something else now, something better. Im not sure if I will be going with another android unit (9.0 would be nice) or if I will be switching over to one of the name brand car headunits and just running carplay.
    I would really like to see a headunit that has some rgb outputs with zones (footwell, rock lights, underglow, that kinda crap) along with some customization to match the truck.
  14. Nov 22, 2019 at 11:51 AM
    #374
    lilmike
    '20 TRD OR DC SB
    Thanks, that is good to hear. I'm seriously considering waving one in, though I am also looking at the Dasaita (sp) one too, as well as some of the aftermarket options.
    I completely agree with you when it comes to the apps and appearance. To be honest, though the hardware is solid, the interface on the Pumpkin is even worse than it was on the Joying and I have less options for customization. I switched to using AutoMate for a frontend, that seems to work pretty well.
  15. Nov 22, 2019 at 2:39 PM
    #375
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Great thread! Thanks to all for working through the issues.
    To throw out another option (even though i'm 2nd gen), I purchased and installed an ATOTO android double din unit in my '11 w/JBL last year:
    https://www.amazon.com/dp/B079D1KN7B/ref=cm_sw_em_r_mt_dp_U_82f2Db25XVYF6
    I added the Metra JBL amp interface:
    https://www.amazon.com/dp/B00133RCCC/ref=cm_sw_em_r_mt_dp_U_M4f2Db5D4VSAG
    The ATOTO had wiring to integrate the steering wheel controls, so I didn't have to add anything for that.
    I was able to connect the factory back up camera, and I also added a front camera in the grill. ATOTO has a built in DVR for an ATOTO dash camera:
    https://www.amazon.com/dp/B01LWW5S3E/ref=cm_sw_em_r_mt_dp_U_n9f2Db8AD4174
    I've done 2 software updates so far with no issues, and I've loaded every app I wanted, including kodi. I plan to delete the JBL eventually. These android head units are great!
  16. Nov 29, 2019 at 10:04 AM
    #376
    lilmike
    '20 TRD OR DC SB
    5nahalf[OP] likes this.
  17. Dec 7, 2019 at 9:50 PM
    #377
    taco-baja
    taco-baja Member
    Miguel
    2019 Tacoma TRD sport
    Hello Selkiesa, have a the same problem with my 2019 Tacoma with JBL, the fade control does not work correctly, one thing I noticed when I found out about this problem, I re-connected back the OEM radio,
    the fade control works good on the OEM radio,
    while I had the OEM radio connected and running all speakers "normal" I disconnected the "blue" connector that connects to the green and purple wires ( Joying rear speakers)
    but the rear speakers still sound good.
    I know this is confusing but to me that means that the "blue" connector is NOT for rear speakers. In other words the the green and purple wires coming out
    of the Joying unit are not connected anywhere.
    I been trying to find a drawing for the wiring of the JBL system,
    but anyway, I noticed your post in this thread are from back in July - 2019, did you find a solution?
    Thank you
  18. Dec 7, 2019 at 10:11 PM
    #378
    taco-baja
    taco-baja Member
    Miguel
    Hello lilmike, I installed this same model Joying radio on my 2019 Tacoma with JBL audio system, I'm having problems with the rear speakers not working properly, but if your truck does not have JBL system the radio works perfect.
  19. Dec 7, 2019 at 11:00 PM
    #379
    taco-baja
    taco-baja Member
    Miguel
    Hello Erik, do you know what APP is that?
  20. Dec 7, 2019 at 11:06 PM
    #380
    taco-baja
    taco-baja Member
    Miguel
    Hello marrone04, do you know if this harness will work on the Joying radio on my 2019 tacoma with JBL audio system? like most people on this thread, I have the problem with the rear speakers not working properly.
    Thankyou
