3rd gen audio build - Joying tacoma headunit
Discussion in 'Audio & Video' started by 5nahalf, Nov 8, 2018.
  1. Jun 8, 2020 at 7:51 PM
    #581
    vaughnjeremy27
    vaughnjeremy27 Member
    Jeremy
    Near Nashville TN
    2008 Trd Off Road
    None
    Yep. I updated to the newest firmware and it works great now. I should have just done that first. Thanks for the input and thanks for keeping up with this great thread.
    5nahalf[OP] likes this.
  2. Jun 8, 2020 at 8:40 PM
    #582
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    @5nahalf What are your thoughts on the audio processor on the joying unit? It seems like you upgraded everything together so I dont know if you can compare this one to the factory one. I upgraded my speakers, and I have my front speakers running off a 4 channel amp, it sounds pretty decent but I wanted to upgrade the headunit and I've had my eyes on this one for about a year, I'm still a little undecided since it's chinesium and I dont know if I'm better off getting a brand name head unit or not.
  3. Jun 8, 2020 at 9:42 PM
    #583
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    First, pretty much all headunits are made in china, some just cost more than others.
    As for the sound quality, im not sure since Its all run through my DSP. But I ran its internal amp for a day, its way louder than the OEM radio, I never really got past volume 5, with my DSP I can get up to volume 20 before its too loud ( I like to have many steps between off and full volume )
  4. Jun 8, 2020 at 9:48 PM
    #584
    Sep1911
    2016 Taco
    I’m new to this car audio stuff. Doesn’t the head unit still process the audio before sending it to an external amp through the 4v RCA output?
  5. Jun 8, 2020 at 9:51 PM
    #585
    5nahalf
    Erik
    Minnesota
    Yes it does, I guess i dont have a good answer for you then as I have only run it from the headunit to the DSP then to the amps. The output looks pretty good coming into the DSP, but I dont have much to compare it to as the last system I installed was around 2001.
  6. Jun 8, 2020 at 10:48 PM
    #586
    Sep1911
    2016 Taco
    My friend has a kilpsch sound system at his house and man is the sound quality breath taking. It’s my latest obsession lol. But yeah, just trying to put together the best setup possible.
  7. Jun 10, 2020 at 8:19 PM
    #587
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Anyone beem able to get Google assistant calling enabled?
    I downloaded and installed the 2 latest updates from Joying which mentioned it but calling still doesn't work with voice control..
  8. Jun 11, 2020 at 10:55 AM
    #588
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I can experiment on my unit tonight and let you know. On Carplay, I've been using "Hey Siri" which works well. Wish I could map my voice button on steering wheel to Siri though
  9. Jun 11, 2020 at 4:00 PM
    #589
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Anyone get this to work on a 2019 or newer? Joying just sent me a new unit that was a "US Version." I just messed around with it for about 2 hours. All the major issues I was having with the previous unit seems to be gone but I still can't get the steering wheel controls or the cameras to work. Haven't tried the firmware yet but there's too many sayings of "it worked right out of the box" for me to want to do that already. I tried a few different Canbus settings and nothing worked. One even made it worse.
  10. Jun 11, 2020 at 4:11 PM
    #590
    5nahalf
    Erik
    Minnesota
    Did you get the can-bus version?
    If you did, there are car settings to select your car. I used 2013 rav4 of my car and the things work.
    Your camera may not be plugged in right. Check to make sure its plugged in.
  11. Jun 11, 2020 at 4:26 PM
    #591
    shaggy135
    Yes I got the canbus version. And yes the camera is plugged in correctly. None of my steering wheel controls work at all. Which exact settings for the RAV4? And is yours a 2019 or 2020?
  12. Jun 11, 2020 at 4:39 PM
    #592
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    2019 here. You can go in and mess with your wheel settings.
  13. Jun 11, 2020 at 4:41 PM
    #593
    5nahalf
    Erik
    Minnesota
    I have a 2018, same radio as the 2019. Mine doesnt support the tacoma, so I have to select rav4 as my model for the canbus system. The new models may support tacomas, but if your controls dont work then chances are you dont have a car selected.
  14. Jun 11, 2020 at 7:04 PM
    #594
    shaggy135
    And was that with the canbus settings set as XP->Toyota->Else->XP2013?
  15. Jun 11, 2020 at 7:07 PM
    #595
    5nahalf
    Erik
    Minnesota
    Im on the most current firmware, but the original model from last year. Yours may look a little different
  16. Jun 11, 2020 at 7:17 PM
    #596
    5nahalf
    Erik
    Minnesota
    This one also works too
  17. Jun 11, 2020 at 9:37 PM
    #597
    shaggy135
    I'll give it another go some time this weekend and see what happens.
  18. Jun 14, 2020 at 8:28 AM
    #598
    5nahalf
    Erik
    Minnesota
    I figured out a easy way to pull the bottom of the screen all the way into the bezel for those of you who have the lip at the bottom.
    Put some painters tape under the bottom of the radio, it will give you a little pull tab that you can use to pull the radio out and flush with the bezel. then pull at a angle and the tape comes off.
    vaughnjeremy27 likes this.
  19. Jun 15, 2020 at 8:43 AM
    #599
    shaggy135
    I guess it's just my truck? Tried all the above Canbus settings. No matter what, steering controls don't work, backup cam doesn't either. And unless I finagle the wiring, the volume always goes up by itself and it forces the screen to phone app. Even without the phone connected.
  20. Jun 15, 2020 at 8:44 AM
    #600
    5nahalf
    Erik
    Minnesota
    Double check all your connections, perhaps the canbus module is not seated all the way or there are some crossed wires somewhere.
