3rd gen audio build - Joying tacoma headunit
Discussion in 'Audio & Video' started by 5nahalf, Nov 8, 2018.
  1. May 8, 2021 at 8:28 AM
    #861
    Tstewart_1
    Tstewart_1 Well-Known Member
    Tyler
    Okay ill give this a shot. I left the gps antenna inside the dash, read about another member doing it and not having any issues. Do you think thats my issue? It shows on those photos I sent that its picking up 5-7 satellites. But on maps it doesnt follow me unless it gets wifi i.e hotspot my phone or the city wifi from cox internet.
    Also has anyone figured out the Celsius to fahrenheit change?
  2. May 8, 2021 at 8:31 AM
    #862
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have mine under dash on top of unit wedged lol I pick up 11 to 14 satellites most of the time
  3. May 8, 2021 at 8:39 AM
    #863
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I stuffed mine inside the dash for the first year. Then when I wired up some switches overhead I moved it up there.... didnt notice any changes in satellites though.
    shotgunbilly420 likes this.
  4. May 8, 2021 at 10:35 AM
    #864
    Tstewart_1
    Tyler
    Which wire do you cut for the grid lines? I’ve got 2 sets on rear view right now. Instructions didn’t state anything
  5. May 8, 2021 at 11:12 AM
    #865
    5nahalf
    Erik
    Minnesota
    No cutting, its a setting in the settings.
  6. May 8, 2021 at 12:05 PM
    #866
    Tstewart_1
    Tyler
    In the vehicle setup area? I never found anything for it. Im not sure if I am just dense or what. I went through it multiple times.
    Also in the vehicle setup, I cant turn on or off anything. Like for instance, locks engaging in D vs at a speed.
    I've also come to resolve the gps issue, i think under the dash is hindering me, it loses signal alot and jumps all over. I ordered a adapter to use factory one
  7. May 8, 2021 at 12:11 PM
    #867
    5nahalf
    Erik
    Minnesota
    I dont remember where it is in the settings, but I do remember that nothing in the settings makes sense. I want to say it was in the password protected settings page, but not sure.
    As for the vehicle setup part, nothing in there is really working since the headunit is not actually made for our trucks. We are waiting for joying to issue us a real canbus integration for the tacoma... so eventually we will get something.
  8. May 8, 2021 at 1:54 PM
    #868
    Tstewart_1
    Tyler
    Im glad you brought that up, what the heck are the passwords? I tried the 8086 and 8083 and some other thats something like 3006. Nothing worked.
    Ah, thats slightly annoying. The doors locking as soon as I put it in D drives me nuts. I pull out of the garage to let the lady in and its locked always now.
  9. May 8, 2021 at 2:51 PM
    #869
    5nahalf
    Erik
    Minnesota
    3368 I think.
  10. May 8, 2021 at 3:11 PM
    #870
    DC4L
    DC4L Well-Known Member
    Todd
    Waco, TX
    2016 MGM TRD Sport 4x4 Access Cab
    BDS 6" w/coilovers|18x12 Fuel Maverick|33x12.5 Atturo Trail Blade XT|CCG grill|Morimoto fogs|OPT-7 redline triple tailgate bar|BAK Revolver X4|ANSO Smoke 3rd brake light|Anzo TRD Pro taillights|Redline Tuning Quicklift|MBRP S5340BLK exhaust| Matt Gecko hood/bed led's|Gasshole|Ultimate dome/map lights|Ultimate LED turn signals|Gentex Homelink|
    5nahalf is correct
    5nahalf[QUOTED][OP] likes this.
  11. May 8, 2021 at 5:20 PM
    #871
    shotgunbilly420
    Please share adapter
  12. May 8, 2021 at 6:45 PM
    #872
    5nahalf
    Erik
    Minnesota
    Towns81 likes this.
  13. May 8, 2021 at 8:49 PM
    #873
    tacoWithstickyrice
    tacoWithstickyrice Well-Known Member
    '19 DCSB TRD OffRoad 4x4
    I do have this one installed in mine and when I was using the one that comes with the radio I was getting 10+, with OEM antenna I usually get 5-9. But it still works fine for me so I haven't had an issue.
    I found I couldn't get any of the settings to work on the setup screen of Car Info but I was able to hook my car up to techstream and change things that way.
    For Celsius to Fahrenheit, it's in one of the options but can't remember at the moment. I can never remember where each setting is at and end up going through every setting just to find it but it's in there.
  14. May 8, 2021 at 8:51 PM
    #874
    5nahalf
    Erik
    Minnesota
    This is because none of the settings locations make a damn bit of sense :)
  15. May 9, 2021 at 10:16 PM
    #875
    SDMikeTaco
    SDMikeTaco Member
  16. May 9, 2021 at 10:24 PM
    #876
    tacoWithstickyrice
    If I'm being honest with myself, I think I would've just used the GPS antenna that comes with the radio. I didn't buy the one you have, I bought the adapter that discountcarstereo makes.
  17. May 9, 2021 at 10:27 PM
    #877
    tacoWithstickyrice
    Also for those that are wondering I double checked and my temp display on the instrument cluster still works. And for the C to F option on the radio, I believe it is in Car Settings, Factory (code: 3368), Original Car Agreement; there are a number of things you change there. I had an issue where the virtual AC panel kept coming up and that was where the setting for it was.
  18. May 11, 2021 at 1:10 PM
    #878
    BobU05
    BobU05 Well-Known Member
    Bob
    Eastern, Iowa
    18' Tacoma TRD Sport 4x4
    Eibach Pro-Truck Lift System (Stage 1) with 18" Fuel Maverick Wheels mounted on 275/65/R18 Falken Wildpeak A/T3W tires. Predator Step Bars. TRD Pro Grill with Raptor lights. TruXedo TruXport Roll Up Tonneau Cover. 15% Window tints all around.
    Anyone have issues with wireless carplay? Mine cuts out often while listening to music. Also, there is an echo while making calls but only on carplay.
  19. May 12, 2021 at 10:34 AM
    #879
    Tstewart_1
    Tyler
    I don’t have those issues with mine. CarPlay works great. Although I still can’t find out where the hell the grid lines removal option is that I went through all the settings I changed that c to f and it didn’t actually change lol. What canbus should we be using? Mines on camry xp
  20. May 12, 2021 at 10:56 AM
    #880
    tacoWithstickyrice
    Sorry can't help you with this since I don't use carplay or android auto for that matter. But might be something you can shoot an email to Joying, it seems like they are pretty responsive?
    If you have the latest version of the OS (android 10?), check in Settings > Factory (code 3368) > Original Car Agreement. I thought I saw a bunch of stuff related to reverse lines or something like that. I am using Hilux for my vehicle setting/canbus. OCA is also where I changed my temp setting as well but I use the one on my cluster, which seems to be more accurate.
