3rd gen audio build - Joying tacoma headunit
Discussion in 'Audio & Video' started by 5nahalf, Nov 8, 2018.
  1. Mar 31, 2022 at 12:29 PM
    #1421
    Windmill
    Windmill Active Member
    2018 TRD Sport
    I got this in my truck today. I had no idea what I was looking at, so I just plugged in what fit. Took me a minute to figure out the backup camera, which is basically connecting two RCA plugs from the Joying harness together. I also connected the provided GPS antenna. Everything seems to work, so I assume it's hooked up correctly. There were two small wires from the Tacoma that I left loose. I assume one was GPS. There was quite a bit from the back of the unit that wasn't hooked up to anything. Any info on anything I may have missed here is appreciated. I should add that I did not use the external mic since I didn't have time to run it. I did take a couple calls from the built in mic through CarPlay and was told it sounded good.
    Once it was hooked up, I went into the various settings. I reversed the track skip, changed to Fahrenheit, set to launch Carlink on startup, changed driver door to left (no idea what this is about), changed can bus to Rav4, and looked through everything else for relevant settings. I still don't know what most of it does. Maybe one day. For now, I turn on the ignition and the CarPlay screen comes on, and that's all I will likely ever need from it.
    I was worried about sound from comments I've seen, but this seems to sound a little better than the Entune; the sound settings are certainly more thorough. I will probably put a component system up front soon, but I feel like this is fine for my listening purposes. I have an audiophile system for music in my house, but I really don't care much about car audio these days.
    The bottom bezel is just barely pushed in due to having only two screws in the brackets. I'd like to figure out to get that perfectly flush, but it's barely noticeable to me when I look at it; no one else would notice.
    For me, this is a CarPlay module with a large screen that fits the factory cutout and retains vehicle settings (aside from music and nav screens in the instrument cluster). I would have to spend over $1000 plus Maestro to get that from a name brand. If it lasts and isn't glitchy, it was an excellent purchase. Time will tell.
    CaliTaco718 and shotgunbilly420 like this.
  2. Mar 31, 2022 at 1:37 PM
    #1422
    Windmill
    2018 TRD Sport
    I'm using Rav4 right now. I'd like to know if anyone knows which is best.
  3. Mar 31, 2022 at 2:44 PM
    #1423
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I feel the same way . I've had my unit for a 1yr now and still loving it .
  4. Mar 31, 2022 at 6:30 PM
    #1424
    CaliTaco718
    CaliTaco718 Instagram: socalmike9000
    Chapel HIll, TN
    2019 TRD Sport DCSB 4x4 MGM
    Falken AT4's.
    Hilux seems the most legit to me. Also fixed the radar sensors on backup screen to show in the rear.
    jdmjustin and shotgunbilly420 like this.
  5. Mar 31, 2022 at 6:41 PM
    #1425
    Windmill
    2018 TRD Sport
    i guess I haven’t gone through the different can box types. I think I’ve only seen the ones in xp. I’ll look again tomorrow.
    My radar doesn’t currently show anything on either end. I don’t even know if I have sensors in the rear. I’m sure someone else would know.
  6. Mar 31, 2022 at 9:53 PM
    #1426
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    While I am not using my headunit right now (doing some mods to it) I still love the thing. The OEM just has so many issues.
  7. Apr 1, 2022 at 5:03 AM
    #1427
    jdmjustin
    jdmjustin Well-Known Member
    Justin
    SW MO
    2018 BBP Tacoma Sport
    Motegi MR149 17x8.5 Falken Wildpeak 265/70/17 Toytec Aluma 2.0
    I'm having this strange issue, that I highly doubt anyone else will. I'm diabetic and have other bluetooth devices synced to my phone. My CGM (Dexcom) syncs every 5 min. During that time my audio will pause and or skip for 3-5 sec. It's very strange because it never really did it before, only recently. My CGM isn't connected to my headunit. I almost think it's my bluetooth connection messing with the wifi connection for carplay.
    It got to the point yesterday on a 30 min drive, just skip/pause every 5 min. Then randomly it rebooted itself about 20 min in. Since then, it's been fine. Just found it to be strange.
  8. Apr 1, 2022 at 11:35 AM
    #1428
    CaliTaco718
    Chapel HIll, TN
    Falken AT4's.
    Folks who are using Android Auto, can the taskbar be moved to the bottom?
  9. Apr 1, 2022 at 12:07 PM
    #1429
    Windmill
    2018 TRD Sport
    I played around with the can box types. I’m having good luck with XP-Camry-18 so far. Hilux has AC controls popping up on the screen that my truck doesn’t support.
    I also realized that setting the driver door side orientates the controls on the screen.
    CaliTaco718 likes this.
  10. Apr 7, 2022 at 8:26 PM
    #1430
    Tx16Tacoma
    Tx16Tacoma Member
    Texas
    2016 Magnetic Grey
    Is anyone having issues with the MPG being off?
    Mine is reading 24-27 MPG and i know that's not right. I double checked the manual way the last 2 times i filled up and i am getting 20 MPG.
  11. Apr 9, 2022 at 8:46 AM
    #1431
    AJames90
    AJames90 Member
    Does anyone know if it is possible to somehow change the radio app/interface ? It's supposed to show the song and artist of what's playing, but it's all glitchy and doesn't really work. Not a huge deal but it drives me crazy when I have the radio on...
  12. Apr 9, 2022 at 9:07 AM
    #1432
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    If the carplay app is on auto connect it turns off the wifi to connect to the phone. The wifi also has an auto connect option and ive seen it flip back and forth. The only way I could get the carplay to leave the wifi alone was turning off the bluetooth on my phone.
  13. Apr 9, 2022 at 9:10 AM
    #1433
    spamy
    spamy Truck guy
    NorCal
    Maybe it was just an earlier version of the joying, but people had been saying that the music doesnt show up right when looking at a USB drive.
    I use blackplayer music player app and with it you can see all your music on a USB or hard drive by artist, album, song, etc. Works great for me. You can make up playlists and so on.
    Also, being that this is running android, if you want something custom, its not impossible to make an app that does exactly what you want. I had made 2 or three apps to do what I wanted. If you dont have the skills but know what you want you can have someone else design if for not a ton of money. Then you can have just what you want.
  14. Apr 9, 2022 at 10:51 AM
    #1434
    JCTacoma330
    JCTacoma330 Well-Known Member
    Justin
    2019 Black Tacoma DCSB OR MT
    None
  15. Apr 11, 2022 at 8:19 AM
    #1435
    jdmjustin
    Justin
    SW MO
    Ordered a MB Quart powered sub yesterday. Being a non-jbl truck, I felt I needed something. I do not recall there being a remote turn on output for the amp. Can anyone clarify this?
  16. Apr 11, 2022 at 8:59 AM
    #1436
    Tx16Tacoma
    Tx16Tacoma Member
    Texas
    2016 Magnetic Grey
    is anyone else having this issue?
  17. Apr 11, 2022 at 9:08 AM
    #1437
    5nahalf
    Erik
    Minnesota
    Im going to say this is probably due to the lack of actual canbus decoding for the tacoma. In order to get the steering wheel controls to work, we use the canbus settings for other toyotas. So its probably a miss calculation on part of the canbus.
  18. Apr 11, 2022 at 9:10 AM
    #1438
    jdmjustin
    Justin
    SW MO
    Unfortunately I can't turn it off, due to the medical devices I have sync'd to my phone. Guess I'll have to live with it.
  19. Apr 15, 2022 at 12:38 PM
    #1439
    Windmill
    2018 TRD Sport
    There is an amp on/off setting in there somewhere.
  20. Apr 18, 2022 at 6:50 AM
    #1440
    jdmjustin
    Justin
    SW MO
    Ended up not needing this feature. I found a ign switch trigger wire in a unused portion of the harness.
