3rd Gen Audio Build
Discussion in 'Audio & Video' started by MESO, Aug 19, 2016.
  1. Aug 19, 2016 at 5:08 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Finally got around to finishing my audio system for my 3rd gen.
    components:
    Front:Kenwood XR-1800P components
    Rear: Disconnected
    Sub: Kenwood Excelon XRW-1002 2Ohm 10"
    Amp: Kenwood Excelon XR9005
    Enclosure: Custom Fiberglass/MDF
    Processor: AudioControl LC7i
    Wire: Stinger PRO
    RCA's: Stinger PRO4000
    The Goods:
    Fiberglass box process:
    Installed;
    The signal was tapped from the front tweeters, ran into the audiocontrol, then to the Kenwood amplifier. The amp is running in 3 channel mode CH1+2 bridged to Front left, CH3+4 bridged to Front right, and CH5 to sub.
    It's a tight fit, but it clears!
    Pictured: Amp/processor/crossovers
    Door speaker adapters were cut out of 3/4" MDF and coated in underbody spray for water protection. Tweeter adapters were out of 1/4" ABS
    (pink connectors; signal from stock stereo)
    (blue connectors: new Tweeter wires)
    Just like factory!
    Doors were sound dampened on both inside and out. Adapters were mounted with bolts/nylon lock nuts/washers.
    Mounted up:
    I am waiting on my ACR-1 Bass knob, which will be mounted in the cubby pocket.
    Final thought:
    100X better then stock. Awesome mids, smooth blend with the sub, highs are a little bright(also since they moved location from door panel to dash on the 3rd gens)
    I have heard the JBL, and this blows it away.
    Best part...you look inside and everything looks 100% factory
    CHEERS!!:cheers::cheers:
  2. Aug 19, 2016 at 7:37 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Impressive work on the enclosure. I wish I had teh fiberglass skillz.
  3. Aug 19, 2016 at 9:53 PM
    JasonT87
    JasonT87 Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    No factory JBL? Must've been easy
  4. Aug 19, 2016 at 10:17 PM
    MESO
    State of Jefferson
    Piece of cake. Didn't even take the radio out. I specifically did not want the JBL because they are trickier to integrate with and I could build a system twice as good for half the price.
    Overall I'm loving it. Still need to go through and dial it all in.
    Pray4Mojo and Aw9d like this.
  5. Aug 20, 2016 at 2:18 PM
    MESO
    State of Jefferson
    Removed the useless cubby and fabed up a plate to mount the bass knob.
    Pray4Mojo, My4thTacoma, ATR55 and 3 others like this.
  6. Aug 20, 2016 at 2:19 PM
    Aw9d
    Aw9d That one guy
    Nice build. If you can make those fiber glass boxes pretty easy I'd look into selling them on here. That would be a hot item for many.
    ratcityrain likes this.
  7. Oct 4, 2016 at 3:22 PM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Very well done on the fiberglass enclosure
  8. Oct 5, 2016 at 10:34 AM
    jmeitz
    jmeitz Audio Solutions
    Jeremie
    St. Louis, MO
    2016 Tacoma trd sport
    Remote Start Lift Stereo Leather LED lights
    Nice enclosure.
  9. Dec 13, 2016 at 5:18 PM
    zackdippolito
    zackdippolito Well-Known Member
    zack
    2012 SR5/2014 TRD Sport/2017 TRD Sport 6M
    Nice build man. Looks very stealth and clean
  10. Dec 25, 2016 at 5:53 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    nice job. i made a fiberglass box about 13 years ago and ended up needing WAAAY more fiberglass than I budgeted for. how thick did yours end up and where did you buy the mat and resin from?
  11. Dec 29, 2016 at 3:25 AM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
    Did you have to cut out the hooks on the cab wall?
  12. Dec 31, 2016 at 8:09 PM
    MtnBiker831
    MtnBiker831 Well-Known Member
    Santa Cruz, CA
    17 Trd Pro
    Audio, lots of it
    Any idea of airspace on the sub enclosure?
  13. Dec 31, 2016 at 9:15 PM
    MESO
    State of Jefferson
    .80ish Cu.Ft
  14. Dec 31, 2016 at 11:22 PM
    MtnBiker831
    Santa Cruz, CA
    17 Trd Pro
    Audio, lots of it
    Thanks. Enclosure looks great!
    Alexk3303 likes this.
  15. Jan 1, 2017 at 6:10 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Very nice and clean install. Do you have the amp and the DSP under a seat?
  16. Feb 18, 2017 at 4:55 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Well done Meso.
    Do you do this for work?
  17. Feb 18, 2017 at 5:00 PM
    MESO
    State of Jefferson
    solscooter and EB Group[QUOTED] like this.
  18. Feb 18, 2017 at 5:03 PM
    EB Group
    Rudy
    Halifax
    Kool, lol
    I use to as well for about a decade. I have recently gotten into mould making and using carbon fiber.
    I am contemplating making a mould for a sub enclosure and having a carbon fiber front.
  19. May 8, 2017 at 9:03 AM
    artesho
    artesho Well-Known Member
    Randy
    This is a clean setup! I've been seeing all your work and I am completely impressed @mesojdm
    I'm going to be doing my BHLM soon and audio upgrades. Did this enclosure setup limit you on subwoofer selection? Or did you have a sub in mind and design this enclosure around it?
  20. Jan 20, 2018 at 5:37 AM
    Cough*Strawberry
    Cough*Strawberry Active Member
    Traveler
    2018 Tdr Sport 4x4 MT
    What products did you use for sound damping? Does it make a big difference? Also did you do the entire cab or just the doors? First time I’ve considered this, and I’m leaning towards second skin. Just have no experience and there are way to many opinions on other forums about it. Thanks in advance.
