3RD GEN AUTO TRANS FLUID CHANGE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PB FAB, May 11, 2018.
  1. Apr 19, 2019 at 8:32 PM
    #41
    craig431
    craig431 New Member
    Craig
    2013 Tacoma Crew Cab
    I have a 2013 Tacoma Pre runner double cab. I went to the parts dept at my Toyota dealer and they sold me 5 quarts of fluid and a crush washer. I was going to change it myself, but I had other issues I needed to take care of. My dealer said they would still use the fluid I purchased from them and just charge me labor. They only used 3 of the 5 quarts. Either they up sold me on the fluid, or I got a half @ss job from the dealer on the fluid change. I've been trying to find out how many quarts is required for a fluid change but haven'r found any info. I'm going to call them back next week and ask how many quarts it takes. Either way I have an issue with them. Every video I've seen requires 5 plus quarts for a flush and fill.
  2. Apr 19, 2019 at 10:39 PM
    #42
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    You likely paid for a drain and refill. Not a flush. Two separate jobs that use very different quantities...3-5qts and around 3x that.
  3. Aug 12, 2019 at 5:57 AM
    #43
    underdog493
    underdog493 Active Member
    Kansas
    16 DCSB TRD OR WHITE
    #43
  4. Aug 12, 2019 at 7:18 AM
    #44
    PB FAB
    PB FAB [OP] Well-Known Member
    2017 SR DCSB 4x4 v6
    First time I’ve seen that kit. Don’t know anything about it. It would be nice if there were more pictures or instructions.
  5. Aug 21, 2020 at 8:56 PM
    #45
    TheOtherSideOfThePillow
    TheOtherSideOfThePillow Well-Known Member
    Kurt
    WA
    2017 Tacoma TRD OR DCSB MGM
    I'm about to do the flush...but still unsure about the correct cooler line to unhook and drain from. Is it the same one as the 2nd Gen DIY link? Just want to make sure I get the right one. Already messed up one part (over torque on the drain plug, so I need a new pan)... so hoping to avoid any other mistakes.
  6. Aug 21, 2020 at 8:58 PM
    #46
    Bishop84
    Bishop84 Well-Known Member
    It'd be best to leave it alone, the pan drop when you replace it will get rid of tons of fluid.
    If you are really set, its the 2 rubber hoses that lead to the trans cooler near the oil filter.
    The oil filter itself has 2 coolant hoses don't touch those.
    AxisCab and Skydvrr like this.
  7. Aug 21, 2020 at 8:59 PM
    #47
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    On the trans? I thought the filter was internal
  8. Aug 21, 2020 at 9:01 PM
    #48
    Kurt
    WA
    That's a good point. Might just do that. There was a lot more fluid in the pan that I expected when I dropped it. Should still be able to get a good amount of new fluid in the system. I'll decide when I get the new pan.
    Thanks!
  9. Aug 21, 2020 at 9:02 PM
    #49
    Bishop84
    I mean engine oil filter as a reference point.
  10. Aug 21, 2020 at 9:21 PM
    #50
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Ahh I see.
  11. Sep 19, 2020 at 12:15 PM
    #51
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Thread revival
    Speaking of pan drops I need to do one
    I'm about to snag a new pan from toyota, I'm back and forth on using liquid gasket or whatever part toyota uses as OEM
    Grab some WS ATF (looking at aftermarket but decided I don't want to mix ATF so ill probably stick with partial synthetic OEM)
    Anything else I need? I've heard the filter ought to be fine and leave it (should just be a metal screen)
  12. Sep 19, 2020 at 12:20 PM
    #52
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I've heard the same about the screen filter. Imma throw some lubeguard as recommended by @gearcruncher. Does Toyota use FIPG for the pan? Supposedly the Toyota orange fipg is the shit.
  13. Sep 19, 2020 at 5:33 PM
    #53
    gearcruncher
    Canadain bumper technician
    Lubeguard is a great idea .
    The Platinum works best with the AC60 series transmissions .
    Grab a 10 ounce bottle and throw it in
    https://www.amazon.com/Lubegard-63010-Platinum-Universal-Protectant/dp/B002MB57UI/ref=sr_1_2?crid=32O2MYEYW4YFR&dchild=1&keywords=lubeguard+transmission+additive&qid=1600561650&sprefix=lubeguard+%2Caps%2C188&sr=8-2
    I highly suggest soaking your pan bolts in lube a couple weeks before you drop the pan . Getting a lot of PM,s from members breaking pan bolts on the 6 speed auto . Make sure you have some never seize on hand to coat the threads before you put the pan bolts back in .
    On another note , why not grab a pan gasket . They are only 5 bucks .
    I hate scraping dry silicone off an aluminum transmission case.
    If you guys are keeping your trucks for a while , using a cork pan gasket is going to save you some greif
  14. Sep 19, 2020 at 6:01 PM
    #54
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Those 3m roloc bristle discs make quick work of that stuff
    gearcruncher[QUOTED] likes this.
  15. Mar 5, 2022 at 3:08 PM
    #55
    chettytac
    chettytac Well-Known Member
    chet
    2009 Toyota Tacoma Access Cab v6 4wd
    The hoses you referring to are the hose going to the trans cooler under the splash pan.
  16. Mar 5, 2022 at 5:44 PM
    #56
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    The system’s capacity is 10.6 quarts.
    Each drain and refill will be approximately 3.5 quarts. HOW MUCH of the old fluid you’d like to remove depends on the number of drains and refills. See below.
    • The first drain replaces 3.5 of the total capacity of the 10.6 quarts which is about 33% replaced.
    • The second drain of 3.5 quarts will remove about another 2.2 quarts of the old fluid giving you about a 54% replacement at this point.
    • The third drain of 3.5 quarts will remove about another 1.6 quarts of the old fluid giving you about a 69% replacement at this point.
    • The fourth drain of 3.5 quarts will remove about another 1.0 quart of the old fluid giving you about a 78% replacement at this point.
    • The fifth drain of 3.5 quarts will remove about another 0.7 quarts of the old fluid giving you about a 85% replacement at this point.
    • A sixth drain of 3.5 quarts will remove about another 0.25 quarts of the old fluid giving you about a 87% replacement at this point.
    This means it will take 6 drains, or 21 quarts, to replace approximately 87% of the old fluid. This is precisely WHY I perform ONE drain and refill [4 quarts] every 20,000 miles. Doing it this early means fewer overall drains than otherwise needed to keep the transmission void of very old fluid.
  17. Mar 5, 2022 at 6:01 PM
    #57
    chettytac
    chet
    Ok, I want to do one flush by removing the inlet and outlet hoses and run the truck until I see fresh fluid. My truck has a 153000 miles and no history of fluid change and I starting to feel some tyranny issues
    AxisCab likes this.
  18. Mar 5, 2022 at 6:13 PM
    #58
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    Just did this to mine today… did three drain and fills an used ~10 quarts. By the third time fluid was coming out pretty red, happy about it. Truck has 76k.
    mquibble likes this.
  19. Mar 5, 2022 at 6:18 PM
    #59
    chettytac
    chet
    How did you do it, by draining from the the trans pan and refill it. Did you drive the truck after every drain or just move the selector and and drain.
  20. Mar 5, 2022 at 7:33 PM
    #60
    dezert.taco
    Nate
    Northern Nevada
    2018 Tacoma
    Yeah, drained through the drain plug an adjusted through the plug with the standpipe. And both, drove the truck down the driveway an back an also cycled through the gears for about a minute. Took about 5 hours all together mostly allowing everything to cool down each time.
