3RD GEN AUTO TRANS FLUID CHANGE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PB FAB, May 11, 2018.
  1. May 9, 2023 at 5:06 AM
    #81
    Dehley23
    Dehley23 New Member
    So I have 2016 Tacoma it has 85k miles on it it’s never had the transmission oil changed, does it need to be changed
  2. May 9, 2023 at 5:31 AM
    #82
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you can DIY it’s not that difficult to do a drain and fill once a year for the next 3-4 years (assuming an automatic trans).
    Dehley23[QUOTED] likes this.
  3. May 11, 2025 at 2:38 PM
    #83
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Are you supposed to drop the pan and swap/clean the filter and screen when changing the fluid or just drain and fill?
    Drain and fill is easy, dropping the pan would be a bit harder for me as the truck is too large for the garage so I'd have to drop down some taps and walls to prevent dirt from getting blown into it when exposed
  4. May 11, 2025 at 5:25 PM
    #84
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Just drain and refill if your intervals are not long. I personally would drop the pan and replace the filter if I were to ever exceed 60k miles between drains.
