3rd Gen Automatic to manual swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eagleye_Eighty, Oct 2, 2020.
  1. Oct 3, 2020 at 8:33 PM
    #81
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Hey I was wondern if anyone has a suggestion on fitting some 35" tires on my new Prius. They don't make an OR but I just loved em hybrids man. Also thinking about a 12k winch but only if I can run it off the battery pack and if it doesn't make my front end sag or require cutting the bumper.
    BTW, would you go with OEM Tacoma TRD Pro or cheap eBay grill on the Prius? Will it require modifications?
    I searched for the search bar for like a half second but couldn't find it.
    #81
    Boghog1, TurdTaco64 and BillsSR5 like this.
  2. Oct 3, 2020 at 9:16 PM
    #82
    Tripod1404
    Tripod1404 Annihilator tripod
    Can someone help me swap two Tesla electric motors to my tacoma?
  3. Oct 3, 2020 at 9:33 PM
    #83
    The_Devil
    E
    I know it works with a 2nd gen. Everything you want to do works with a 2nd gen.
    CygnusX191 and BillsSR5 like this.
  4. Oct 3, 2020 at 9:35 PM
    #84
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Would probably work on a 3rd gen if one of you had the balls to do it. :duel:
  5. Oct 3, 2020 at 9:41 PM
    #85
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You did gen 2. How different is gen 3 with all the changes? If you do junkyard swap from a 2019-2020 then it's fine. Anything else is going to be a problem and costly because electronics.
    CygnusX191, BillsSR5 and GillyLink like this.
  6. Oct 3, 2020 at 9:47 PM
    #86
    The_Devil
    E
    Then again perhaps drinking bleach might cure covid.
    If I wanted a second gen I would have bought one with full time 4x4. Oh ya, I did but it was called an FJ. Cruiser.
  7. Oct 3, 2020 at 9:48 PM
    #87
    The_Devil
    E
    None of that matters because.....balls.
    It takes allot of balls to encourage someone else to make risky foolish modifications to their truck.
    BillsSR5 likes this.
  8. Oct 4, 2020 at 2:30 AM
    #88
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    its amazing that anyone would even take a foolish idea like this and think it can be even become reality, [​IMG]
    The_Devil[QUOTED] likes this.
  9. Oct 4, 2020 at 2:46 AM
    #89
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    OP is equivalent of an ' Atention Getter '
    buys want he doesnt like / want
    takes everyone else to task when they dont agree
    if he were truly passionate about changing reinventing his taco
    he would already be 1/2 way thru his build
    taking photos & accumulating high 5s
    NOT a Starbux argument with everyone that can only see it as an
    as inane &
    an excercise in futilty
    he would already have parts ordered
    grease under his fingernails
    WD40 wafting in the air
    ManInTheMaze and The_Devil like this.
  10. Oct 4, 2020 at 3:22 AM
    #90
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    CygnusX191 likes this.
  11. Oct 4, 2020 at 4:09 AM
    #91
    jschnurr
    jschnurr Member
    Just reading this thread, and honest question here, what exactly is different in the ECMs of the auto vs manual? Presumably, it controls the gear shifts in the auto, but if a manual was swapped in without any changes and it "thought" it was in neutral, and all other inputs were satisfied, then why won't this work with a manual transmission?
  12. Oct 4, 2020 at 4:17 AM
    #92
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I think you are thinking it would be like splicing two wires together with a wire nut to fool it into thinking it's in neutral. I think it would be more like re-writing code and bricking the PCM. The 3G is a computer with a wheel at each corner. OVTune can attest to it's complexity.
    CygnusX191, Boghog1 and chstaco like this.
  13. Oct 4, 2020 at 4:47 AM
    #93
    jowybyo
    Joe
    Baltimore, MD
    WTF are you talking about? Are you intentionally being hyperbolic? How is comparing drinking bleach even remotely the same as doing something that reasonably well documented? The 3rd gen isn’t really much different then the 2nd gen. It’s been done a bunch on a 2nd gen and we can figure out how to do it on a 3rd gen. Also, do you take all comments out of context or only the ones that make you look the most ridiculous?
  14. Oct 4, 2020 at 4:49 AM
    #94
    jowybyo
    Joe
    Baltimore, MD
    I didn’t encourage him to do anything. He asked for information not an opinion. For some reason people around here don’t know the difference.
  15. Oct 4, 2020 at 4:50 AM
    #95
    jowybyo
    Joe
    Baltimore, MD
    The ECM goes in to limp mode if the transmission inputs are missing.
    kahanabob likes this.
  16. Oct 4, 2020 at 4:51 AM
    #96
    jowybyo
    Joe
    Baltimore, MD
    It would likely be easier to swap to the manual version of the ECM. After that it would be exactly like splicing a few wires together.
  17. Oct 4, 2020 at 6:17 AM
    #97
    MDFM31
    Chester Co, PA
    16 DCSBOR
    He asked about using an auto PCM. I don't think anyone knows what a 3G will do. Comparing a 2G PCM to a 3G PCM is like comparing a horse and buggy to a space ship, for better or worse.
  18. Oct 4, 2020 at 6:22 AM
    #98
    Tripod1404
    OP can’t do this. His auto has push start, no manual comes with a push start. So a manual ECM would not work with push start. If you install manual ECM on a truck that has push start it will either not turn on, or act like the truck is broken into.
    OP can also install regular key start( which would be difficult on its own without triggering anti-theft system). But he stated push start is one of the things he liked in his current truck.
    BillsSR5 and The_Devil like this.
  19. Oct 4, 2020 at 6:24 AM
    #99
    jowybyo
    Joe
    Baltimore, MD
    The limited and SR5 both use the same engine ECM (assuming they are both auto). Obviously, the ECM for the manual is different, which wasn't offered as an option on the limited. It still stands to reason that the manual ECM could be swapped in. Still waiting on the full wiring diagram to confirm the push button start among other things.
  20. Oct 4, 2020 at 6:26 AM
    #100
    jowybyo
    Joe
    Baltimore, MD
    Are you taking an educated guess at this or do you know for fact? I don't see why the engine ECM cares whether the 12v signal comes from a key cylinder or from a button. But there could be some hidden crap going on to pass the signal.
