3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Oct 29, 2019 at 4:20 PM
    #181
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    this is my second Toyota with this weird no dipstick checking procedure. I myself know how to check and or change the fluid. when I checked the fluid on my Jan 2019 built Tacoma, when I pulled the check bolt, no oil came out, none. I had to add around 12 oz to make it trickle out correctly, at the correct temp range, so I think that Toyota still may not be filling some of them correctly.
    cryptolyme and Skydvrr like this.
  2. Oct 29, 2019 at 4:27 PM
    #182
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    There is a range, do we know what the range is?
  3. Oct 29, 2019 at 4:27 PM
    #183
    ryan760
    ryan760 Well-Known Member
    Not necessarily. If fluid is coming out of the overflow pipe, then the fluid level is at the maximum acceptable level. There is also a minimum acceptable level, and that's generally 0.5 qt (~16 oz) below the maximum level. If you had to add 12 oz to bring it to the maximum level, then in theory your fluid level was within the acceptable range.
    Vlady likes this.
  4. Oct 29, 2019 at 4:33 PM
    #184
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Idk. If there was that big of a min/max why would they be so adamant about the temperature?
    mallege likes this.
  5. Oct 29, 2019 at 4:41 PM
    #185
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
    Expansion of fluid
    Vlady likes this.
  6. Oct 29, 2019 at 4:42 PM
    #186
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah exactly.
    mallege likes this.
  7. Oct 29, 2019 at 4:50 PM
    #187
    ryan760
    Because temperature significantly affects the volume and therefore height of fluid level in the transmission. If the primary way of checking fluid level right now is by volume, using the overflow pipe as a reference, then the fluid temperature has to match whatever fluid temp the engineers calibrated the height of the overflow pipe to.
    Think about it this way... if the fluid was cold then the fluid height relative to the overflow pipe would be low and you would end up adding more fluid than you needed until. Obviously vice versa for a fluid temp that is too high...
    The ideal way to check would be by weight... actually draining the transmission and weighing what came out. Temperature would not affect this.
    4x4spiegel likes this.
  8. Oct 29, 2019 at 4:54 PM
    #188
    MyWifesTaco
    TRD pro grille .
    I believe the temp is 98 to 115 degrees for the correct temp it's posted above a few posts
  9. Oct 29, 2019 at 4:58 PM
    #189
    Skydvrr
    Nick
    YMH
    Black '17 OR
    No I get that. But if there was a min max of half a quart why bother accounting for the thermal expansion of the oil in the first place?
  10. Oct 29, 2019 at 6:37 PM
    #190
    MyWifesTaco
    TRD pro grille .
    All this is true there are still quite a few variables one of those also being what the individual persons interpretation of the " trickle" draining out of the pan is
    Next issue would be one of the technical guys on here explain or give a example of the expansion per quart ratio it's far above my equating skills but there is a formula
    But I would imagine it's not by very much or there would be quit a issue with bottles of a low viscosity style fluid would be popping or swelling up noticably especially on a hot day in a garage ?
  11. Oct 29, 2019 at 7:02 PM
    #191
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Exactly. So why do we assume there would be such a huge min/max? Toyota calls for a pretty exact procedure to measure. So I'd assume the min / max is a few Oz. Not half a quart haha.
  12. Oct 29, 2019 at 7:06 PM
    #192
    MyWifesTaco
    TRD pro grille .
    The be all end all would have been a simple check at cold fill plug like a transfer case since it's a "pressure " transmission and a simple dipstick would not suffice
    As soon as I do the drain measure and weigh I will post unless someone beats me to it
    Also curious if the 2 wheel is different than the 4x4
  13. Oct 29, 2019 at 7:09 PM
    #193
    Skydvrr
    Nick
    YMH
    Black '17 OR
    But define cold! Cold for Canada, or cold for me in AZ? That's much more than the 20* variance that the book calls for. Keep in mind this just my understanding of it all. I could be way out in left field.
    MyWifesTaco[QUOTED] likes this.
  14. Oct 29, 2019 at 7:17 PM
    #194
    MyWifesTaco
    TRD pro grille .
    Another easy experiment would when "cold" just pull the check plug before pulling the drain to see how much drains out
  15. Oct 29, 2019 at 7:21 PM
    #195
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'm probably gonna do another drain and fill in a month or so. Maybe I'll try this. Theoretically, if u did a drain and fill will the trans was at 190*, u could get a little more out of the pan. Negligible probably tho
  16. Oct 29, 2019 at 7:22 PM
    #196
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Also, if u hit the quote button in the bottom right it'll copy my reply and tag my name too.
  17. Nov 3, 2019 at 11:23 AM
    #197
    jimmerheck
    Vancouver, WA
    Dont burn yourself on the hotter fluid!!!
  18. Nov 3, 2019 at 11:28 AM
    #198
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The reason we “need” this complex process is not just thermal expansion. The transmission has different amount of oil trapped in different passages and galleries depending on what it was last doing when you shut off the truck. It takes ages for all the oil to drain back into the pan. Maybe even days if the truck is sitting.
    Toyota gave us a method to check the level that takes 1/2 hour if the tech knows what he is doing.
    The “cold level” approach would have instructions like “park truck on level surface for 4 days, remove full plug”.
    it’s actually better the way it is.
  19. Nov 4, 2019 at 7:00 PM
    #199
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    Excellent write up and instructional OP, going to do this when I have the time to check my fluid levels as I noticed the harsh downshift when slowing down then giving a little pedal to speed up. Also, if anyone can chime in. How does one use the kit below:
    https://www.ebay.com/itm/Toyota-Lexus-Sealed-Transmission-Fluid-Replacement-Kit-/222731930378
    From the looks of it, would it be worthwhile to do this? Pros and cons?
    I have the Torque app, seen it mentioned that it may work with getting the auto trans temp to get the desired overflow drain point. Any thoughts?
  20. Nov 15, 2019 at 3:55 PM
    #200
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    Huge FYI!!!!!
    The 2020's DO NOT have Pin 13 installed in the ODB connector!!
    If you look at the top row, you'll see that #4 looks different than #3, and #13 is different than #14.
    I pulled the port out to see the wiring from the backside. The bottom row from above is closer.
    Good thing I found this out AFTER I added 16oz to the trans! :facepalm:
