3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Jul 8, 2020 at 8:44 AM
    #261
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
  2. Jul 8, 2020 at 8:50 AM
    #262
    3mw
    3mw Member
    2019 Magnetic Grey Tacoma SR Access Cab
  3. Jul 16, 2020 at 1:45 PM
    #263
    fryrice
    fryrice Well-Known Member
    MA
    2020 MG Access Cab SR w/ SX pkg
    Just bought my 2020 v6 SR model, should I check mine as well? Truck only has 53 miles on it.
  4. Jul 16, 2020 at 1:47 PM
    #264
    MyWifesTaco
    TRD pro grille .
    Is it shifting "normal"
  5. Jul 16, 2020 at 1:50 PM
    #265
    fryrice
    MA
    Yes, don't see any clunking...but this is my first truck so not sure what I should be expecting from the transmission with low fluid.
    No harsh shifts that I notice, keep in mind I just picked up the truck yesterday so I might need to drive some more.
  6. Jul 16, 2020 at 1:51 PM
    #266
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I still need to do this but i am intimidated by the instructions. I also have to remove my aftermarket skid plates
  7. Jul 16, 2020 at 1:55 PM
    #267
    fryrice
    MA
    Yeah, I got a Toyota for a reason so I don't have to go through these kinds of things...just was not expecting to these kinds of major missteps to happening on a new car.
    But if it has to be done it has to be done.
    cryptolyme likes this.
  8. Jul 16, 2020 at 8:00 PM
    #268
    MyWifesTaco
    TRD pro grille .
    How about a informal drain and fill post from the members who have done a drain and fill
    And yes yes assuming that it was checked and re checked and once again assumed to be at the correct level before said drain and fill
    I would give a good guess that it's going to be 3.25 quarts or very near there give or take a few ounces
    Therefor giving a much easier method of simply draining the pan drain bolt and pouring in 3.25 quarts as a
    "Standard " or "accepted" or "approved"or dare I say "official " Tacoma world trans fill level and call it a day
    :crapstorm:
    AM6217 and fryrice like this.
  9. Sep 3, 2020 at 9:32 AM
    #269
    schwartzki
    schwartzki Well-Known Member
    Midwest
    2020 Voodoo Tacoma TRD OR DCSB Prem/Tech/LED
    TRD Pro wheels, suspension & grill. KO2's, Front Window tint, Truxedo X15 Pro
  10. Sep 3, 2020 at 4:10 PM
    #270
    kruggirello
    kruggirello New Member
    Just ran into this...ready to do the temp check mode step and can't get it. Do you have any instructions for how to do it on the 2020?
  11. Sep 3, 2020 at 4:23 PM
    #271
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    schwartzki likes this.
  12. Sep 5, 2020 at 9:06 AM
    #272
    Bigkracka
    Bigkracka Well-Known Member
    Tx
    20 Tacoma SR5 Crew Cab V6
    OP, thanks for this thread! My 2020 sr5 v6 AT was a quart low. Glad to see Toyota fixed thus :rolleyes:
  13. Sep 5, 2020 at 9:11 AM
    #273
    Bigkracka
    Tx
    As for the jumpers I used them on my 2020 but didnt see the warning lights, proceeded per instructions from OP and all went well.
  14. Oct 10, 2020 at 1:06 PM
    #274
    Altarboy
    Altarboy Member
    White 2016 Tacoma SR Access Cab 4cyl
    White topper (thank you Orkin)
    I suspect the tendency to find a low fluid level in transmissions could be the result of them being filled to the full mark at the factory, and then the discrepancy occurs when fluid flows into the cooler and hoses upon first start.
    I checked my level with the tranny warm and in neutral with the engine idling. Later, I caused a debate at work with one guy saying this transmission should be checked running in park and the other saying it should be turned off in park.
  15. Oct 10, 2020 at 3:12 PM
    #275
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    With as many units as they go through, they have to have some automated way of dispensing the fluid into each unit. No one is standing there with WS quarts pouring them into the tranny. Just like dealers doing oil changes; comes from a 50 gal drum and has a preset on the pump nozzle. So it being underfilled is completely a fault of not calibrating it correctly. Maybe between vehicles with/without cooler. Either way, whoever actually manages the process won't ever see or hear complaints about each one... ever.
    You had it right with idling! Did you replace the washer or just cracked it to see if fluid came out at the proper temp?
  16. Oct 10, 2020 at 4:05 PM
    #276
    Altarboy
    Altarboy Member
    I bought new washers and Toyota fluid. I changed out 6 quarts with the drain_fill_run_drain method I learned from this board.
    Smacky2020 likes this.
  17. Oct 14, 2020 at 11:46 PM
    #277
    Jholt0804
    Jholt0804 New Member
    Josh
    2016 TRD Off Road 4x4
    I've been told by the dealer that the transmission was "sealed" and couldn't open it until i suspected something was wrong. But, fluid does go bad over time. I bring this up cause im about to do a complete fluid flush (Engine oil, brake fluid, Differential Fluid, coolant, and transmission) it's at 75K. What yall think i should do?
  18. Oct 22, 2020 at 12:38 PM
    #278
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    The dealer is full of it. If you want to flush all fluids, do it
    cryptolyme, mallege and GoldenBrew like this.
  19. Oct 22, 2020 at 1:31 PM
    #279
    MyWifesTaco
    TRD pro grille .
    Drain and fill no flush
  20. Nov 6, 2020 at 5:15 PM
    #280
    TacomaVirus
    TacomaVirus Well-Known Member
    Nick
    2020 Cement TRD Sport
    I have a 2020 TRD Sport that shifts a little hard and was curious to check the level. I tried the instructions above with no luck. Has anyone got this to work? Not sure what I am missing but tried three times with no luck. Start truck, p to s, s to p, n to d for 12 seconds and then back to p. Am I missing something? Where should the shifter be while waiting for the d indicator to come on?
