3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Jan 8, 2022 at 4:53 PM
    #381
    C4vettrn
    C4vettrn Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Can you elaborate or share where info is. Thinking about purchasing an app based OBD reader. What ar
  2. Jan 8, 2022 at 4:54 PM
    #382
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Anyone else do a 2020 + yet ? How did you check temp ? I may need to break down and buy one of the app based obd readers.
  3. Jan 8, 2022 at 5:06 PM
    #383
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Try to move the stick between N and P and see if D on the panel starts blinking and disappears. If it does, you are good.
    Ideally, you want Techstream, but you need to put some affort getting unlocked version and ODB adapter is $160+
  4. Jan 8, 2022 at 5:33 PM
    #384
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  5. Jan 9, 2022 at 8:29 AM
    #385
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Thank you. I still don't comprehend what pinning the thermostat does and why some do and don't.
  6. Jan 9, 2022 at 8:43 AM
    #386
    splitbolt
    NW Arkansas
    It's a throwback to a Tundra TSB that required pinning the t.stat to check fluid level.
    AFAIK, there is no technical literature that states it is required on 3rd Gen Tacomas.
    The thinking is, the air cooler is not getting filled; opening the t.stat allows the air cooler to fill. I've done it both ways; no difference. Then again, my t.stat had probably opened and filled the cooler prior to my checks...Who knows?
    Well, they eliminated the air cooler in 2020 as well, so...
  7. Jan 9, 2022 at 2:37 PM
    #387
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Good info thanks. Just totalled my 2015 and bought a 2020. I know it has a trans cooler but never herd of an air cooler. Regardless it doesn't sound like the new truck has it, thanks.
  8. Jan 29, 2022 at 7:12 PM
    #388
    Enduromatic
    Enduromatic Very Classy Redneck.
    matt
    Oregon. Heart still Colo though.
    17 magrey dclb TRD or.
    rebuilt leafs/ billy 5125 ome/ billy 5100
    This info proved quite helpful! Thanks op. I would like to add that I just purchased a used 17trdor with trans coole/tow package and was having strange hard shifts. They were only after sharply decelerating and then accelerating and quick 90 degree turns .
    My thoughts were it was low enough that the g's to the side or front would be enough to push the fluid out of where the plates are and thus the problem. After using this helpful level check info my thought proved true. 2.75 quarts low. Issue gone. Maybe this Intel will help someone else looking to check level because of hard shift. Note: it would slip only in the 2 described scenarios and then when it caught it would hard shift/ chirp tires even at 8mph or so.
    The truck has every service record. In 80k never a transmission drain and fill, logged at least. My suspicion is because this "it's a sealed system, never even look at it" bs. That even my dealership parroted.
  9. Feb 19, 2022 at 10:20 AM
    #389
    IronratPR
    IronratPR Well-Known Member
    Ace
    Caguas,PR (USA)
    Terra Tacoma 2025 TRD Sport 4x4 aka The Brick
    None
    OBD Fusion with Toyota 2021 Enhanced Diagnostics Trans Temp 1 works on a 2022. Just did it this morning
    MiTacoTRD likes this.
  10. Mar 17, 2022 at 11:20 PM
    #390
    SJH65
    SJH65 Member
    I'm diving into this project on my 2005 Toyota Tacoma and curious if anyone else has experienced this particular hiccup.
    Fill, drain and check bolts have all been loosened. The truck has been leveled and OBD pins #4/13 jumped. Start the truck (lights off), shift between drive/neutral at least 6-7 times, and then back to park. Instead of the AT Temp light blinking for 2-seconds the light remains a solid red. Tried both from cold and warm starts with the same result.
    Takes about 18 minutes for the AT Temp light to go from a solid to flashing; indicating that the temperature has become too hot for the proper oil check procedure.
    Alternatively, I do have a Thinkcar Thinkobd 100 which can likely read the transmission temperature as well. Just curious if anyone else has experienced this on the 05'.
    Thanks in advance. This is an extremely helpful thread.
  11. Apr 5, 2022 at 5:24 PM
    #391
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    It will be a little while before I have to change mine...not even 10K miles on her yet.
    Great info...thanks!
  12. Apr 5, 2022 at 5:48 PM
    #392
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  13. Apr 5, 2022 at 6:43 PM
    #393
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    My 2021 OR does not support any of the above methods, except an OBD reader for the trans temperature.
    Have not yet found the Techstream access to putting the trans into check mode, my version is one of the 16.xxx.xx.
  14. Apr 6, 2022 at 9:16 AM
    #394
    Vlady
    Issy, WA
    Do you have Techstream and looking where to find the temp check mode?
  15. Apr 6, 2022 at 9:48 AM
    #395
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Here's the pdf from Toyota. NOTE for 2020+ automatic transmission temperature check you do NOT have to jump the DLC3 terminals
  16. Apr 6, 2022 at 1:51 PM
    #396
    Toycoma2021
    Yes, I have Techstream 16.20.023. Looks like SSMTRDOR may have supplied the necessary document. Will read it later after taxes.
  17. Apr 8, 2022 at 12:07 PM
    #397
    bgoods
    bgoods Well-Known Member
    Brian
    Orlando
    2016 TRD Sport 4x4
    Stocklocker[QUOTED] likes this.
  18. Apr 8, 2022 at 12:19 PM
    #398
    Stocklocker
    17TRDORDCSBAT
    Yeah. Care Care Nut is a great channel. The guy is a gem and great teacher.
    FWIW: it took about 25 minutes for my transmission to reach temperature up here in the Canada. Some of the instructions say 8 minutes or so, but that has a lot to do with ambient.
    My initial drain was almost exactly 2 litres. I added 3 litres (the two I drained, plus extra to adjust to correct level). When I adjusted level I drained out exactly one more litre as my tranny had the proper fill to begin with.
    Taking Car Care Nut’s advice, I did not do multiple drains and fills to eliminate all the old fluid as he advised against that. So for now, I have 3 fresh litres in the tranny.
    bgoods[QUOTED] likes this.
  19. Apr 8, 2022 at 12:22 PM
    #399
    Stocklocker
    17TRDORDCSBAT
    I also recommend taking this video in. It’s a bit different as the Trucks have a dedicated tranny drain plug and the cars have a removable snorkel to drain the system, but it reinforces many of the same concepts.
    https://m.youtube.com/watch?v=eRxSu4-4ojo
  20. Apr 8, 2022 at 12:54 PM
    #400
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    CCN mentions some sort of scan tool to verify correct level check temp. I’m guessing that my Scangauge would be the correct tool for that?
