3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Apr 8, 2022 at 1:39 PM
    #401
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yes. If you get the tranny temp on it. I like using the method used in the videos as it leaves no guesswork. When the “D” light reappears, it’s time to adjust the level. The non-techsteam method seems more complex than it really is. Once you’ve done it a couple times it’s not so scary.
  2. Apr 8, 2022 at 1:55 PM
    #402
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yep...
    Temp check mode puts the engine in a certain idle mode...
    The Techstream method puts it in temp check mode as well... Why not just instruct the Techstream user to monitor the temp sensor if it didn't matter.
    As you said, eliminate the guess work.
    Stocklocker[QUOTED] and Skydvrr like this.
  3. Apr 29, 2022 at 1:48 PM
    #403
    Tacomuncher21
    Tacomuncher21 Well-Known Member
    21 SR 2.7l AC 4x4
    I’ll be checking the level soon then. Thanks
  4. May 10, 2022 at 2:42 PM
    #404
    Juspat2
    Juspat2 Well-Known Member
    Justin
    MatSu, Alaska
    2016 Black TRD Sport Access
    So, if i have a scan guage with Trans oil temp on it.... do i have to put the truck into 'check mode', or can i skip that step and just watch for the AT oil temp to get between 95-113? Also, is it the trans oil pan temp or torque converter temp that one should watch? thanks -
    Otterstuff likes this.
  5. May 10, 2022 at 2:44 PM
    #405
    saint277
    saint277 Vigilo Confido
    ya you can just use the scan gauge, and I tend to wait for both temps to be in the range, but pan temp is the one you want.
    Otterstuff and Juspat2[QUOTED] like this.
  6. May 10, 2022 at 3:02 PM
    #406
    Juspat2
    Justin
    MatSu, Alaska
    thank you -
  7. May 28, 2022 at 11:32 AM
    #407
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I just did this whole thing and according to the work my transmission was almost 1 quart low. To be honest I think I did something wrong because I find it hard to believe it was that low. I didn’t have any shifting issues previously
  8. May 28, 2022 at 11:52 AM
    #408
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    If you use Toyota's check mode, it only changes engine speed when the trans temp is in the correct range. You just hang out under the truck and wait, no need to watch anything, just listen for the rpm change.
  9. May 28, 2022 at 12:48 PM
    #409
    Anchovy
    TRD Ferguson
    I would imagine that it also opens the thermostat for trucks with them
  10. May 28, 2022 at 11:37 PM
    #410
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Do we need to do any of this song and dance if we just drain the pan and refill until it drips from the overflow port? All the guides I've watched make it seem that easy, then you start 'er up, shift through PRNDS, and test drive.
  11. May 28, 2022 at 11:44 PM
    #411
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I don’t think so. I don’t think there’s an electronicals going to the tstat.
  12. May 28, 2022 at 11:44 PM
    #412
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yes. Imo
    CAG Gonzo[QUOTED] likes this.
  13. Jun 1, 2022 at 6:13 PM
    #413
    321cya
    321cya New Member
    2017 DC LB TRD off Rd, white
    Just did a test run of this method to make sure I know what I'm doing tomorrow. Going to clean the pan and replace the filter in the morning.
    Great write up! Thanks so much. It was so much easier than I thought at first.
    I used a stopwatch to see how much time I had between the solid D and the flashing D and I came up with about 11 minutes. Truck had not been driven all day but I'm in the southwest and it was about 95F
    and sunny.
    Edit to add: dropped the pan, replaced filter and gasket, cleaned everything out and put about 5 QTS back in before I did this fluid check method today.
    So glad I did! Wish it was a bit earlier (I'm at 96k miles right now) because there was a lot of metal sludge on those magnets. But- hot damn! She shifts so much smoother now. Feels good man :broccoli:
  14. Jun 2, 2022 at 3:59 AM
    #414
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I need to do this.
  15. Jun 3, 2022 at 3:02 AM
    #415
    Zaalimk
    Zaalimk Member
    18 mgm TRD OR
    I tried doing this today but I’m getting a slightly different outcome. When I perform the shifting sequence, the D either starts blinking (atf too hot) or stays solid (correct temp). There was no heating up period between the two.
    Is this happening because I’m f-ing up or because the ambient temp was 95f when I performed it??
  16. Jun 3, 2022 at 5:39 AM
    #416
    willtill
    Maryland
    Probably that.
    Zaalimk[QUOTED] and Skydvrr like this.
  17. Jun 3, 2022 at 8:45 AM
    #417
    Illini Tacoma
    Illini Tacoma Well-Known Member
    2016 Dark Red Double Cab Short Box
    Toyota, just put a damn dipstick on the transmission and cut out all the needless BS!
    321cya, auskip07, Juspat2 and 6 others like this.
  18. Jun 3, 2022 at 1:06 PM
    #418
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Do it in the morning. It takes hours to cool the fluid down.
    Or use OBD apps to check the actual temp.
    Zaalimk[QUOTED] likes this.
  19. Jun 3, 2022 at 3:07 PM
    #419
    Zaalimk
    Zaalimk Member
    18 mgm TRD OR
    Exaclty what happened with me earlier today!
  20. Jun 3, 2022 at 7:50 PM
    #420
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Overflow transmission fluid level checks piss me off.
    Toyota says that's normal.
    Otterstuff and Illini Tacoma like this.
