3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Jun 4, 2022 at 10:20 AM
    #421
    Zaalimk
    Zaalimk Member
    18 mgm TRD OR
    Yup that’s what I did but the same thing happened. No warm up, solid D and it took roughly 5 minutes for the D to start blinking..
  2. Jun 4, 2022 at 1:47 PM
    #422
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Which year is your truck?
  3. Jun 7, 2022 at 2:48 AM
    #423
    Zaalimk
    Zaalimk Member
    18 mgm TRD OR
    2018 manufacturing
    2019 according to VIN number
  4. Jun 7, 2022 at 8:57 AM
    #424
    Vlady
    Issy, WA
    For putting a truck in the temp check mode, do you jump OBDII pins prior the stick manipulations?
  5. Jun 7, 2022 at 10:25 AM
    #425
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Jumper is installed before anything, aka "key-off" state. Be sure you have the right pins, there's a reason newer model years don't use that process.
  6. Jun 7, 2022 at 11:09 AM
    #426
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    What's the reason? I have a 2021.
  7. Jun 7, 2022 at 7:25 PM
    #427
    Zaalimk
    Zaalimk Member
    18 mgm TRD OR
    Yes. Before I start it. I’m wondering maybe if I cycle to accessory mode before starting it, that might change things ..
  8. Jun 8, 2022 at 12:43 PM
    #428
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    The OBD port always has power, get the jumper on the wrong pins and it may damage something. An easy and potentially very costly mistake.
  9. Jun 8, 2022 at 1:54 PM
    #429
    Toycoma2021
    So you think Toyota removed the required pins from the OBD port from the newer vehicles so people that were checking their ATF could not make a mistake. My 2021 does not have the pins on the OBD port and I have to use TechStream. Which by the way I have not gotten to work correctly.
  10. Jul 8, 2022 at 10:42 AM
    #430
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You can do it without Techstream.
    https://www.tacomaworld.com/threads...-level-check-diy.547455/page-12#post-22645913
  11. Jul 8, 2022 at 10:56 AM
    #431
    Toycoma2021
  12. Jul 19, 2022 at 8:09 AM
    #432
    Doghouse61
    Doghouse61 Well-Known Member
    Paul
    Calgary
    So I know this is a stupid question but I'm wondering what happens if the transmission is overfilled by a half a quart to a quart. I haven't done this (yet:rolleyes:) but as I have only a cursory understanding of transmissions I'm just curious.
  13. Jul 19, 2022 at 10:13 AM
    #433
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Im probably wrong, but Im going to do my fluid soon. Im going to have it parked on a level surface, and Im just going to drain it ice cold. Im going to measure what comes out. And Im going to pump fluid in until it weeps from the fill hole. Cold out/Cold in. How bad can that really be?
  14. Jul 19, 2022 at 10:38 AM
    #434
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    It could be really bad! I posted the instructions. See
    (1) 3rd Gen Automatic Transmission Fluid Level Check DIY | Page 20 | Tacoma World
    Monster0Frankenstein likes this.
  15. Jul 19, 2022 at 12:30 PM
    #435
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    part number of the filter you used?
  16. Jul 19, 2022 at 4:12 PM
    #436
    gForceDude
    gForceDude Well-Known Member
    Here's the Filter:
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-transmission-filter-3533004010
    The Gasket is designed to be re-usable, so you shouldn't need a new one; but if you want one anyway, here it is:
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-pan-gasket-3516804010
    And, Mr. Gearcruncher has some excellent advice here regarding LubeGard:
    https://www.tacomaworld.com/threads...rite-up-with-pics.361114/page-4#post-24529990
    321cya and auskip07[QUOTED] like this.
  17. Jul 19, 2022 at 4:29 PM
    #437
    AM6217
    Seriously how wrong can it be if I drain ambient temp fluid from drain plug, and pump ambient temp fluid back in. I honestly don't understand.
  18. Jul 19, 2022 at 4:52 PM
    #438
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    If you dont know what the base level is in the system, you are just throwing darts at a board. if you are high or low, you wouldnt know. Ski
  19. Jul 19, 2022 at 4:54 PM
    #439
    Toycoma2021
    Nothing is wrong with the theory with one big IF. IF the level was correct to begin with. There have been many posts where the user has not found the fluid to be at the proper level from the factory - don't know how true these posts are.
    Your prior post #434 had two conflicting statements. One was you were going to measure what you got out, the other was to fill with cold fluid until it overflowed. It is not clear from your post your intentions, please review your writing. This second idea was the worst as then you would definitely have an overfilled transmission when the fluid warmed up, i.e. fluid expands when it gets hot. This IIRC produces a foaming liquid, liquids filled with a bunch of air do not flow properly. An automatic transmission depends upon a dependable flowing liquid. Much like a brake system with lots of air in the fluid will not work well.
    This is a very long thread to read through and understand every nuance. There were some YouTube videos showing a mockup of the ATF pan and its workings with the fluid level check port.
    Oh, one more important thing, when the level is checked the engine must be running.
  20. Jul 19, 2022 at 9:37 PM
    #440
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Does anyone know the part number for the hex head bolt? I think the drain and overflow are of this type but the fill bolt is a hex cap screw that could be prone to stripping.
    I'm curious about the Lube guard fluid. Does anyone have experience with it? For ~$15, seems like an easy investment while performing a fluid change.
