3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Sep 17, 2022 at 7:35 PM
    #461
    verlaryder
    verlaryder Well-Known Member
    Today I resolved my difficulties. I discovered that my "no fluid came out of the 5mm overflow plug problem" when trying to determine if the factory filled these transmission correctly could be resolved by merely adding 1/3rd of a quart to the original factory fill. When I did that fluid came gushing out. So the factory only barely underfilled the 2021 & '2022's - on the order of around 4 - 8 ounces - not enough to be of concern.
  2. Sep 17, 2022 at 7:47 PM
    #462
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    So...you finally followed the procedure and all is good.
    If you had not deviated from the procedure and not made assumptions about the expansion of fluid, you could have saved yourself some hassle. You are also assuming the level of the '21 based on your experience with the '22.
    Glad it worked out for you...finally.
    verlaryder[QUOTED] likes this.
  3. Sep 18, 2022 at 11:32 AM
    #463
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    Checked mine…the factory fill was at the proper level. The amount of fluid used from the quart I added was negligible due to how minor it was. Process was very simple to complete.
  4. Sep 18, 2022 at 12:28 PM
    #464
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    What temp does the fluid need to be at for a check, is it 95-115 or something like that? I am doing a full fluid exchange next spring, did it in my 4runner a couple times and it is very easy. The temp check range is enough that an infared scan tool works good.
  5. Sep 18, 2022 at 6:09 PM
    #465
    verlaryder
    SmoPo16 and Gatafly like this.
  6. Oct 26, 2022 at 6:04 AM
    #466
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    Let's say you messed this process up by not adding a quart to begin with but added fluid until it went to a slow leak at full temp. Then went to check on it a few hundred miles later and only got about 1.3 quarts out the second time.....
  7. Oct 26, 2022 at 9:27 AM
    #467
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    IMO - if you didn’t feel any unusual shifting behaviors during those few hundred miles, you’re good.
    Glad you caught it
  8. Oct 26, 2022 at 9:36 AM
    #468
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    4 banger tranny is 1.6 qtrs for drain/refill.
    So you are pretty close
  9. Oct 26, 2022 at 12:46 PM
    #469
    Fishingeek603
    New Hamphire
    Weird my first drain was 2.4 quarts
  10. Oct 26, 2022 at 2:46 PM
    #470
    Vlady
    Issy, WA
  11. Oct 26, 2022 at 2:57 PM
    #471
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, it says 1.6 quarts for mine, but i got about 2.4 quarts out.
    Fishingeek603 likes this.
  12. Oct 26, 2022 at 3:05 PM
    #472
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’m a bit confused. Per the provided table for the 2GR-FKS the fluid for a drain and refill (3.3 qt) is more than for the pan removal (2.5 qt). How is this so?
  13. Oct 26, 2022 at 4:42 PM
    #473
    Vlady
    Issy, WA
    No idea. Perhaps folks with TIS access can pull the most recent revision if available. This on from 2016
  14. Oct 27, 2022 at 5:19 AM
    #474
    Fishingeek603
    New Hamphire
    You're my savior
  15. Oct 28, 2022 at 1:55 PM
    #475
    KeithF40
    KeithF40 Well-Known Member
    Keith
    2019 Black Toyota Tacoma SR V6 4x4 Double Cab
    I followed the process but just get the blinking D, have had truck off for like 2 hours now (thought that meant it was over temp).
  16. Oct 28, 2022 at 4:10 PM
    #476
    gForceDude
    gForceDude Well-Known Member
    It can take several hours for the fluid to cool down, so it sounds like your fluid temp might still be too hot to start the Level-Check Procedure.
    :notsure:
    Fishingeek603, usmc2msu and #4TOY4ME like this.
  17. Oct 28, 2022 at 9:47 PM
    #477
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Still too hot; do a practice run in the morning with the procedure. 95-113 degrees is not very hot, your body temperature norm is 98.6. The transmission is a big chunk of metal and the fluid has a lot of thermal mass as well.
    #4TOY4ME and gForceDude like this.
  18. Oct 29, 2022 at 4:32 PM
    #478
    KeithF40
    Keith
    So I waited until this morning and it finally cooled down. Problem is I can't get the plug with the 5 mm hex out and I think I stripped it.
  19. Oct 29, 2022 at 6:17 PM
    #479
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
    why did they use a hex head in the first place???wonder if there is a a conversion regular bolt u can use if u get that one out?
  20. Oct 29, 2022 at 8:07 PM
    #480
    KeithF40
    Keith
    that is the plan if anyone knows the part to order to replace it. now how do i get it out?
