3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Dec 4, 2022 at 9:31 PM
    #501
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
  2. Dec 6, 2022 at 1:23 PM
    #502
    Tacogent
    Tacogent Well-Known Member
    Nonw Stock
    12/6/2022
    My experience for checking the Trans Fluid temp and level for a 2021 Taco TRD Sport DCSB.
    Previously, I set up the Torque Pro app for use with the Tacoma ODB II and had it engaged via Bluetooth to my Android tablet during this procedure. I used the Engine Coolant, TC 1 and TC 2pids for the dials on my tablet. The Pids formulas that I entered came from the TacomaWorld discussions. TC 1 was the pan temp.
    My Procedure:
    1) Attached ODB doggle into port and opened the Torque Pro app for the Tacoma and made the Bluetooth connection.
    2) Made sure Truck was level.
    3) Went under the car and
    a. Opened fill bolt. Added 1 quart 32 oz of WS. Closed fill bolt.
    b. Loosened the check level bolt
    c. Pinned the Thermostat OPEN
    4) Started the truck procedure according to Post # 230. (Finally got it to work.)
    5) The D went away. Ambient temp was 64F. Time was 11:43.
    Coolant temp=76F, TF1 =61.2F, TF2 =61.2F.
    6) Felt the Trans oil hoses attached to trans cooler in the radiator. Top hose was definitely warmer than the bottom.
    After 12 minutes at 11:55, the D appeared and was not blinking. Coolant temp=156.2F, TF1 =97.2F, TF2 =100.6F
    7) Went under the truck and removed the check bolt. So, 25 oz came out till the stream trickled. That means it took about 7-8 oz. About ¼ quart.
    8) Inserted the check bolt and tightened to 15 ft/lbs. Used same washer.
    9) Went back to the cab. Torque Pro temp TF1 =104F, TF2=109F. Time was at 11:59 at end of trickle.
    Kept truck running 5 minutes more till the D started blinking. Coolant temp=174.2F, TF1 =115F, TF2 =117.4F. Time was 12:.03.
    10) Turned off the Truck.
    11) Went under the truck. Unpinned the thermostat
    12) Results:
    a. With the D not on, coolant temp was 76F at 11:43, , it took 12 minutes to get to checking temp for TF1 pan.
    b. At 11:55, at D reappearance, checking temp per Torque TF1 was at 97F and TF2 =101F.
    c. Went under the truck. Took about 4-5-minutes of fumbling and draining. When at 11:59, got back in the truck, TF1 was 105F and TF2=109F. Left truck running.
    d. About 12:03, the D was flashing, TF1=115, TF2=117, Coolant =174F.
    e. Appx 7-8 oz added. (32oz-25oz= 7oz)
    Conclusion: You have 8 to 10 minutes to CHECK/DRAIN the trans fluid.
    These procedures work on the 2021 Tacoma models. Get tools, your procedures and parts organized beforehand. Hardest part was manually pumping the WS into the Fill hole while lying under the truck.
    Second hardest was getting post #230 to work –.
    When shifting P to S to P, feel the shift points engage the trans.
    Then, when back at the (2nd time) P, shift from here more quickly now to the ‘N and D shifting’ portion of the procedure – do this quicker than the P-S-P shifting (say 5-8 times) and the D should disappear from the dash.
    Then, when you see the D go away, shift to P (nothing showing in the indicator now) to start the trans fluid level/temp test.
    Robie and mquibble like this.
  3. Dec 6, 2022 at 4:08 PM
    #503
    gForceDude
    gForceDude Well-Known Member
    :thumbsup:
    cryptolime likes this.
  4. Dec 15, 2022 at 8:01 PM
    #504
    dnguy77
    dnguy77 Well-Known Member
    Duey
    Baton Rouge, LA
    '18 White Tacoma DC TRD Sport, '03 Grey Tundra AC SR5
    2018 TRD Sport 2x4, drained a little over 2 quarts, put in 3quarts, did temp check and 600ml came out, so 400ml short from the factory.
    thomasburk likes this.
  5. Feb 5, 2023 at 10:10 AM
    #505
    Katracho994
    Katracho994 New Member
    I have a 2021 sr5 4x4 but I can’t get the temperature to work cuz my obd4 is different on the pin I don’t know how to do it I already put 4-1/2 court noting come out gushing after 8 minutes of idle I just have 1/2 more I have the front yack up
  6. Feb 5, 2023 at 1:21 PM
    #506
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB
    It takes about 10 minutes for engine to reach temperature required for fluid level check. From room temperature. even with engine running you have several minutes where fluid remains in range. If you have a laser temperature gauge, check trans pan for exact temperature reading.
  7. Feb 5, 2023 at 3:21 PM
    #507
    gForceDude
    Here's a link to the process for 2020 & newer trannys:
    https://www.tacomaworld.com/threads...-level-check-diy.547455/page-12#post-22645913
    Mine took about 12 minutes to reach the proper temp for the Level-Check Procedure.
    Katracho994[QUOTED] likes this.
  8. Feb 6, 2023 at 8:26 AM
    #508
    Katracho994
    thanks I’ll do it when I get home
    thomasburk[QUOTED] likes this.
  9. Feb 6, 2023 at 10:44 AM
    #509
    Katracho994
  10. Feb 6, 2023 at 10:52 AM
    #510
    Katracho994
    sorry but I don’t get it after starting the enguine I have to turn off o what it mean
    • Turn off electrical and mechanical loads
  11. Feb 6, 2023 at 1:42 PM
    #511
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Should be able to see temp with a scanner, correct?
    What temp should be used? Pan temp?
  12. Feb 6, 2023 at 4:15 PM
    #512
    gForceDude
    Turn off any/all lights, the fan, the radio, etc.
  13. Feb 6, 2023 at 5:45 PM
    #513
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Correct me if Im wrong, but is the amount to drain and refill the automatic 3.5 quarts ? If so , couldn't I just park the truck on a level surface , and while it's cold, pull the drain plug ? And if 3.5 quarts is the measured amount that comes out, can't I just put in 3.5quarts ?
  14. Feb 6, 2023 at 5:50 PM
    #514
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Sure, if you knew for certain, your truck was at the correct level. if you add 3.5 qts. and you were low to start... you would still be low. or the flip side, if you were too full. only way to know for sure, is to check fluid level correctly. Would be nice, if there were an easier way though. Ski
  15. Feb 6, 2023 at 5:52 PM
    #515
    AM6217
    Thanks Ski
  16. Feb 7, 2023 at 4:48 AM
    #516
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Last time I did this, I used a funnel from above and a piece of 1/2” clear poly hose to fill.
    I hate using those darn pumps
    Papa_Smurfin likes this.
  17. Feb 27, 2023 at 12:18 PM
    #517
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I made a video this morning of me checking my trans fluid at 20K miles without having to jump the OBD port (my ‘21 doesn’t even have a pin in hole 13). My level from the factory was good…
    https://youtu.be/XTU_Jt7OJZk
    3JOH22A, Tacogent, Amorak and 6 others like this.
  18. Mar 29, 2023 at 1:06 PM
    #518
    Jimmywestco
    Jimmywestco Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    Can anyone suggest a good fluid pump. Thanks
  19. Mar 29, 2023 at 1:11 PM
    #519
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If I didn’t have so many pumps, I’d be looking for one that fit the bottle of the ATF you are going to be using. The Toyota WS I believe has a non standard screw on cap. IIRC
  20. Mar 29, 2023 at 1:11 PM
    #520
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I bought this one off Amazon and it works great. You can fully disassemble it to clean so you can use it for other oil types. My only complaint would be the tubes. If you don’t cut them down to side, they are unwieldy.
    Hilux1 likes this.
