3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Dec 29, 2024 at 7:31 PM
    #601
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Are you planning on not using the check mode? The check mode also controls the idle speed and thus to some degree the level.
    usmc2msu likes this.
  2. Dec 29, 2024 at 7:55 PM
    #602
    Mike Z
    Mike Z Well-Known Member
    By the time the trans temp meets the minimum temp the idle is about normal. The dealer uses techstream to get the temp and did not mention anything about check mode
  3. Jan 6, 2025 at 7:53 AM
    #603
    Tacogent
    Tacogent Well-Known Member
    Nonw Stock
    Check out the video at post # 517 , by 'Brian2sun'.
    No jumper wire needed.
    I don't think Tacos 2021 and after can even use the 'jumper wire' method.
    I've checked the upper and lower trans oil temps when in check mode via ODBII doggel and Torque Pro on my tablet and they were within +- 1*F of what they should be.
  4. Jan 6, 2025 at 1:22 PM
    #604
    Mike Z
    Looking again in the service manual I did find "Select the Active Test item: Connect the TC and TE1 / ON." in Techstream before reading the AFT temp with "Select the Data List menu: A/T Oil Temperature 1." I saw elsewhere that 800 rpm is the check fluid mode rpm and post #517 video shows the tachometer looking about 800 so I'll do the DND procedure to be safe.
    Tacogent likes this.
  5. Jan 6, 2025 at 2:45 PM
    #605
    Toycoma2021
    Precisely, the idle speed is “controlled” in the level check mode. This is what many people are missing when they say they will just use some other device to check the temperature when checking the ATF fluid level. How much does the idle matter? Do not know, but that is what Toyota has developed and it seems easy enough to do with or without Techstream. I do have Techstream and I have never opened it up to use when checking my fluid - seems way too much trouble on getting the computer out and such.
  6. Mar 4, 2025 at 10:03 PM
    #606
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Subbing
  7. Aug 3, 2025 at 4:26 PM
    #607
    dougluvgold
    dougluvgold Member
    Douglas
    2023 tacoma SR5 dbl cab off road /OTT tune mild spicy stock height. Barselona red
    OTT TUNE med spicy , k&n air filter
    The paper clip bridge in obd port isn't necessary , just the shift pattern will put it in check mode .
  8. Aug 28, 2025 at 8:37 PM
    #608
    Taco Tyrant
    Taco Tyrant Well-Known Member
    Hondo Tx
    2020 SR V6 4WD
    Thanks for the write up! What a pain in the ass though! I think a bunch of mechanics were fucking the head Toyota engineers wife based on the level of spite for mechanics in the design of the turd gen.
    BRFab and thomasburk like this.
