3rd Gen Automatic Transmission Fluid Level Check DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rowsdower, May 3, 2018.
  1. Jan 4, 2019 at 12:24 PM
    #61
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    so whats the news?
  2. Jan 4, 2019 at 12:27 PM
    #62
    trackdaybro
    trackdaybro Well-Known Member
    No noticeable difference after the light top off. Traded into a 6MT soon after.
    HolyReptar[QUOTED] likes this.
  3. Jan 7, 2019 at 10:12 PM
    #63
    Maximus2002
    Maximus2002 Well-Known Member
    Sam
    2016 Silver TRD Sport 4x4
    Help: How would you fully drain the pan?
  4. Jan 8, 2019 at 4:04 AM
    #64
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    There's a drain plug in addition to the overflow plug.
    Maximus2002 likes this.
  5. Jan 8, 2019 at 2:17 PM
    #65
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    For those with a copy of TS or scangauge what is the temp readout we are looking for on a 2017 Tacoma?
  6. Jan 12, 2019 at 8:46 AM
    #66
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    I get 186* tf1
    190 tf2 after driving for an hour with a decent amount of shifting
  7. Jan 12, 2019 at 8:47 AM
    #67
    reloader403
    Acworth, GA
    Tf2 isnt something I care too much about considering it is the TC outlet. But pan temp stays 186-190 under decent load or with my small 5x8
  8. Jan 21, 2019 at 6:29 PM
    #68
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Nice write up ... I wanted to copy and save this entire file ... :thumbsup:
  9. Jan 25, 2019 at 5:39 PM
    #69
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I just bought an '18 TRD OR 4x4 and I'd like to check my AT fluid for peace of mind as well. When the engine is up to temp and you crawl under the truck to remove the overfill plug, what am I looking for? Am I waiting for all of the fluid to come out before I put the plug back in? Am I waiting for it to trickle, as in a drip drip drip, or a small steady stream?
    Ngneer likes this.
  10. Jan 25, 2019 at 5:43 PM
    #70
    rowsdower
    rowsdower [OP] Well-Known Member
    You really only need to pull it for a few seconds. If there isn't fluid gushing out, then you're all set.
    Ngneer likes this.
  11. Jan 25, 2019 at 5:50 PM
    #71
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thanks! Now what if it is gushing when I remove the overfill plug? Would I need to let all of the fluid drain out before I put the plug back in? I'm just trying to figure out when to put the plug back in, when it's still gushing or when it's stopped gushing.
    Ngneer likes this.
  12. Jan 25, 2019 at 7:21 PM
    #72
    rowsdower
    When it slows to a trickle, put the plug back in. Not when it's gushing out. It's never going to stop dripping out because the fluid level is going to be at just the same level as the top of the overflow tube, and the truck will be running so the fluid will be moving around making waves. You'll know when it's time to put the plug back in. Don't overthink it.
    Ngneer and usmc2msu like this.
  13. Jan 25, 2019 at 7:23 PM
    #73
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thanks! I think I'll check it this weekend!
    Ngneer likes this.
  14. Jan 26, 2019 at 7:17 AM
    #74
    Adubya
    Adubya Active Member
    Austin
    Las Vegas, Nevada
    2017 Tacoma TRD OFF ROAD- DCSB
    FRP Flippac ADS Coilovers, Triple Bypasses, Bumps, Deavers Relentless Fab Bumper BAMF Sliders
    Great write up!
    Ngneer likes this.
  15. Jan 26, 2019 at 9:08 AM
    #75
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Excellent write up!
    Best I’ve seen on the subject, better than the TOYOTA fsm. In fact, TOYOTA ought to use it as a field service guide.
    Post like this are what makes TW shine, with no bashing on TOYOTA or WS ATF.
    Sticky please?
    Now if only post #1 could be in a pfd file format, it would be the icing on the cake.
    Cheers!
    Ngneer likes this.
  16. Feb 2, 2019 at 8:37 AM
    #76
    yotanut
    yotanut Well-Known Member
    2022 TRD Pro 6MT
    Looking over the Toyota service manual for the procedure and they mention nothing about pinning the thermostat for those of us with a tow package. I am going to follow your procedure today, but wondering why Toyota doesn’t pin it.
    It also appears they mention to fill until fluid comes out of the overflow plug to begin with.
    cryptolyme likes this.
  17. Feb 2, 2019 at 9:03 AM
    #77
    Markc1024
    Markc1024 Well-Known Member
    I think pinning the thermostat just ensures that the circuit is full of fluid. If one never got it above the opening temp, you'd be a little short once it opens and fills. If checking on a warm day, it might still be beneficial to slow the warm up a little and give you time to check without exceeding the temp limit.
  18. Feb 2, 2019 at 9:57 AM
    #78
    yotanut
    2022 TRD Pro 6MT
    I just followed the instructions here and my truck was 1/2 quart low. Glad I did it.
    Thanks OP.
  19. Feb 9, 2019 at 11:44 AM
    #79
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Just did this to my truck. Trying to eliminate rough downshifting in stop and go traffic and some piece of mind. I was 1/3 to 1/4 quart low. Doubt that will affect much.
    Ngneer likes this.
  20. Feb 10, 2019 at 11:02 AM
    #80
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    Here is how I did it on my last Tacoma, a 4x4 06 Sport. This is the shortened version, because at the time, I was changing the fluid and screen also, so leaving that part out. Found out what Toyota recommended for fluid temp to check the level, I think it was around 96 to 116 or somewhere around that. whoever uses this technique would want to find the Toyota temp spec. I drove my truck around the block to warm it up a bit, but not too much. Used an inexpensive handheld IR temp gun and shot it at the pan and it read 100. Pulled check bolt and fluid that came out was 105 so diff in temp was 5 degrees. So for my future checks, I know the pan is 5 degrees cooler than the fluid. After using this technique for my trans fluid change, I found the new amount I added back in, was exactly the same amount added by the folks who did the Toyota technique of using the diagnostic port or a handheld scanner. I will be using this method on my current truck, but will be pressing in the thermostat also. If it truly matters.
    Ngneer likes this.
