3rd Gen BHLM + Retrofit Projector
Discussion in 'Lighting' started by MESO, Apr 29, 2016.
  1. May 1, 2016 at 6:20 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah I've done quite a few 2nd gen retros so this being damn near plug and play for a very nice retro is awesome.
  2. May 1, 2016 at 9:27 PM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    I really want to attempt this.
    Does the grill and bumper 100% have to come off?
  3. May 1, 2016 at 9:45 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Yes. There is 1 bottom screw (10mm) the is mounted inward connecting the headlight to the fender. Removing the bumper is the only way. Its actually really easy!
    Got them all adjusted and wired up;
    I'm LOVIN' this cutoff. super crisp, and not blinding oncoming traffic.
    some night shots;
    With the Highs on, it's super bright.
    -The highbeam spot(h11) is getting swapped to OPT7 LED. Although I'm not super crazy about LED's.. with it being used occasionally, and momentary I think it will be fine. Finally, when I change out the fogs I don't think I'll even need a lightbar anymore.
  4. May 1, 2016 at 9:53 PM
    sorgon82
    Ont. Canada
    Awesome job man n thanks for the details
  5. May 2, 2016 at 6:29 AM
    Large
    Large Red
    I would bet getting the lens apart from the housing would be the most pain in the ass part.
  6. May 2, 2016 at 8:44 AM
    sdsmtengineer
    sdsmtengineer Member
    Nick
    Rapid City SD
    2013 Tacoma TRD offroad
    Fog Lamp anytime MOD ABS Kill switch MOD Wet Okole Seat Cover Palsti Dip chrome grill Plasti Dip all badges
    I know you mentioned the bake time in your first post, but its a little confusing with the different times you had to use. Now that you have successfully got the perma-seal apart what temp and time do your suggest so that multiple reheating is not needed.
    BTW the lights look AWESOME!
    I did the VLED high beam and HID low beam conversion from the TRS, but I'm not 100% happy with beam quality thats why Im doing a retrofit like you.
    Also I have a pair of baja designs squadron light on my BMW R1200GSA, they are AWESOME, you will not be disappointed. Its also really nice to see Baja Designs making an adaptor to fit their lights into the factory toyota fogs. It looks like I'm going to have to buy a pair of the he baja designs squadron racer lights.
    And for those of you out there that don't understand the different types of lighting and the proper selection for what your using the lights for Baja Designs has a great read called the Science of Lighting. Check it out...
    http://www.bajadesigns.com/page.asp?p_key=036E902AEE0340F2AB2042420B2611C7
  7. May 2, 2016 at 9:23 AM
    MESO
    State of Jefferson
    I have read 2 different approaches on getting the permaseal to break free. Some guys bake it hot(270-280) for 8-10min. Others bake it longer 18-20min at a lower Temperature(230-240). I choose the later. I figured baking it longer would slowly heat up everything consistently, plus I wouldn't risk melting the housings.
    After ~20min in the oven it was still hard to break apart. The plastic housing was malleable but the lens still wouldn't budge. So back in the oven, but I bumped up the temp to around 250 for 10min. This started softening things up, now I could get a flat head under a corner and start working it up. By the time I got halfway around, the housing had cooled. So I out it back in the oven 1 more time and that finished it. Good luck:)
    TRSJimmy likes this.
  8. May 3, 2016 at 6:50 PM
    MESO
    State of Jefferson
    Also, @sdsmtengineer I don't think you can do it in 1 bake unless you get the housing REALLY up to temp. Maybe the pros can, but multiple bakes are definitely advised. It's actually not bad; while your working on one, the other is in the oven. When your done prying, the other will be hot and ready and you can just swap them. Repeat until you crack em' open!
  9. May 4, 2016 at 9:20 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    So much win in this thread. Great job.
  10. May 5, 2016 at 8:16 PM
    Lochevan
    Lochevan Well-Known Member
    2016 DCSB Sport 4x4
    I completely agree with @mesojdm. I initially thought multiple heatings would be annoying but it's really not that bad. If you try to race through it, you'll likely mutilate the black housing - it gets pretty soft even at 240. Take your time and enjoy some awesome custom lights.
    MESO[OP] likes this.
  11. May 16, 2016 at 7:30 PM
    Patmac
    Patmac Well-Known Member
    Pat
    Chesapeake, VA
    14 TRD Sport
    20% tint, weather techs, icon stage 3. n-fab, bhlm, retrofits, SCS SR8, 285s
  12. May 19, 2016 at 8:02 AM
    NascarSigEp
    NascarSigEp Well-Known Member
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    My question is why did you cover the lense in tape to put in the oven? I've done multiple sets of headlights and tailights without covering the lens.
    Your write up is amazing! Great job!
    RubberDuck and TRSJimmy like this.
  13. May 19, 2016 at 8:31 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Curious as well
  14. May 19, 2016 at 8:46 AM
    MESO
    State of Jefferson
    I didn't want to take any chances scratching the lens when man-handling it trying to take it apart. The plastic can scuff pretty easily. Cheap insurance, and it pulls right off leaving no residue.
  15. May 19, 2016 at 8:54 AM
    #35
    NascarSigEp
    Tim
    Omaha,NE
    2016 DC Sport 4x4
    Awesome. I woulda thought there would be some transfer from the tape or at least residue. I wonder if it also helps retain heat during the process.
  16. Aug 5, 2016 at 6:54 PM
    #36
    Zombiii
    Zombiii Active Member
    2016 4x4 TRD Sport Long Bed
    This isn't related to the headlights but something I noticed in your picture of the headlights installed. Did you paint parts of your grill matte black? Or is it just the lighting in those shots?
    It looks different in those shots from my chrome grill. Just curious.
  17. Aug 5, 2016 at 7:56 PM
    #37
    MESO
    State of Jefferson
    The center grill section was removed and painted with black plasti-dip.(temporary)
    This is how it looks now.
    P.s I am LOVING THESE LIGHTS.
  18. Aug 5, 2016 at 8:38 PM
    #38
    TRSJimmy
    Jimmy
    Gainesville, GA
    Beautiful
  19. Aug 5, 2016 at 9:47 PM
    #39
    MESO
    State of Jefferson
    Thanks! It's a must have for the 3rd gen's and completes the look IMO.
    What are you waiting for?: https://www.tacomaworld.com/threads/pair-of-tacoma-headlights.444108/
    strongrob likes this.
  20. Aug 6, 2016 at 4:56 PM
    #40
    TRSJimmy
    Jimmy
    Gainesville, GA
    Good luck! I :bowdown: you for taking on a permasealed headlight as your first retrofit. Butyl is stupid easy compared to permaseal. I hope you get it man!!! I kinda want to do a set now
    0uTkAsT[QUOTED] likes this.
