3rd Gen BHLM + Retrofit Projector
Discussion in 'Lighting' started by MESO, Apr 29, 2016.
  1. Sep 9, 2018 at 9:59 PM
    #661
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    How tight we talking, built the d2s in my 1st gen. Small shroud like the bullet I believe it is?
  2. Sep 9, 2018 at 10:01 PM
    #662
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    The front won't be the issue. It will be the rear clearance. The back of the projector will probably be hanging out the hole.
  3. Sep 9, 2018 at 10:03 PM
    #663
    GreeGunc
    Jacob
    North GA
    The threaded shaft?
    Might have to go the bolt route
  4. Sep 9, 2018 at 10:06 PM
    #664
    MESO
    State of Jefferson
    Sure, but then it wouldn't be adjustable. (critical for low beam)
    The issue will be how uneven the rear plastic housing is. Here is an example of the modifications needed for a 3" projector in high beam spot:
    RubberDuck likes this.
  5. Sep 9, 2018 at 10:13 PM
    #665
    GreeGunc
    Jacob
    North GA
    Still haven't got a spare set of housings yet, the projector needs to sit that far back :eek:
  6. Sep 9, 2018 at 10:17 PM
    #666
    MESO
    State of Jefferson
    In my application they did.
  7. Sep 9, 2018 at 10:19 PM
    #667
    GreeGunc
    Jacob
    North GA
    Those the quad projectors or your friends headlight build?:D
    I've been doing research :anonymous:
  8. Sep 10, 2018 at 7:53 AM
    #668
    MESO
    State of Jefferson
    That was the quad LED retro
  9. Sep 10, 2018 at 8:02 AM
    #669
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Want!!!
  10. Sep 10, 2018 at 9:54 AM
    #670
    GreeGunc
    Jacob
    North GA
    I wonder if it would be better to move the factory projector to the high beam spot and new projector in the factory spot. High beam shouldnt need to be adjusted right?
  11. Sep 10, 2018 at 9:56 AM
    #671
    MESO
    State of Jefferson
    yes that's a better plan. But I wanted 4 low beams and 4 high beams with full adjustment.
    1bad2k likes this.
  12. Sep 10, 2018 at 10:02 AM
    #672
    GreeGunc
    Jacob
    North GA
    I'm not that crazy:p
    You went with the morimoto mled?
    You like them over hid? I just like the thought of less wiring
  13. Sep 26, 2018 at 5:22 AM
    #673
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I hate to ask a stupid question here but here goes.... how do the Rx350 projects give you hi and low? If I just want that and dont care about running the stock hi bulb any more then I dont have to?
  14. Sep 26, 2018 at 5:30 AM
    #674
    20tacoma17
    2017 DCLB Sport AT
    There is a shield in the projector. It blocks the upper portion of the light for low beam and when you hit high beam it moves out of the way.
    HolyReptar[QUOTED] and 1bad2k like this.
  15. Sep 26, 2018 at 5:31 AM
    #675
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    How exactly does it do that? Is there something special that needs to be changed on the harness?
  16. Sep 26, 2018 at 5:59 AM
    #676
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    There are two wires that come off the projector itself, you wire those to your stock high beam plug on the truck’s harness. You’ll just need the matching female plug to put on the wires coming off the projector, h9 I believe? May be having a brain fart on that.
  17. Sep 26, 2018 at 6:00 AM
    #677
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Awesome thank you
  18. Sep 26, 2018 at 6:02 AM
    #678
    20tacoma17
    2017 DCLB Sport AT
    You will need an adapter to plug into your High beam plug. It plugs into the shield actuator. When you turn on your high beams it moves the shield instead of turning on the other high beam light you used to have.
    HolyReptar and no vtec 4me like this.
  19. Sep 30, 2018 at 6:10 PM
    #679
    lowtaco
    lowtaco Well-Known Member
    San Diego, CA
    Does anyone here have a set of amber headlight reflectors left over if they replaced them with clears? I messed mine up and need replacements.
  20. Oct 3, 2018 at 8:52 PM
    #680
    20tacoma17
    2017 DCLB Sport AT
    Is there a special paint needed for the headlight chrome and blacking out part of the halo?
