3rd Gen BHLM + Retrofit Projector
Discussion in 'Lighting' started by MESO, Apr 29, 2016.
  1. Dec 5, 2018 at 7:02 AM
    #801
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Yeah same bolt pattern. I plan to use those adapters you speak of, just wondering how much theyll need to be spaced forward...
  2. Dec 5, 2018 at 7:03 AM
    #802
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Bro I have rock sliders to avoid door dings at the mall Starbucks.
  3. Dec 5, 2018 at 7:37 AM
    #803
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I've got kbro2s, plate bumper, winch, and skids to get to walmart
    I know the struggle
    1bad2k[QUOTED] likes this.
  4. Dec 5, 2018 at 7:54 AM
    #804
    Skinny P
    Skinny P Well-Known Member
    Steven
    Where did you buy the cheap pair?
  5. Dec 5, 2018 at 10:28 AM
    #805
    brohirrim
    brohirrim Well-Known Member
    Anyone know how hard it is to replace the high beam reflector with a projector? I believe earlier Meso said that you have to put a smaller projector in unlesss you modify the housing. Has anyone done it?
  6. Dec 5, 2018 at 12:17 PM
    #806
    iNfectious
    iNfectious Well-Known Member
    Q
    Lone Star State
    '18 TRD Sport 4X4 DCSB
    I bought a pair for around $100 on Ebay. Missing tabs and scuffed up. Always email the seller for a combined deal.
    The internal headlight parts are practically brand new.
  7. Dec 5, 2018 at 12:25 PM
    #807
    Skinny P
    Steven
    Cool thanks man, I was considering doing this to my OEM ones, but if I can get a practice set for $100 I’d be all in.
    Do you have a parts list by chance of everything you used? Like are they obtainable off of Amazon?
  8. Dec 5, 2018 at 12:27 PM
    #808
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Might be easier to try Profile's LED highs. The output is decent and compliments a bi-xenon projector.
  9. Dec 5, 2018 at 12:39 PM
    #809
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    HAHAHAHA! I’ve thought about getting sliders for that exact reason! LMAO!
  10. Dec 5, 2018 at 12:49 PM
    #810
    Redline870
    The GIF in your signature is amazing
  11. Dec 5, 2018 at 9:05 PM
    #811
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Would have been nice if it was a single large lens that way it would match the bi-xenon.
    brohirrim likes this.
  12. Dec 6, 2018 at 12:24 AM
    #812
    iNfectious
    Q
    Lone Star State
    I'm still working on mine. The first post on this thread will help you out.
  13. Dec 6, 2018 at 6:20 AM
    #813
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Could always use a cheap mini h1 with the cutoff and foreground shields removed so it's just a full-time high beam. They are only like $20. EDIT: Actually that would suck because of the HID warm up time.
  14. Dec 6, 2018 at 9:03 AM
    #814
    GreeGunc
    Jacob
    North GA
    I've thought about putting the oem projector in the high seam spot and removing the cutoff sheild
  15. Dec 6, 2018 at 9:50 AM
    #815
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Might work with an LED bulb as well if the yellow of the halogen isn't wanted. No issues with scattered light as it's for a high beam anyways but probably won't perform as well.
  16. Dec 6, 2018 at 10:49 AM
    #816
    GreeGunc
    Jacob
    North GA
    You think?
    I know the lens on the d2s in my 1st gen looked like a magnifying glass, reflecting the light as you wanted it
  17. Dec 6, 2018 at 12:24 PM
    #817
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Without the LED being properly mounted it won't throw as far as it should.
  18. Dec 6, 2018 at 1:29 PM
    #818
    GreeGunc
    Jacob
    North GA
    It's the factory shroud so h11 bulb will fit fine?
  19. Dec 7, 2018 at 10:54 PM
    #819
    Redline870
    Are these the adapters you speak of? https://www.lightwerkz.net/index.php/components/retrofit-brackets/toyota-tacoma-d2s-bracket.html
    mesojdm - would you use the new D2S 5.0 or the RX350 projectors? I’m debating, and if there’s an adapter plate for a bolt in installation, it makes it a difficult decision. I’d like some input from some more experienced retrofitters.
  20. Dec 7, 2018 at 11:02 PM
    #820
    MESO
    State of Jefferson
    I’d try the 5.0 out especially at the price point. I’m working on a set of quad 5.0’s,
    ... probably around the same price as a single pair of RX’s ha. Morimoto has really improved on their projectors.
