3rd Gen BHLM + Retrofit Projector
Discussion in 'Lighting' started by MESO, Apr 29, 2016.
  1. Oct 5, 2016 at 3:39 PM
    #121
    shadowkhan
    shadowkhan Well-Known Member
    2016 Barcelona Red TRD Sport 4x4 Prem/Tech w/JBL DCSB
    for those that have done this mod. do you think the mod could be done in a day? Was planning to do it early sunday but need to put them back on for work the next day.
  2. Oct 5, 2016 at 3:42 PM
    #122
    TastyTaco
    TastyTaco Well-Known Member
    Nick
    Vancouver, WA
    2003 Taco 3.4 DC TRD
    3" Lift, BFG K02 285/70/17, Pro Comp 45 Series 17x9 -6, ACME D2S Retrofit
    If you have never done a retrofit I would suggest a weekend so there is no rushing. The quickest I have done a retrofit MH1 in my old tundra was 3ish hours with painting and everything.
    If you start early enough you might be able to get it done.
  3. Oct 5, 2016 at 3:45 PM
    #123
    shadowkhan
    thanks for the reply. yeah planning to do it pretty early around 8
  4. Oct 5, 2016 at 4:51 PM
    #124
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I agree. A weekend is best. Especially if you never done one. Paint cure is 24 hours per the can.
    0uTkAsT likes this.
  5. Oct 5, 2016 at 7:25 PM
    #125
    shadowkhan
    damn there goes that plan
  6. Oct 5, 2016 at 7:43 PM
    #126
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    And a weekend plan is if everything goes right. Snap a headlight and it's an 800 dollar whoopsie. It takes me a week. I give a full 7 day cure of the paint before putting it back together.
  7. Oct 5, 2016 at 8:47 PM
    #127
    shadowkhan
    Well can't you close it up after the paint dries and let the curing happen when it's closed up?
  8. Oct 5, 2016 at 9:26 PM
    #128
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    Abdolutely.
  9. Oct 6, 2016 at 7:24 AM
    #129
    shadowkhan
    yeah, i'll probably do it that way. Just so hard to find time to do it. Having my sister take my son to Disneyland so i have some free time to work on it.
  10. Oct 6, 2016 at 7:55 AM
    #130
    TastyTaco
    Nick
    Vancouver, WA
    It really depends on the paint you use as well. I swear by Krylon Fusion paint. I have never prepped a surface such as scuffing and cleaning and the paint adheres perfectly. Dry to touch within 10min they say but I try to give it 30 or so before handling and I always hold the non painted surfaces. The only concern really is when putting a painted part back in the headlight without waiting to long is chipping the paint or finger prints.
    It is getting harder to source the paint locally now, every store keeps replacing it with their own brand of paint.
  11. Oct 6, 2016 at 7:58 AM
    #131
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    So much sex :drool::drool::drool::drool::drool::drool:
  12. Oct 8, 2016 at 12:22 PM
    #132
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    So I've decided to go ahead and do this. I'm going to do it a little differently though. My 2016 is MGM so rather than going black, i'll be using MGM instead. I will also tint the amber signal like you guys have done, looks much better.
    Automotivetouchup.com sells very high quality products. I plan to use their plastic primer which is designed to promote adhesion to plastics including chrome plated plastic. I will scuff the chrome with 0000 steel wool, wash very well, then prime. I will then use their paint and high gloss clear. I've used their products before and I was very happy. They even smell like the same paints used in body shops.
    As far as resealing the housings, what's everyone's opinion of this?
    http://www.ebay.com/itm/201548915636?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    trd_overland and Bkoger43 like this.
  13. Oct 8, 2016 at 1:24 PM
    #133
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    Third set done. These keep gettn better and better
    Citadel, MeFryRice, lonzorizo and 4 others like this.
  14. Oct 8, 2016 at 1:27 PM
    #134
    2016 Tacoma SR
    HOCO Maryland
    I think when I do mine I'm going to paint the majority of the inner signal section also. Get rid of as much chrome as possible. I'm running LED bulbs there anyway, they'll still be plenty bright.
  15. Oct 8, 2016 at 5:45 PM
    #135
    shadowkhan
    What paint is everyone using. At Home Depot and the amount of paint is overwhelming lol
  16. Oct 8, 2016 at 6:39 PM
    #136
    motorsport36
    Furnace, AZ
    98 SR5 AC 4x4
    Krylon fusion. Matte/flat/satin color of your choice
  17. Oct 8, 2016 at 6:54 PM
    #137
    tj714
    tj714 Active Member
    Tj
    2017 TRD OFFROAD DCLB 4x4
    Plasti dip
    l have done a few retros and search for some butyl tape on ebay. I know they have black and grey as colors. It is sold by the roll and you can form it in to a long rope that can be pressed in to the lens channel.
  18. Oct 8, 2016 at 8:48 PM
    #138
    2016 Tacoma SR
    HOCO Maryland
    I have that already, I use it whenever running wires through an aftermarket grommet in a firewall to seal everything up. It never hardens, stays soft and gets even softer when heated. Definitely not what I want to use to seal up my headlights permanently.
    HolyReptar likes this.
  19. Oct 8, 2016 at 9:38 PM
    #139
    tj714
    tj714 Active Member
    Tj
    Plasti dip
    Ahhhh a permanent seal. I have never used anything permanent for my headlights. I would not know what to use in a permanent application. You should try hidplanet, maybe you will fine an answer there.
  20. Oct 9, 2016 at 6:39 PM
    #140
    TastyTaco
    Nick
    Vancouver, WA
    What color is this?
    Also what temperature and exact amount of time have you been baking them for? Thanks
