3rd Gen BHLM w/Retro - Lens Tint on Reflector questions
Discussion in 'Lighting' started by Team Scream, Sep 20, 2020.
  1. Sep 20, 2020 at 3:30 PM
    Team Scream
    Team Scream [OP] Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
    So I am mid stroke on a BHLM/Retro, using Morimoto D2S 5.0 bi-xenon projectors.
    I purchased the high beam harness so I could use my factory high beams as added cool factor, but I would also like to darken up the factory high beam reflector, and was wondering if anyone has tried using lens tint (spray) on the reflector with good success?
    My concern is that the OEM high beam bulb will put out too much heat, and probably destroy the lens tint on the reflectors (have the same concern with just blacking out the reflector), so I am looking to replace the factory bulb with an LED forward facing spot of some kind. My thought is that if I can put an LED in there, even one with multiple elements, it will provide some light output, but way less heat output. It's a form over function thing for sure.
    Can anyone recommend an LED that has forward facing elements to replace the OEM high beam bulb?
    Thanks
  2. Sep 20, 2020 at 6:46 PM
    MFDOOM88
    MFDOOM88 Well-Known Member
    Boston
    2016 Black Tacoma TRD Sport
    I don’t think you can “destroy” the paint especially since there isn’t any physical contact. Also, it’s not like you’ll have your high beams on for extended durations. I’m sure you’ll be just fine with the stock bulb
