3rd Gen Bilstein 5100's Now Available - In stock and Ready to Ship
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, Oct 11, 2016.
  1. Feb 27, 2017 at 10:50 AM
    #61
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I'll have to double check my alignment sheet to get specifics but over all very happy with the results.
  2. Feb 27, 2017 at 11:45 AM
    #62
    idoitforthebacon
    idoitforthebacon Active Member
    Awesome, thanks! I've been on the fence with a 1.5" or 2" via 6112's and trying to avoid UCAs to address Caster/alignment issues. Truck look great btw!
  3. Mar 12, 2017 at 5:44 PM
    #63
    joestacos
    joestacos Ice cold rice water
    that1tacoguy
    CenCal
    17 Tacoma TRD Off Road
    Pro Driver inside
    If I order the front set that is listen on your website and posted at the beginning of the post, I should be able to make it "leveled" ?
    New to this, sorry
  4. Mar 13, 2017 at 10:04 AM
    #64
    HeadStrong Off-Road
    HeadStrong Off-Road [OP] Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    It is really difficult to guarantee a particular stance since so many variables can come into play. In order to try to get the best results possible, I recommend measuring your current rake (from the center of the hub to the bottom of your fender on all 4 corners) to see exactly how much higher you sit in the back as opposed to the front. This way you will know about how high you will need to go in the front and/or rear to get you near the stance you are shooting for. Measurements should be taken on level ground in order to be as close to accurate as possible.
    ajsandiego likes this.
  5. Mar 13, 2017 at 11:26 AM
    #65
    joestacos
    that1tacoguy
    CenCal
    Pro Driver inside
    I know you cant guarantee a perfect stance, but my question is, If i buy this set you posted I dont need to buy anything else from you if i just want to set it at .85 right?
    Chrisperez305 likes this.
  6. Mar 13, 2017 at 11:55 AM
    #66
    HeadStrong Off-Road
    You wouldn't need anything else unless you wanted to get the rear shocks to match but that isn't necessary.
  7. Mar 13, 2017 at 12:13 PM
    #67
    joestacos
    that1tacoguy
    CenCal
    Pro Driver inside
    Cool thanks
    Ordering it right now
  8. Mar 13, 2017 at 12:40 PM
    #68
    HeadStrong Off-Road
    Sounds good. If there is anything else that I can help you with, just let me know! :)
  9. Mar 21, 2017 at 8:03 PM
    #69
    edansnatches
    edansnatches Well-Known Member
    erik
    wv
    2016 trd off road mgm
    icon 2.5 ext coilovers , icon resi rears dakar's lr uca's 255/80/17 wildpeak at3w Scs sr8’s are v series ccg 'merica trd grill
    @HeadStrong Off-Road . Marie, thanks for all your help in the past. I just sent you a PM with another question. Finally making the order!:muscleflexing:
  10. Mar 22, 2017 at 11:44 AM
    #70
    HeadStrong Off-Road
    :woot:Just responded to the PM :kona:
    edansnatches[QUOTED] likes this.
  11. Mar 30, 2017 at 5:48 AM
    #71
    AUTaco
    AUTaco Well-Known Member
    Todd
    Baton Rouge, LA
    2016 White Toyota Tacoma SR5 4x4 DCSB TSS Sport Package with 17" rims
    Raptor Style Grill , tonneau cover. 1 1/2 inch lift with Bilsteins all around.
    Marie new to game. If I put 5100's all around an set front at 2" & 1" spacer in back I should be close to level or have a little rake(no bro stance). Thanks
  12. Mar 30, 2017 at 7:38 AM
    #72
    HeadStrong Off-Road
    It depends on how much rake you have now. If you measure your current stance (while being parked on as level ground a possible) you will get an idea of how much higher you sit in the back as opposed to the front. Then you will at least have a starting point to add the 2" to the front measurements and the 1" to the rear measurements and see about how you will sit after the lift is installed. I have seen some 3rd gens be nearly level from the factory and some be close to 2" higher in the back so measuring your Tacoma helps.
  13. Mar 30, 2017 at 8:17 AM
    #73
    AUTaco
    Todd
    Baton Rouge, LA
    Marie I am 1" taller in back than front all way around. If set at 2" in front will I get any settling or should set at 1.55 and 1" block in back. Thanks
  14. Mar 30, 2017 at 8:24 AM
    #74
    HeadStrong Off-Road
    Those are the average after settled lift heights which means you would settle in near the 2" mark on a 4wd 4dr 2016+ Tacoma. It can depend on which way you would err. If you see more settling from the front or the rear which way would you prefer to sit should that happen, either nose high or rear high. You can also go back in and change the settings later if you wanted just a little bit more elbow grease is all.
  15. Mar 30, 2017 at 8:28 AM
    #75
    AUTaco
    Todd
    Baton Rouge, LA
    Thanks! Been a big help.
  16. Mar 30, 2017 at 8:30 AM
    #76
    HeadStrong Off-Road
    Anytime. That is what I am here for :thumbsup:
  17. Mar 30, 2017 at 8:31 AM
    #77
    AUTaco
    Todd
    Baton Rouge, LA
    One more question do I need to add a differential drop?
  18. Mar 30, 2017 at 8:42 AM
    #78
    HeadStrong Off-Road
    That depends on your after lifted angles. Whenever you lift the truck it is always good to familiarize yourself with your factory angles to so you know what may need to be corrected in order to prevent any premature ware, vibrations, etc.
  19. Mar 30, 2017 at 6:48 PM
    #79
    FishTaco57
    FishTaco57 Active Member
    Guy
    Columbus Ohio
    2017 TRD Offroad Quicksand
    So it sounds like you're the person to go to with questions. I plan on ordering a lift from you but with all the research I've done I can't figure out the advantage or if I need the extended rear Bilstein 5100's. I plan on ordering the 5100's front and rear with OME 87's then doing a AAL. Thanks in advance
  20. Mar 30, 2017 at 7:02 PM
    #80
    HeadStrong Off-Road
    IF you are not running any rear lift then you do not need the Bilsteins. However most people prefer the ride from the 5100's over stock so that is one thing to consider. Others want the shocks to match all the way around and some people want to know that all of the shocks on the truck were installed at the same time for maintenance/replacement.
