3rd Gen Block Heater Recall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thumpr71, May 6, 2020.
  1. Nov 18, 2022 at 5:49 PM
    #241
    jaapsheep
    jaapsheep Well-Known Member
    Janice
    canada
    2023 Blue Crush TRD off road access cab
    went for the blackout package this time
    Just got my block heater installed today. This was not a recall replacement, this was a new install. Mine didn't come with a block heater. Sure hope it's worth the $$. IMG_20221118_174135366.jpg
    doublethebass[QUOTED] likes this.
  2. Nov 18, 2022 at 6:29 PM
    #242
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    It does NOT take an hour and a half to install a block heater lol
  3. Nov 19, 2022 at 8:42 AM
    #243
    jaapsheep
    Janice
    canada
    I know, nothing happens in a hurry at Kelowna Toyota, and an appointment means absolutely nothing... they just keep your truck all day. Hate the place!
  4. Dec 23, 2022 at 9:19 AM
    #244
    jaapsheep
    Janice
    canada
    How did your block heater perform this past week? I had mine plugged in for half a day and the truck barely started in -20. I am not sure if it's the battery or the block heater not working or not up to the task. On my tractor, I can tell it's working because when I plug it in I listen and it makes a sound like when you first plug in the kettle... I listened for that on my truck, but didn't really hear anything. Is there a way to test the block heater? Otherwise, I spent $400 for nothing... On the hopeful side, it started registering on the temp gauge at about 5 km down the road, and in 10 min was blowing hot air... my battery is the original 2017, so I am suspecting it at the moment.
  5. Dec 23, 2022 at 9:34 AM
    #245
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I suspect battery. It's -25 to -30ish here the last little while and I haven't plugged in my block heater yet this year. Normal sluggish start but nothing concerning.
  6. Dec 23, 2022 at 9:53 AM
    #246
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    That is quite the scene with the Taco on fire in Post #1!
    It doesn't get that cold here in Delaware...at least below 17F...which is the coldest I've experienced since 2006.
    Here's an old thread I found while Googling what a "Block Heater" was and if I had one. It's an accessory I wouldn't want!
    https://www.tacomaworld.com/threads/oem-block-heater.398333/
  7. Dec 23, 2022 at 12:14 PM
    #247
    RotorRPM
    RotorRPM Well-Known Member
    Ontario
    2021 DCLB Sport
    TrueTrac
    I have had my truck plugged in the past week or so with temps ranging from -20c to -30. It certainly starts easier than if it’s not plugged in, and I agree it warms up faster for sure.
    As far as I can tell there is no way to ensure that the block heater is actually working though. My 06 Subaru block heater made a very faint noise if I put my ear to one wheel well, so I’m just running on faith with the Tacoma one.
    jaapsheep likes this.
  8. Dec 23, 2022 at 12:20 PM
    #248
    DuffyBank
    DuffyBank Well-Known Member
    I dug the cord out from under the back seat in -32C weather yesterday, had to bring it inside to warm up so I could uncoil it, then remembered that the plug on the truck is buried somewhere after my bumper install.
  9. Dec 23, 2022 at 12:26 PM
    #249
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    When it is really cold out, aim the temp reader gun at various part of the engine block and it should read at or above freezing when the outside ambient temp is -20 or whatever.
    I have an aftermarket KATS engine block heater, available from etrailer online, that draws 400 watts. Block heaters range in power from 400 to 1500watts.
    https://www.canadiantire.ca/en/pdp/...ered-digital-temperature-reader-0574554p.html
  10. Dec 23, 2022 at 12:33 PM
    #250
    RotorRPM
    Ontario
    2021 DCLB Sport
    TrueTrac
    Awesome thanks I'll try that! Atleast then I can make sure once a season at a minimum that all is working.
  11. Dec 23, 2022 at 7:41 PM
    #251
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I use a timer on mine, it starts up at 4am and runs until 8am. I usually start it around 7:30 so it’s had 3ish hours.
    Scanguage reads coolant temp if 15c on startup in -30c weather. It usually starts fine although this week I’ve had the trip odo reset which makes me think my original oem battery is also crapping out..
    jaapsheep[QUOTED] likes this.
  12. Dec 23, 2022 at 8:11 PM
    #252
    Firn
    Firn Well-Known Member
    White OR
    Block heaters have been used on millions of vehicles for many many decades now. This is a specific problem not an issue with "block heaters". Heck, other manufactures are having car fires from trailer connectors and tail lights. There are a thousand things on a car that can cause a fire, bad engineering is bad engineering.
  13. Dec 24, 2022 at 4:48 AM
    #253
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I'm not familiar with the concept...and you're right about engineering on any product.
    My son-in-law, who is studying to be an architect but has worked on cars most of his life, explained the concept of a Block Heater:
    It's like a heating element in an electric kettle only it goes into the vehicle fluid system to warm up the engine block.
    I understand now but from my experience, it just wasn't something I needed for my vehicles.
    As for today's temps...
    It was 8F overnight and feels like -8F according to my weather app.
    The only thing I did was put a windsheild cover on my Sport.
    Expected high for today is near 20F.
  14. Dec 24, 2022 at 6:13 AM
    #254
    DanoTay
    Victoria, B.C.
    The Tacoma has a slightly different system. Instead of removing a frost plug and installing the engine block heater element into direct contact with the antifreeze, the engine block itself is cast with a cavity or slot that the heater slots into and then heats the metal that it is in contact with.
  15. Dec 24, 2022 at 3:39 PM
    #255
    jaapsheep
    Janice
    canada
    mine made the saddest beep when I unlocked the door... my first clue I guess that a battery is probably in my near future. I don't have a way of measuring the coolant temp other that it seemed to warm the cab sooner than expected in -20 weather.
  16. Dec 24, 2022 at 4:38 PM
    #256
    lakerman
    lakerman Well-Known Member
    1stgen taco
    test in with an ohm reader super easy touch the 2 ends to the prong on the cord plug if it reads current she works., not sure how that new block heater got installed crickets when you ask the dealer... is all you hear in the western provinces.
  17. Dec 25, 2022 at 3:16 PM
    #257
    jaapsheep
    Janice
    canada
    ok, I'm a bit of a rookie with electrical things... but I do have a multimeter. Which part of the cord plug and what setting for the ohms? Started it again today at about -3, and had plugged it in for a couple hours anyway. Very sad sound to the first crank... I think it's my battery
  18. Dec 26, 2022 at 9:41 AM
    #258
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You don't really need to plug in a block heater unless it's -20C or colder and vehicle is outside. In a garage maybe -25C or colder. If I lived in Kelowna I'd never plug it in. If your battery is 5 yrs or older I'd just get a new one instead of messing about and worrying. Costco has as good of batteries as anywhere and good prices.
  19. Dec 26, 2022 at 3:04 PM
    #259
    jaapsheep
    Janice
    canada
    I have the truck outside and we did have -30 at night and several days of colder than -25. I live a bit above the valley bottom so it's colder up here. I do agree about the battery though, probably time to just get a new one before it leaves me stranded...
  20. Dec 26, 2022 at 3:49 PM
    #260
    DanoTay
    Victoria, B.C.
    In addition to plugging in a block heater, when it gets -20*C, I hook a smart trickle charger to my battery.
